12 February 2026, 23:41:19
Spoorwegmuseum in zwaar weer
WesleyMunnik
12 February 2026, 23:20:49
EifelBurgenBahn
12 February 2026, 22:30:31
12 February 2026, 22:25:10
12 February 2026, 22:11:03
Cegielski
12 February 2026, 22:02:11
12 February 2026, 21:55:06
Stub switches
12 February 2026, 21:28:45
12 February 2026, 21:15:21
Steven Loosman
12 February 2026, 21:15:20
reinderlf
12 February 2026, 21:12:47
12 February 2026, 21:09:20
Bediening OOC terminal Oss
timtrein
12 February 2026, 19:50:02
12 February 2026, 19:42:24
12 February 2026, 18:50:46
12 February 2026, 18:42:35
Roco 70788 2400 met Zimo MX645 acceleratie settings
Steven Loosman
12 February 2026, 18:12:17
Station Weesp
virmfan
12 February 2026, 18:05:15
Foto's station Weesp gezocht
virmfan
12 February 2026, 18:01:04
Voordelige treinkaartjes
12 February 2026, 18:00:49
12 February 2026, 17:46:46
Mijn LEGO modellen.
12 February 2026, 17:29:22
12 February 2026, 17:18:29
12 February 2026, 17:03:17
4 april Het Stoomgenootschap naar Köln
Seinhuis
12 February 2026, 16:55:32
Minstens 5 jaar geen treinverkeer Groningen-Leer [D]
Noordster
12 February 2026, 16:51:57
12 February 2026, 16:42:09
Spoor vernieuwing Oisterwijk
12 February 2026, 16:42:05
12 February 2026, 16:41:07
Daan Knoben
12 February 2026, 16:25:59
Digitaal
Fleischmann booster 36VA
Topic: Fleischmann booster 36VA (gelezen 1532 keer)
Ronaldp
13 December 2016, 14:09:15 »
Heb een fleischmann multimaus met een fleischmann(680801)booster van 36VA
Nu zie je ook fleischmann boosters van 50VA.
Is dan de booster anders?
Of is alleen de voedings adapter zwaarder?
mvg ronald
Multimaus
Bezetmelders Rosoft
Servo decoders Rosoft
xTreme Keerlus Rosoft
Rails en wissel peco 55
Koploper
Ronaldk
Re: Fleischmann booster 36VA
13 December 2016, 14:14:33 »
Dat is alleen een zwaardere trafo. De versterker (booster) is hetzelfde namelijk een roco 10764. Degene met 36VA levert ongeveer 2A voor de baan en de 52VA levert ongeveer 3A voor de baan.
Groeten Ronald.
santerdam
13 December 2016, 14:16:41 »
Het verschil is alleen de capaciteit van de voeding.
De FLM 680801 is identiek aan de Roco 10764. Daarvoor kun je een 36VA gelijkspanning adapter gebruiken of een 50VA wisselspanning trafo.
Sander
Edit : Ronald was me voor !
Ronaldp
13 December 2016, 14:20:04 »
Dus met ander woorden...als ik een zwaardere trafo koop?
Heb ik dus gelijk een zwaarder uit voering.
Moet het altijd een trafo van fleischmann zijn.
Of kunnen er andere trafo.s op?
mvg ronald
Multimaus
Bezetmelders Rosoft
Koploper
Ronaldk
13 December 2016, 14:26:30 »
Kan ook andere trafo's voor gebruikt worden. Volgens mij maximaal 18 volt als uitgangsspanning. Ik zal eens kijken naar wat op de zware trafo staat. Je krijgt er niet meer dan ongeveer 3A op de baan meer levert de versterker niet. Dus veel zwaarder dan 52VA is niet nodig
Groeten Ronald.
Ronaldp
13 December 2016, 14:37:35 »
Hebben jullie voorbeelden van welke trafo's ik er bv bij kan kopen?
En het liefst ook waar?
mvg ronald
Multimaus
Bezetmelders Rosoft
Koploper
Modelrailroading is fun!
13 December 2016, 16:47:12 »
Viesmann, Conrad, Lenz.... zijn allemaal of gelijk of bijna gelijk. Zoals mijn naamgenoot al aangeeft, rond de 50VA is prima. En dat zijn die dingen allemaal:
https://www.conrad.nl/nl/Search.html?search=krachtige%20transformator&sc.WT.ac=modelspoor_01-04-2016_NL_transformator_highlight
Deze:
https://www.conrad.nl/nl/krachtige-transformator-230-v-bv00026-404288.html
Te 2/2
Metrop-Märklin
13 December 2016, 16:57:36 »
Tja, 2A of 3A of meer, wat doet dat met de bedrading?
Bij hoeveel ampere ga je een kritieke grens over?
Interessant zo'n adveis dat het niet uitmaakt ...
Jan Willem
CH, peco, piko, roco, k-rail
Ronaldp
13 December 2016, 17:14:36 »
Werk met en ringleiding van 2.5mm2.
Dus dat wordt niet de bockelnek.
Zo groot is de baan niet.
mvg ronald
Multimaus
Bezetmelders Rosoft
Koploper
13 December 2016, 18:49:18 »
Citaat van: Te 2/2 op 13 December 2016, 16:57:36
Door 2,5 mm2 kan je probleemloos 20A jagen. Bij de keuze voor de draaddoorsnede bij een modelspoorbaan gaat het dan ook niet in de eerste plaats om de stroom, maar om de spanningsval.
Digitaal
