24 October 2025, 23:41:26
Rocky Rail 6400 door ceuleer
24 October 2025, 23:22:35
Raadplaatje door Dpc Fo
24 October 2025, 23:14:01
Bruggen-IG - brug over de Poldervaart Schiedam/Kethel door Taigagaai
24 October 2025, 22:57:51
Bf Kibronn door Benelux795
24 October 2025, 22:56:05
24 October 2025, 22:49:49
24 October 2025, 22:43:01
Aanstaande zaterdag en zondag Modelbeurs in De Goorn NH door wmrail
24 October 2025, 22:19:20
Am Ende der Strecke, modulebaan op 1 M2 door 741230
24 October 2025, 22:02:32
Toon hier je nieuwe (model-) spooraanwinst(en)... door VulcanRaven
24 October 2025, 21:08:50
Yet Another Servo Decoder door spock
24 October 2025, 21:02:54
Artitec 6300 door ModelWessel
24 October 2025, 20:57:33
Pendel module Viessmann 5214 door Te 2/2
24 October 2025, 20:55:12
Hengelo in 1981-1982, maar dan anders: Kassenberg in N door Rick
24 October 2025, 20:35:22
sein decoder Z21 10837 programeren door n-driver
24 October 2025, 20:18:02
Z21 Pro Link en Wifi door n-driver
24 October 2025, 20:13:43
Overstap naar HTM door Jan Bennink
24 October 2025, 19:46:22
Big Scale Trains - NS SLT in H0 door HOHans
24 October 2025, 19:44:52
Project seaside Germany door Frank 123
24 October 2025, 19:35:40
Spoor 1 pendelbaan, maar dan rond (1:32) door rbroerse
24 October 2025, 19:28:58
24 October 2025, 19:23:43
MoBaBro.de door henk
24 October 2025, 19:22:58
Nederlands-materieel in Spoor-1 door FritsT
24 October 2025, 19:20:09
24 October 2025, 19:18:31
Mijn geweatherde modellen door Casmir
24 October 2025, 19:09:06
Ermehuizen, dienstregelingsjaar 1973/1974 door 1200blauw
24 October 2025, 19:06:46
24 October 2025, 18:49:17
Stalen D 4 deurs spoor 0 door FritsT
24 October 2025, 17:49:25
Klein mobiel ontwerp met thema stadsmuren door Slotticar
24 October 2025, 16:22:48
Een nieuw baantje op Micromodules door Ronald Halma
24 October 2025, 16:04:50
Auteur Topic: intellibox stuk, wat zijn gevolgen ??  (gelezen 730 keer)
Michel de Ridder
« Gepost op: 03 June 2023, 19:44:05 »
Door een stommiteit mijn intellibox kapot gemaakt, als hij nu onder spanning wordt gezet gaat het rode led's direct knipperen. Alles los gehaald en alleen voeding aangesloten, zelfde resultaat.
Conclusie hij is stuk.
Ik had nog een reserve intellibox liggen, deze aangesloten.  Bijna alles werkt nog behalve de S88 modules, die geven nu allemaal bezetmelding.
Hoe groot is de kans dat ook de S88 modules (een combinatie van Conrad S88 met eigen gemaakte stroomdetectie en Digikeijs 4088 CS) ook kapot zijn gegaan door de verkeerde spanning die werd aangesloten ??
Duikeend
Re: intellibox stuk, wat zijn gevolgen ??
« Reactie #1 Gepost op: 03 June 2023, 19:54:30 »
laat me raden: voedingsstekker in de s88 poort gestoken?  ;)
althans, dat deed ik dus vorig jaar. stom dat het past maar goed.
dus toen was het IC kapot. een leeg IC kost iets van 3 euro maar helaas is hij geprogrammeerd wat duurder.
ik meen dat me dat bijna 80 euro kostte bij Uhlenbrock/hobbytime. heb nog ergens het bonnetje liggen.
Verder was erbij mij niks kapot maar hoe dat bij jou is kan ik niet zeggen  ;)
Groetjes, Ferenc
hondekop
phdirk
« Reactie #2 Gepost op: 03 June 2023, 20:11:09 »
Hallo Michel,
Als je een beetje thuis bent in het Duits, kun je het reparatieformulier op de site van Uhlenbrock invullen, uitprinten en de zaak opsturen. Meestal heb je hem dan snel gerepareerd weer terug, al staat er nu op de site dat de reparatietijden kunnen oplopen.
Je kunt de IB ook naar HobByTime opsturen, zij sturen hem dan door naar Uhlenbrock.
Ik heb tot nu toe prima ervaringen met de reparatieservice van Uhlenbrock.
Met beste groeten,
Dirk Meijer
Michel de Ridder
« Reactie #3 Gepost op: 03 June 2023, 20:15:53 »
Dank voor de antwoorden, maar dat is de vraag eignelijk niet, de vraag is of de S88 modules ook defect zijn geraakt omdat nu, als ik koploper opstart alle bezetpunten branden.
R.C.Grootveld
  • Na 60 jaar 3Rail overgestapt op 'die kleine Rote'
    • Robula: Preda - Muot met een ruime blik
« Reactie #4 Gepost op: 03 June 2023, 22:29:49 »
Ik kan me vaag herinneren dat ik dat de eerste keer dat ik met m'n IB en S88 aan de gang ging ook had en opgelost heb door de S88 stekker om te draaien.
Andere optie: Vergeten in te voeren hoeveel S88 modules je hebt?
« Laatst bewerkt op: 04 June 2023, 12:52:39 door Reinout van Rees. Reden: citaat weg »
