Train o Matic smart power pack
om 07:18:10
om 00:23:35
om 00:22:18
om 00:18:20
08 January 2026, 23:45:54
Thanks, Chat
08 January 2026, 23:34:07
Slijptrein
08 January 2026, 23:24:58
08 January 2026, 22:39:54
MaTrix 2026
hmmglaser
08 January 2026, 22:33:49
08 January 2026, 22:09:34
08 January 2026, 21:54:45
08 January 2026, 21:52:38
meino
08 January 2026, 21:49:32
Mitchell
08 January 2026, 21:26:48
Treinen afstellen
08 January 2026, 20:43:24
08 January 2026, 20:40:29
Diesellok DB221 donor motor
Freddy
08 January 2026, 20:36:12
08 January 2026, 20:35:13
Rijnstraat
08 January 2026, 20:00:04
Minitrix wissels verbranden
Patrick1977
08 January 2026, 19:54:43
08 January 2026, 19:36:57
08 January 2026, 19:16:12
NZH A 1001 - 1004
08 January 2026, 19:12:41
stroomdoorvoer k rails
schipcas
08 January 2026, 18:58:54
Station Roodeschool
Torikoos
08 January 2026, 18:15:18
Paulogic
08 January 2026, 18:00:19
Tandwielen Fleischmann BR 80
Bert54
08 January 2026, 17:06:35
Leids spoor (voorheen Blauwpoortsbrug)
08 January 2026, 16:42:17
Botsing bij SGB 29-12-2025
Reinier Z.
08 January 2026, 16:39:35
08 January 2026, 15:42:34
Vragen over verschillende merken rails (H0)
Topic: Vragen over verschillende merken rails (H0) (gelezen 53551 keer)
willem22
Re:Vragen over verschillende merken rails (H0)
Reactie #150 Gepost op:
26 October 2010, 23:15:21 »
Er zijn al wat draadjes hier over geweest kijk even bij de zoek funktie.
http://forum.beneluxspoor.net/index.php?action=printpage;topic=896.0
wil.
Team Beurzen en PR
Lid MSG Haarlemmermeer
Reactie #151 Gepost op:
27 October 2010, 08:35:17 »
Voor het gemak, samengevoegd
Vr. groeten,
Bob
Spiky
Reactie #152 Gepost op:
27 October 2010, 09:39:25 »
Handig draadje... Hopelijk binnenkort een keuze maken uit:
- Tillig Elite
- Roco Line zonder badding
- Piko A
dennie
Reactie #153 Gepost op:
27 October 2010, 18:28:43 »
Was gestart met oude lima rails wat een rotzooi was dat,bij de railverbinder af en toe kortsluiting kregen rood kleurtje.
Volgende baan was marklin metaal rails ook rotzooi,storingsgevoelig.Snel gedumpt.
Op beurs kennis gemaakt met profirails en sindsdien hele baan opgebouwd uit profirails ,voordeel makkelijk op maat te maken en je kunt er zelfs nog op staan.
Maarten43
Tb
Reactie #154 Gepost op:
27 October 2010, 18:32:37 »
In Ho, Rocoline zonder bedding
In n-spoor uiteraard Peco.
Maarten
N-spoor DB/NS Selectrix - HO NS DCC Profiboss.
Railroadtycoon
Reactie #155 Gepost op:
27 October 2010, 19:06:20 »
voorheen voornamelijk fleischmann, tegenwoordig Peco code 75 h0 en Peco h0e.. voor een gecombineerd stukje gebruik ik tillig
Erwin (n-spoorder)
o(N)t-spoorder uit Limburg
Reactie #156 Gepost op:
27 October 2010, 19:35:49 »
Meters GT-rails met Peko wissels
Omdat iedereen een hobby moet kunnen hebben.
NS 1607 Vlissingen
Zal 't gaan, ja!
Reactie #157 Gepost op:
27 October 2010, 19:44:22 »
wat op valt is dat de Fleischmann Profi-Gleis redelijk vaak genoemd word.
Hier zit er nog zo een wat over dat spul rijdt.
