EifelBurgenBahn door Frank 123
Vandaag om 06:14:56
Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: Verlichting in LS Models ICR rijtuig  (gelezen 9563 keer)
Henk Veenstra
« Gepost op: 10 March 2016, 15:25:03 »
Hoe binnenverlichting inbouwen in een ICR rijtuig van LS Models.
Vooral hoe stroomafname op de wielen aanbrengen.
mvg Henk
« Laatst bewerkt op: 10 March 2016, 16:35:17 door Bert van Gelder »
IJsselsteyn
Re: Verlichting in LS Models ICE rijtuig
« Reactie #1 Gepost op: 10 March 2016, 16:21:53 »
ICE's zijn hogesnelheidstreinen in Duitsland. Dit is een ICR-rijtuig.   :police:
Steyn
Bert van Gelder
Re: Verlichting in LS Models ICR rijtuig
« Reactie #2 Gepost op: 10 March 2016, 16:35:41 »
Dat staat er toch??
Brs
    • Mat'89
« Reactie #3 Gepost op: 10 March 2016, 17:29:44 »
Er zitten twee koperstripjes in het plastic zakje met onderdelen. Ik heb 3 setjes en sommige hebben alle 6 stripjes in hetzelfde zakje (2 voor elk van de 3 wagons), en sommige 2 per zakje. Hier kun je een dun draadje aan vast  solderen. Als je de wagon opent zie je dat er aan de bovenkant van de wanden in het midden een soort inkeping zit. Hier kun je de meeste ledstrips prima in kwijt. Ik heb zowel huffing-tonic als digikeijs strips met success ingebouwd. Eventueel kan ik vanavond wat foto's maken.
Henk Veenstra
« Reactie #4 Gepost op: 10 March 2016, 18:01:32 »
Brs,
Ik zou het fijn als je er wat foto's van zou willen
maken.Bedankt alvast.
mvg Henk
Brs
    • Mat'89
« Reactie #5 Gepost op: 10 March 2016, 20:23:02 »
Hier een foto van de benelux ICRm van LS Models:
Let op dat de dikte van de draad die je ziet als de kap eraf is, eigenlijk te dik is. Deze heb ik meteen voorzien van dunner draad zodat deze niet schuin gaat staan
IJsselsteyn
« Reactie #6 Gepost op: 10 March 2016, 20:30:14 »
« Reactie #7 Gepost op: 10 March 2016, 20:43:09 »
Ik heb aangepaste Roco stroomafnemers gebruikt. Verder telkens twee of drie rijtuigen elektrisch gekoppeld.
Brs
    • Mat'89
« Reactie #8 Gepost op: 10 March 2016, 21:09:13 »
De Roco stroomafnemers zie ik vaker langskomen hier op het forum, maar heb ze nog niet in een winkel/online gezien. Heb je wellicht een artikelnummer? Ik heb merkloze slepers die meestal passen, maar bij de LS models ICRm niet... Een van de meegeleverde slepers die is zo misvormd dat er vaker niet dan wel stroom opgenomen wordt...
« Reactie #9 Gepost op: 10 March 2016, 21:19:27 »
De Roco stroomafnemers koop ik meestal op een beurs bij Treinenshop Emmen. Per post werkt ook.
http://www.etsemmen.nl
Brs
    • Mat'89
« Reactie #10 Gepost op: 10 March 2016, 21:30:45 »
Ik kan ze jammer genoeg niet vinden als ik op stroomafnemer(s), slepers of wielcontact zoek. Enkel "binnenverlichting voor 4 assige rijtuigen":
http://www.etsemmen.nl/component/virtuemart/toebehoren/roco/binnenverlichting-voor-4-assige-rijtuigen-detail?Itemid=0
Maar daar lijken andere stroomafnemers bij te zitten...
« Reactie #11 Gepost op: 10 March 2016, 21:32:12 »
Ik weet het bestelnummer ook niet uit mijn hoofd. Maar als je een mailtje naar de treinenshop stuurt, heb je in de regel snel antwoord. Prima service.  (y)
Peter Spruit
  • SBB en BLS baan in opbouw - Project Goschensteg
« Reactie #12 Gepost op: 11 March 2016, 08:24:18 »
Deze stroomafnemers kan je ook vlot kopen via bvb E-Bay Duitsland.
Ik behou de 3 lipjes ( 2 onder en 1 op de as )
Andere tip :  tussen het lipje en de as even heel klein beetje aantippen met het beruchte/beroemde ATF en je hebt een bijna flikkerloze verlichting en practisch geen rolweerstand meer daar deze de wrijving zo goed als wegneemt  ;)
Mvg
Peter
Petdig1
Brs
    • Mat'89
« Reactie #13 Gepost op: 11 March 2016, 10:02:15 »
Dat is inderdaad bijna bizar te noemen hoe goed dat werkt, ik was ook een beetje sceptisch maar heb een maand geleden ook "ATF-Dexron II-D 1L" besteld a EUR 12,-.
Volgens mij kan ik daar vrijwel oneindig mee doen (als ik het alleen voor de hobby gebruik).
Met een wattenstaafje het lipje en het contactdeel van het wiel en de rails aangetipt en in 99 van de 100 gevallen het flikkeren opgelost (het overgebleven geval was een stroomafnemer die niet goed vast zat)
Henk Veenstra
« Reactie #14 Gepost op: 11 March 2016, 10:06:14 »
Brs,
Is dat een zelf gemaakte stroomafnemer?
Henk,
Zijn dat geen Hufting stroomafnemers?
Wat is ATF.
mvg Henk
