Train o Matic smart power pack door henk
Vandaag om 07:18:10
Modelspoordagen VERPLAATST naar 7 & 8 maart 2026 door Frank 123
Vandaag om 00:23:35
Vandaag om 00:22:18
Vandaag om 00:18:20
Rondom Charlois door Benelux795
08 January 2026, 23:45:54
Thanks, Chat door Quinzeedied
08 January 2026, 23:34:07
08 January 2026, 23:24:58
Hoek van Holland - Warschau, samenstelling in model. Welke rijtuigen? door Huibert
08 January 2026, 22:39:54
MaTrix 2026 door hmmglaser
08 January 2026, 22:33:49
08 January 2026, 22:09:34
08 January 2026, 21:54:45
Bouw NTM Stationsgebouw Lemmer door gdh
08 January 2026, 21:52:38
Wat is een redelijk goedkope dcc sein decoder? door meino
08 January 2026, 21:49:32
De Hofstraat in Eindhoven (1:160) door Mitchell
08 January 2026, 21:26:48
Treinen afstellen door Hans1963
08 January 2026, 20:43:24
08 January 2026, 20:40:29
Diesellok DB221 donor motor door Freddy
08 January 2026, 20:36:12
08 January 2026, 20:35:13
08 January 2026, 20:00:04
Minitrix wissels verbranden door Patrick1977
08 January 2026, 19:54:43
Digikeijs DR5000 Centrale, vragen en antwoorden door Ben
08 January 2026, 19:36:57
08 January 2026, 19:16:12
NZH A 1001 - 1004 door Gerco van Beelen
08 January 2026, 19:12:41
stroomdoorvoer k rails door schipcas
08 January 2026, 18:58:54
08 January 2026, 18:15:18
Ombouw/Pimpen Bolle neuzen door Paulogic
08 January 2026, 18:00:19
Tandwielen Fleischmann BR 80 door Bert54
08 January 2026, 17:06:35
Leids spoor (voorheen Blauwpoortsbrug) door Gerco van Beelen
08 January 2026, 16:42:17
Botsing bij SGB 29-12-2025 door Reinier Z.
08 January 2026, 16:39:35
Aachenau West door wob
08 January 2026, 15:42:34
Auteur Topic: Vragen over verschillende merken rails (H0)  (gelezen 53548 keer)
Piet van Dorssen
Re:Vragen over verschillende merken rails (H0)
« Reactie #120 Gepost op: 21 May 2007, 10:17:45 »
Wellicht wordt "Peco" bedoeld?
NS tijdperk 3; Lenz Digital Plus; station Meppel; Koploper in voorbereiding
« Reactie #121 Gepost op: 21 May 2007, 10:23:38 »
Roco line met bedding is op dit moment zeer goedkoop althans in Houten wat ik zo zag. Het voordeel is 1-Je hebt een bedding die zeer makkelijk te verouderen is. 2- De wisselaandrijving zit onder de wissel in de bedding en als je van plan bent om digitaal te rijden zet je er een digitale aandrijving in. Geen geouwehoer meer met externe decoders.
Rocoline met bedding wordt niet meer gefabriceerd en is om die reden geen aanrader. Roco heeft nog Rocoline zonder bedding en tegenwoordig Geoline met bedding. Doet sterk denken aan Trix C-rails.
NS1124
« Reactie #122 Gepost op: 21 May 2007, 11:51:07 »
Ik rij zelf met Fleischmann Profi rails en het bevalt me zeer goed, het is voor het rijden wel aan te raden om even een poetsblokje over de baan te halen maar daarna rijdt het vlekkeloos, en zeker als je een poetswagen (bruine roco bij conrad gekocht) mee laat rijden.
Het nadeel aan de Fleischmann rails is de kleine wissels, deze zijn niet geschikt om bijvoorbeeld kruispunten te maken op 2 spoors baanvakken.
Hierbij moet dan het baanvak aanzienlijk breder gemaakt worden en dit staat niet mooi. Door het aanpassen van de wissels kan dit zeker wel opgelost worden maar het is een hoop extra werk.
Ik ben zelf al weer aan het kijken geweest naar goede rails en roco rails zonder bedding (ik heb geen idee hoe het heet) is zeker een goede tweede keuze, het maken van sporenplannen voor stations is makkelijker en natuurgetrouw.
Peco rails is het mooiste maar ook prijzig, het is maar hoe je er tegen aan kijkt.
Succes met de keuze.
maartenvanderburgt
« Reactie #123 Gepost op: 21 May 2007, 16:46:25 »
Tillig rails is veel mooier (gebruneerd, doorlopende wisseltongen, continentale wissels) en niet prijzig, het is inderdaad maar hoe je er tegen aan kijkt.
Maarten van der Burgt.