Jos.
En was 1680 cm Lang
(Rotterdam, 2009)
Jan van den Berg
Reactie #158 Gepost op:
27 October 2010, 20:11:20 »
Ik gebruik Fleischmann profi en slanke Roco modelwissels uit de oude serie 4504/05 nieuw zilver die ik zelf van een opvulling en grind bedding heb voorzien. en sommige met ondervloerse aandrijving. Een test pendel baan met Piko A gleis die erg mooi vind
Laatst bewerkt op: 27 October 2010, 20:23:53 door Jan van den Berg
J.v.d.Berg
MdR
Reactie #159 Gepost op:
30 October 2010, 12:03:33 »
Ik gebruik voor gewoon rocoline zonder bedding (was eerst met bedding) en in de schaduwstations rocoline met bedding.
breitenstein
Reactie #160 Gepost op:
30 October 2010, 14:15:43 »
Ik heb Tillig hO-Elite op het zichtbare gedeelte; de rails voldoen zeer goed; voor de Tillig-wissels gebruik ik Tortoise-motoren, hetgeen zeer goed werkt. Tillig heeft recent zijn wissels aangepast, zodat de kortsluitingsproblemen, die er soms bestonden definitief zijn opgelost. Op het niet-zichtbare gedeelte gebruik ik Piko-A-rails en wissels. In het schaduwstation is er dan het voordeel dat de uitgaande wissels open kunnen worden gereden.
Casper
Reactie #161 Gepost op:
30 October 2010, 14:53:50 »
ik gebruikte fleischmann profi.
maar die wisselspoeltjes wilden het niet echt doen bij mij.
denk dat ik iets fout heb gedaan maarja.
baan is gesloopt. omdat ik wat mooiers wil.
en omdat de rails niet zo goed was gelegd. op een gegeven moment moest ik eerst aan de ene kant
aan de rails rommelen om aan de andere kant te kunnen rijden.
reden: slechte stroomdoorvoer en maar 1 aansluiten. ipv een ringleiding.
en nogmaals ik heb er een beetje een zootje van gemaakt.
maar weet ik veel. eerste baan en nog niet op dit forum. je doet maar wat.
nu ga ik overstappen op rocoline zonder bedding.(2,1mm). ik heb het bij railz gezien.
en vond het erg mooi. dus dat word em.
ik heb mijn rolbrug deel al ermee gelegd. omdat ik wat oude roco rails had met die rubbere bedding. en die rails
is precies hetzelfde. toppertje dus. scheelt weer. (scheelt ook 40 euro(voor 2 wissels)).
het is al duur zat.
maar van fleischmann profi had ik een stuk met de fleischmann bedding gemaakt. en dat is wel mooi geworden.
als je met wat roestverf werkt zie je geen kleurverschil.
maar om nou zoveel van die dure zakjes te kopen ben ik ook niet van plan.
gr,
mathyn
www.MCKmodelbouw.nl
Nu ook op
instagram
Treinhobbijist
Reactie #162 Gepost op:
30 October 2010, 16:15:54 »
Gebruik al ruim 45 jaar Fleischmann messingrails ! (vanaf 1965)
En nog volop overal te krijgen, onverwoestbaar, dus dat zal wel zo blijven.
Overigens snap ik wel, dat als je NU als beginner iets gaat doen in deze hobbij, je hier niet zo snel hiervoor kiest .
Gr Treinhobbijist
Ook Engelse treinen zijn leuk
cor_b
at ,t moar exact 1:87 is
Doornvliet CS 1975 t/m 1995
Reactie #163 Gepost op:
30 October 2010, 22:28:29 »
Altijd Roco line met bedding gebruikt sinds de aankondiging van Roco in 1989 tijdens NS 150jaar
Verandering van spijze doet eten ,dus ik heb al meer dan 1jaar Tillig elite gleis en ,t bevalt goed.
Cor
Lokpaint
Reactie #164 Gepost op:
30 October 2010, 23:12:39 »
Hoi
Ik rij op märklin M-rail.
bart
