Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: Faller containerkraan 120290 en vooral ... de aandrijving  (gelezen 20977 keer)
Joto
    • Tollens
Re: Faller containerkraan 120290 en vooral ... de aandrijving
« Reactie #75 Gepost op: 17 January 2020, 23:14:19 »
Citaat van: MOVisser
Kijk, ik ben op het forum, maar ben ook zakelijk bezig
Ronald,
Je hebt een tekening laten zien van een containergrijper, evt in n en een idee over een AVG.
Maar we hebben nog niets concreets cq werkend gezien,  wat het kan, eruit ziet en kost.  ???
Dat vind ik niet zakelijk.
Mijn persoonlijke gedachte is dat er veel animo voor is op zowel dit forum als bij het 3 rail forum,
mits er duidelijkheid wordt geschapen. (en geen verzoek in de trant van: "zeg het maar")
Eveneens persoonlijk,  vind ik dat je jouw investeringen voor je moet houden, maar gewoon als ondernemer duidelijkheid moet scheppen wat de offers voor de gebruiker zijn.
Voor de duidelijkheid,  het kan negatief opgevat worden, maar ik juich dit soort initiatieven alleen maar toe en zie "mijn" opmerkingen als een duwtje in de rug om uiteindelijk zakelijk succes te hebben. ( EN wij als forum-gebruikers ook  ;) )
Met vriendelijke groet
John
(Hopelijk een toekomstige grijper gebruiker)  ;D
« Laatst bewerkt op: 18 January 2020, 18:56:56 door 44 »
« Reactie #76 Gepost op: 18 January 2020, 17:48:11 »
werkend??? Dan heb je nog niet naar het you tube gekeken?? zie de link in eerdere posts
Prijs is al gemeld in Rijswijk en vandaag in Houten. Daar ook laten zien dat het werkt.
Ronald Visser
Joto
    • Tollens
« Reactie #77 Gepost op: 18 January 2020, 18:10:29 »
Waarom niet in dit draadje ?
« Reactie #78 Gepost op: 18 January 2020, 18:24:10 »
zie reactie #48.
Ronald
(Dit bericht is niet verzonden via Tapatalk) (y)
Debvd
« Reactie #79 Gepost op: 18 January 2020, 18:42:20 »
Het is een leuke, maar vooral ook spannende dag geweest vandaag. ???
Het grijper experiment opgezet met de onderdelen die ik ervoor klaar gemaakt had:
technisch lego portaal kraan (simplistisch maar werkend)
de grijper/spreader gemonteerd,
de batterijtjes voor de stroom voorziening etc etc.
Er zijn nog enkele zaken die ik wil verbeteren, gezien de ervaring tot nu toe.
Als dat gelukt is, de vormgeving bijwerken tot een mooi ogend geheel. (y)
Ik ben ook nog op zoek naar heel erg soepel stroomdraad.
Dat had ik, maar dat blijkt toch niet zo soepel in de praktijk.
Dit beïnvloedt het wel of niet roteren van de spreader net op het moment dat de container gegrepen gaat worden.
Daarom ben ik ook anders gaan denken over de communicatie met de grijper. Via de genoemde stroomdraden of draadloos en een batterijtje met electronica in de grijper ???
Spannend was het.
Ronald Visser
(O je wil het experiment zien   ;D :     you tube  https://youtu.be/l2c1JNHd3CQ     )
Ff naar voren gehaald voor je john ....Wel eerst goed draadje lezen hé  ;D ;D (y)
Ronald kan jij me ff pb sturen voor de prijsindicatie voor n  (y)
Frans Peeters
  • Gelukkig voor mij zit de laatste gek nog niet vast
« Reactie #80 Gepost op: 02 February 2020, 21:53:32 »
In het filmpje ga je steeds terug nar de setting voor een 40' container na het lossen van een 20'.
Is dit aan te passen in de sturing?
Kan je de sturing ook inbouwen in de bewuste Heljan-kraan. daar zijn de meest voorkomende problemen net de grijper die vast loopt. Als die vervangen kan worden...
Een prijsindicatie mag ook per PM of PB
Frans
MTD treinenclub vzw Edegem - www.mtdtreinenclub.be -
Tentoonstelling MODELSPOOR by MTD - Hangar 27, Edegem (B) op 24 & 25 Oktober 2026