Jeroen1975
  • GTW in de tuin
  • 45mm, zelfbouw, Brits- en Achterhoeks smalspoor
    • Jeroen's Treinen Site
« Reactie #124 Gepost op: 21 May 2007, 17:44:47 »
Piko rails is GEEN CODE 83, maar code 100  (2,5 mm)
Sorrie, dacht dat nieuwe A serie ook 2,1mm zal het wijzigen
Treinen van britse eilanden
Treinen uit de achterhoek
djm008
« Reactie #125 Gepost op: 21 May 2007, 23:16:29 »
Ik kan weer een hele serie rails kopen....fleischmann dit keer. Ik weet alleen totaal niet of ik er wat aan heb. Want ik heb me dus al gigantisch met die lima rails vergrabbeld. Wie zou ik hier eens over kunnen mailen?? Foto van de rails en wat het is...
RobE
« Reactie #126 Gepost op: 22 May 2007, 12:11:22 »
Dat je één keer de mist ingaat kan gebeuren maar laat dat geen tweede keer gebeuren.
Zonde van het geld.
Je hebt al verschillende keren advies gekregen over goede rails.
Zelf gebruik ik Piko A rails en dat bevalt uitstekend.
Nieuw en voor een scherpe prijs.
Rob
Rob is op 4 februari overleden.
Edits Booster, MRdirect, Koploper, HSI-88, Zimo, HO, 2 rail
johanR
« Reactie #127 Gepost op: 22 May 2007, 13:19:27 »
Ik sluit me hierbij aan, als je kijkt bij de link op het tweede bericht is dat een winkel die scherp aanbied. De rails is nog niet zolang op de markt en zal waarschijnlijk nog zeer lang gefabriceerd worden. Ik heb mijn rails verkocht en ben gewoon een plan gaan maken van mijn schaduwstation en heb dat gekocht wat ik nodig was. Ik koop dan later de rest wel als ik weer verder ben. Zo verspreid ik de kosten wat, en kan dan rustig bouwen. Ik zal als je toch voor de fleischmann rails gaat zeker geen messing rails gaan leggen op stukken waar je erg lastig bij komt.
Gr. Johan
erikpat
« Reactie #128 Gepost op: 26 May 2007, 00:08:22 »
hallo allemaal, ik heb mijn trein spullen weer uit de dozen gehaald.
En ik wil weer beginnen met een mooie baan te bouwen
Nu heb ik een vraag met wat voor merk rails kan ik HO Lima rails gebruiken.
alvast bedankt voor de moeite.
 gr erikpat
Marijn
  • Grote treintjes monteur
« Reactie #129 Gepost op: 26 May 2007, 02:21:33 »
Ik neem aan dat je vrij oude Lima rails bedoelt.
Deze heeft een spoorstaaf hoogte van +/- 2,5mm wat we dan weer Code 100 noemen voor het gemak  ;)
In principe kan je deze rails eenvoudig combineren met:
- Fleischmann Modellgleis
- Roco "2,5 mm" rail programma
- Piko A-Gleis
- GT-Flex
- Peco Code 100
Ook te combineren met de volgende merken welke een andere spoorstaafhoogte hebben code 83, 80 of 75 ( een klein hoogte verschil ontstaat op de overgang naar dit railmateriaal):
- Fleischmann Profigleis (met bedding)
- Roco Line (met of zonder bedding)
- Trix C rail (met bedding)
- Lima NEM 120 systeem
- Peco Streamline (code 75)
En dan heb ik nog niet alle merken genoemd  ;D
Om kort te zijn, je kan het aansluiten op de meeste gangbare 2 rail merken soms met een kleine aanpassing  ;D
erikpat
« Reactie #130 Gepost op: 26 May 2007, 09:53:09 »
ok ,dus ik heb keuze genoeg blijkt wel.
ik zal gelijk even verder neuzen voor meer rails.
bedankt voor je snelle reactie
Rijssensvosje
« Reactie #131 Gepost op: 15 June 2007, 15:38:18 »
Ik kan 2 railsets kopen van Roco Set C/D.
Dset  heeft het typenummer 42012.
Zijn dit geoline rails? OF zijn die makkelijk te koppelen aan
Geoline, icm met Digitaal rijden??
« Reactie #132 Gepost op: 15 June 2007, 15:40:22 »
Dat is het oude Rocoline met bedding. Is wat anders dan Geoline. De rails is wel te koppelen, maar de bedding ziet er heel anders uit.
Rijssensvosje
« Reactie #133 Gepost op: 15 June 2007, 15:48:58 »
ok, ik kan het kopen voor 40 euro, beide setjes, maar dan moet je dus gaan koppelen met geo,
en koppelstukjes kopen. Misschien met gevolg dat het puzzelen wordt waar je ze koppelt natuurlijk,
en om het dan mooi te laten lijken moet je het haast onzichtbaar leggen die rails, in n tunnel of schaduwstation
djm008
« Reactie #134 Gepost op: 23 June 2007, 15:18:29 »
Ik ben erg tevreden over mijn profirails. Hiervoor had ik lima.
Nu ben ik zelf niet zo'n railsexpert, maar kan iemand me hier zeggen of de profirails een goede soort zijn over het algemeen??
Misschien kan ook iemand me zeggen hoeveel jaar dat dit type rails al bestaat??
