om 00:24:44
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?"
Michiel VL
26 January 2026, 22:59:31
EifelBurgenBahn
26 January 2026, 22:45:26
HeVe01
26 January 2026, 22:44:28
Heiko
26 January 2026, 21:45:15
Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
Carl
26 January 2026, 21:27:09
Faller 2026
26 January 2026, 21:09:37
Kippenlijn of Valleilijn
Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan
26 January 2026, 20:57:31
Christoph
26 January 2026, 20:50:23
Da's Daz 2
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel)
sdz1976
26 January 2026, 20:04:08
26 January 2026, 19:53:54
26 January 2026, 19:36:57
Rsd1000
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005
ns.1200
26 January 2026, 18:42:35
René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6)
Maikel van Velzen
26 January 2026, 18:24:45
william_2
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris.
26 January 2026, 17:15:20
Jouef BB9201 anno 1968
saskia
26 January 2026, 16:51:03
Welk soldeer
Topic: Welk soldeer (gelezen 1287 keer)
Ronaldp
Welk soldeer
09 February 2017, 15:56:03 »
Heb in huis print soldeer en electro soldeer.
welke is beter om rails aan mekaar te solderen?Is peco code 55 rails.
Beide hebben harskern.
mvg ronald
Multimaus
Bezetmelders Rosoft
Servo decoders Rosoft
xTreme Keerlus Rosoft
Rails en wissel peco 55
Koploper
Re: Welk soldeer
09 February 2017, 16:01:51 »
Wat is de samenstelling van beide soorten? Hoeveel tin, lood en eventueel koper of zilver zit er in?
Printsoldeer en elektrosoldeer klinkt alsof het hetzelfde is.
Ronaldp
Re: Welk soldeer
09 February 2017, 16:46:34 »
Dit is het print soldeer:
https://www.karwei.nl/assortiment/griffon-print-harskern-60/40-4-m-0-7-mm/p/B210632
Dit is het electro soldeer:
https://www.karwei.nl/assortiment/skandia-soldeerdraad-elektro-60/40-1-5mm-40-g/p/B413008
Volgens mij dus het zelfde?
Behalve de dikte?
klopt dat?
mvg ronald
Multimaus
Bezetmelders Rosoft
Koploper
Re: Welk soldeer
09 February 2017, 17:09:32 »
Ronald, probeer eens de Löt-öl van Sommerfeldt, artikel nummer 82. Daarmee kun je ook Märklin C-railprofielen aan elkaar solderen. Wellicht dat Godfather Models dit kan leveren.
Groet, Rob
robin binsbergen
Re: Welk soldeer
09 February 2017, 17:54:50 »
40/60 doet het ook prima hoor.
Eton Wick, UK
Re: Welk soldeer
09 February 2017, 18:05:17 »
Ik gebruik ook 40/60 met een 25 watt bout. Gaat altijd prima.
www.tramfabriek.nl
Volg mijn bouwactiviteiten op
Facebook
Re: Welk soldeer
09 February 2017, 18:59:29 »
Ik was een reactie aan te typen toen hier de stroom uitviel. Dus nu een herkansing.
Het soldeer van Ronald is allebei 60/40, dat betekent 60% tin en 40% lood. Voor elektrowerk is dat de gunstigste verhouding.
40/60 wordt ook vaak verkocht, maar dat is volgens mij omdat lood veel goedkoper is dan tin.
Ik geef zelf de voorkeur aan 60/40 want dat vloeit het makkelijkst.
Welk soldeer
