HS 4de klasse Staatsspoorstation door Sven
Vandaag om 01:15:06
Multimaus Zwart door Sven
Vandaag om 01:10:26
Ontraxs 2026 door Marty
Vandaag om 00:50:22
Vandaag om 00:36:38
Bentheimer Eisenbahn, gisteren, vandaag en morgen. door borotof
Vandaag om 00:29:24
Houten Plus zaterdag 21 februari 2026 door p-kokkie
19 February 2026, 23:36:38
Vraagje over digitaliseren Hamo Motorpost door borotof
19 February 2026, 23:21:45
US diorama in H0 door Jelmer
19 February 2026, 22:45:52
19 February 2026, 22:26:14
Duitse/Belgische tegenhangers van Beneluxspoor/3railforum? door sncf231e
19 February 2026, 22:15:30
Aachenau West door Peter J K
19 February 2026, 21:58:27
Stub switches door Hans1963
19 February 2026, 21:54:31
Onlangs gespot - gefotografeerd, de foto's door Menno de Vries
19 February 2026, 21:24:50
Trein Eindhoven Brussel? door Hlv53
19 February 2026, 21:09:45
19 February 2026, 21:01:31
19 February 2026, 21:00:55
Fabrieksplaten NS E-lok 1600 en 1700 door Kees-Jan
19 February 2026, 20:52:45
PB Models, ICR-rijtuigen door De eerste Ivo
19 February 2026, 20:49:36
19 February 2026, 20:40:09
19 February 2026, 20:30:26
19 February 2026, 19:55:44
19 February 2026, 19:15:50
19 February 2026, 18:34:04
Vraagje over servo aansluiting door Joost O
19 February 2026, 17:19:49
Fleischmann 1898 set analoog>digitaal door Robert uut Salland
19 February 2026, 17:15:26
Cv instellingen Fleischmann Sprinter door 008200
19 February 2026, 17:08:22
19 February 2026, 17:01:54
19 February 2026, 16:47:17
H0e pizza layout door Sven
19 February 2026, 15:39:10
NSB 20b en 21b door Simplex
19 February 2026, 14:49:30
Auteur Topic: welke soort rails?  (gelezen 1738 keer)
jeroen5822
welke soort rails?
« Gepost op: 15 October 2016, 17:55:44 »
hallo allen,
Welke soort rails past er op de piko a rails?
greetz jeroen
zuylen
Re: welke soort rails?
« Reactie #1 Gepost op: 15 October 2016, 20:51:58 »
Kort gezegd alle HO rails behalve rails van het Marklin systeem.
Ronaldk
« Reactie #2 Gepost op: 15 October 2016, 21:04:08 »
Dat is inderdaad kort gezegd :) In principe kan je alle rails aan elkaar knopen, behalve een paar soorten van Märklin. Er zitten wel verschillen in hoogtes tussen bepaalde merken en railsoorten. Dus zonder bedding, met bedding. Ook verschillen in spoorstaaf hoogte is mogelijk. Daar zal je op moeten letten als je verschillende merken door elkaar wil gebruiken. Kijk maar eens voor de gein in dit artikel: Rail (spoorstaaf), hoogte en materiaal
Groeten Ronald.
« Laatst bewerkt op: 15 October 2016, 21:06:11 door Ronald Koerts »
Hendrik Jan
« Reactie #3 Gepost op: 15 October 2016, 21:41:31 »
Het minder eenvoudige antwoord:
piko A-gleis is "code 100".
Dat betekent: 100/1000 van 1 inch, oftewel 2,54mm.
Combineer je dit met bv peco code 100, of Fleischmann Profi Gleis (ook code 100), dan gaat het prima.
Maar combineren met de oude Fleischmann Modell Gleis (zonder bedding, met messing railsstaven), dan heb je een uitdaging.
Deze railstaven zijn namelijk grover en vooral hoger: 2,7mm.
Dat lijkt niet veel, maar kan toch problemen geven.
Ook lagere profielen komen voor. Bv code 83 of code 75.
Het is allemaal wel te koppelen, met speciale verloop-raillassen. Maar misschien moet je dat niet willen.
Over rails zijn op dit forum al zoveel bomen opgezet, dat je misschien het bos niet meer ziet.
Mocht je naar Eurospoor komen:
loop even langs bij de Beneluxspoor stand (of modulebaan) en laat je voorlichten.
groeten
Hendrik Jan
-Billy Connolly
Te 2/2
  • Metrop-Märklin
« Reactie #4 Gepost op: 19 October 2016, 23:35:25 »
Ehh, k-rails past ook min of meer (de trein merkt de overgang niet, oog en vingertop wel).
Ik mix piko-A met peco puko's samen met k-rails
(maar ja, die had ik het eerst als voormalig puristisch 3-railer).
Je kunt piko-a samen gebruiken met het oude (beddingloze) roco 2,5, en met peco code 100.
Met verloop raillasjes kun je van piko-A (code 100) naar tillig (code 83) of peco (code 75).
En ook zonder lukt dat met enige handigheid (met dun ophoog materiaal balsa hout, mdf, papier).
Voor eerdere discussies zie dit draadje uit
2011:
http://forum.beneluxspoor.net/index.php/topic,39809.msg630548.html#msg630548
2012:
http://forum.beneluxspoor.net/index.php/topic,41425.msg650918.html#msg650918
Leuk idee, misschien zien we elkaar allemaal wel op Eurospoor!  (y)
« Laatst bewerkt op: 20 October 2016, 00:43:35 door Te 2/2 »
Jan Willem
CH, peco, piko, roco, k-rail
jeroen5822
« Reactie #5 Gepost op: 09 November 2016, 19:34:51 »
tnx voor de reakties allen.. ik ga er even mee stoeien
jeroen
