Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: Spiegelglas snijden: hoe?  (gelezen 9099 keer)
arnout
Re: Spiegelglas snijden: hoe?
« Reactie #15 Gepost op: 23 August 2018, 14:39:24 »
Als je splinters hebt, heb je te hard gedrukt. Slaat je snijder over dan is hij of bot of je drukt te zacht. Het beste is je snijder droog te bewaren. Een beetje WD40 is genoeg om hem weer goed te laten snijden
Trein-H0
« Reactie #16 Gepost op: 23 August 2018, 21:15:45 »
@ Arnout: De inkepingen kun je wel gebruiken om lichte druk te creëren, niet om af te breken. Dan krijg je inderdaad kartelrandjes.
arnout
« Reactie #17 Gepost op: 23 August 2018, 21:47:39 »
Welke inkeping bedoel je?
Trein-H0
« Reactie #18 Gepost op: 24 August 2018, 10:00:01 »
Van de glassnijder
« Reactie #19 Gepost op: 24 August 2018, 10:24:22 »
Die inkepingen dienen om randjes af te breken die te smal zijn om met je handen beet te pakken.
