Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: Vervoer over water!  (gelezen 1018 keer)
    • sleutelspoor
Vervoer over water!
« Gepost op: 19 August 2023, 11:53:45 »
Vertaal dit maar eens in spoorwagens en/of vrachtwagen!
Bakkie neemt minimaal 2000 ton mee (Kolen/Erts) :)
hrp
Re: Vervoer over water!
« Reactie #1 Gepost op: 19 August 2023, 12:46:21 »
Ik denk dat lege bakken makkelijker gaan, minder waterverplaatsing.
Of niet?
      Ronald
    • sleutelspoor
« Reactie #2 Gepost op: 19 August 2023, 13:10:02 »
Hieronder de gehele tekst met het antwoord, en de vertaling door Google.
If you watch river traffic frequently, you've probably seen a tow made up of empty barges before, just like this 56-barge tow being pushed northbound by the M/V E. BRONSON INGRAM near downtown New Orleans, LA. Answer from our Operations Experts: Empties can be pushed faster, but it's also like having a large wind sail out in front of you, so it can be challenging depending on the weather. That's why sound rigging work and focused Pilots/Captains play a crucial role in successful empty barge trips.
Als je vaak naar het rivierverkeer kijkt, heb je waarschijnlijk al eerder een sleep gezien die bestaat uit lege schuiten, net als deze 56-barge sleep die naar het noorden wordt geduwd door de M / V E. BRONSON INGRAM in de buurt van het centrum van New Orleans, LA. Antwoord van onze Operations Experts: Leeggoed kan sneller worden geduwd, maar het is ook alsof je een grote wind voor je uit hebt zeilen, dus het kan een uitdaging zijn, afhankelijk van het weer. Daarom spelen geluidstuigwerk en gefocuste piloten/kapiteins een cruciale rol bij succesvolle lege binnenvaarttochten.
R.C.Grootveld
  • Na 60 jaar 3Rail overgestapt op 'die kleine Rote'
    • Robula: Preda - Muot met een ruime blik
« Reactie #3 Gepost op: 20 August 2023, 18:27:57 »
In de VS is natuurlijk alles groter, maar "wij" kunnen er ook wat van.
De Veerhaven(NL) en Hercules(D) serie van Thyssen-Krupp, pendelen continue heen en weer tussen Rotterdam en Essen met erts en kolen.
Bij voldoende waterstand varen ze met 3x2 naar boven, 270m lang, waterverplaatsing ca 19000 Ton, waarvan ca 16000 Ton payload.
Naar beneden proberen ze veel mogelijk gebruik te maken van de stroming en varen ze met 2x3
Bijgaand een toevalstreffer waarbij een geladen opvarende en lege afvarende elkaar passeren bij Wesel.
Opm:
Ik heb geen aandelen in die club, werk er niet, kom ze alleen met enige regelmaat op het water tegen.
Fascinerende combinaties om te zien, vooral als ze vlak langs je varen.
j.ossebaar
« Reactie #4 Gepost op: 26 August 2023, 16:24:58 »
De duwboot Veerhaven  is van rederij veerhaven en vaart tussen Rotterdam en Schwelger ( roergebied ) , de andere boot is van rederij Imperial/Mannesman en vaart tussen Rotterdam . en Mannesman Rheinhausen . Daar de vaarsnelheid ,afvarig vrij hoog is  en het vaarwater afvarig in het midden van de stroom loopt moet de duwcombinatie afvarig zo klein mogenlijk gehouden worden . Snelheden van 20/25 km/h zijn afvarig normaal . In Amerika zijn de vaarwegen breder en soms dieper dan in europa , daardoor kunnen de duwconvooien groter in omvang zijn .
