24 en 25 Januari 2026 modelspoorweekend Ewijk door neudalhausenstadbahn
Vandaag om 00:29:38
Vandaag om 00:00:32
Brawa 2026 door grossraumwagen
24 January 2026, 23:40:44
Doornvliet door Ronzol
24 January 2026, 23:34:13
Condensator - Binnenverlichting en Decoder. door bask185
24 January 2026, 23:13:01
Japanse 2C2, 4-6-4, Hudson locomotieven in vele schalen. door minilocomaster
24 January 2026, 23:06:10
Baan weer opgebouwd na vervangen dakraam door minilocomaster
24 January 2026, 23:05:13
Bahnstrecke 5867 door 741230
24 January 2026, 22:50:51
Spur 0 1 Tage 2026 in Giessen (D) door Marty
24 January 2026, 22:34:05
"Southern Pacific's Coos Bay Branchline in H0", een nieuwe thuisbaan. door Hans1963
24 January 2026, 22:32:00
24 January 2026, 21:35:17
PB Models, ICR-rijtuigen door cor_b
24 January 2026, 21:12:14
Welke central is betrouwbaar? door Ronald Halma
24 January 2026, 20:13:51
Ontraxs 2026 door Ronald Halma
24 January 2026, 20:08:37
24 January 2026, 20:04:43
Baanplan De Oosthoek (h0, 360 bij 140) door Frans Peeters
24 January 2026, 19:28:07
Bruine NS 1200s - Treinsamenstellingen. door Ferdinand Bogman
24 January 2026, 18:54:47
Ervaringen met bezorgdiensten (PostNL, DHL, etc) door Charles_
24 January 2026, 18:51:22
Yamorc YD8116 & MP1 vraag door Bert_Apd
24 January 2026, 18:44:28
19 Toen door Keska
24 January 2026, 18:42:15
US diorama in H0 door gdh
24 January 2026, 17:19:28
24 January 2026, 17:11:28
Die Sauerlandbahn - Tijdperk III door Frank 123
24 January 2026, 17:00:50
heeft iemand ideeën voor een baan van 120CM bij 240CM? door Ronald69
24 January 2026, 16:47:55
24 January 2026, 15:50:12
Oudere Marklin S3/6 opleuken door Robkop
24 January 2026, 15:19:07
24 January 2026, 15:05:32
Handleiding Trix Express 2232 BLS 255 door stoombr38
24 January 2026, 13:36:46
ICR-rijtuigen, voor welk merk ga je? LSmodels, PBmodels, Exact Train of Piko? door Hammondman
24 January 2026, 13:28:12
Big Scale Trains - NS SLT in H0 door hmmglaser
24 January 2026, 13:11:19
Auteur Topic: Bröckenbahn  (gelezen 174797 keer)
  • Eens komt het goed.
    • MIL MOD
Re: Bröckenbahn
« Reactie #615 Gepost op: 12 August 2019, 21:25:00 »
Het is toch wel heel apart wat je maakt Frank  (y)
Re: Bröckenbahn
« Reactie #616 Gepost op: 13 August 2019, 21:32:29 »
Al het goede komt in 2en, of in mijn geval stuk of 4 ;D
Bedacht met te laat dat het beter in de ruimte gaat passen als ik het hele plan spiegel..
Dus de boel maar weer opnieuw geprint en uitgesneden....
Meteen maar van de gelegenheid gebruik gemaakt om de opstelsporen van het schaduwstation nog wat te verlengen...
Nog nog even oude railplan lossnijden en de nieuwe er op lijmen
Am Ende der Strecke
Den gamla sågverket (gepland)
  • Het leven op de weg.
    • Midland
Re: Bröckenbahn
« Reactie #617 Gepost op: 15 August 2019, 09:21:35 »
Dat gaat er goed uitzien.
Al in gedachten wat voor industrie je gaat maken?
Dan krijgt je spoorbaan een echte van A naar B functie. Mogelijk nog een extra station/haltes.
Wat betreft de industrie kun je in je 3D model al zover gaan dat je mock-ups plaatst van de gebouwen die je zou willen hebben.
Dan krijg je daar ook al een idee van hoe de je de sporen wilt hebben liggen.
(y)
Gr Koen.
Re: Bröckenbahn
« Reactie #618 Gepost op: 15 August 2019, 09:40:34 »
Hoi Koen,
In ieder geval een landelijk karakter en iets met hout en steen. Dus zagerij en steengroeve oid...
Gebouwen ook in het model plaatsen was wel mijn bedoeling
Am Ende der Strecke
Re: Bröckenbahn
« Reactie #619 Gepost op: 15 August 2019, 21:22:45 »
En weer begonnen met de spanten....  met passen en meten ca 2 stuks per avond dus ben hier d3 komende 2 weken wel zoet mee..
Am Ende der Strecke
Re: Bröckenbahn
« Reactie #620 Gepost op: 15 August 2019, 21:32:08 »
Omdat ik wat beter beeld van het totale oppervlak wou bedacht ik me vandaag dat in de presentatieruimte op mijn werk verijdbare tafels van 1,5 bij 0,75 gezet worden. Vanmiddag deze even 7,5 meter uit elkaar gezet zodat er een vak van 1,5 x 7,5 op tafel hoogte ontstaat.
Conclusie: daar moet de komende jaren voldoende van te maken zijn.
Am Ende der Strecke
    • Midland
Re: Bröckenbahn
« Reactie #621 Gepost op: 16 August 2019, 19:07:00 »
Het wordt een grote baan.
Qua landschap is er werk aan de winkel.
Gr Koen.
    • MIL MOD
Re: Bröckenbahn
« Reactie #622 Gepost op: 16 August 2019, 19:24:40 »
Zo Frank, dat gaat wat worden  (y)
  • Spoor-0 & Spoor-1
    • Modeltreinbaan.nl
Re: Bröckenbahn
« Reactie #623 Gepost op: 16 August 2019, 19:38:00 »
Geweldig Frank! (y)
Re: Bröckenbahn
« Reactie #624 Gepost op: 16 August 2019, 20:05:14 »
Heren,
Bedankt voor de positieve reacties. Ik verwacht alleen pas begin 2020 te starten. Eerst nog even wat zaken in huis verhuizen, oude baan afbreken, paar wanden op zolder er uit halen en nieuwe vloer leggen.
Tot die tijd ga ik verder met uitwerken van het plan (o.a. het 3D model). Dus nog even geduid voor dat de echte bouw start  >:(
Am Ende der Strecke
Re: Bröckenbahn
« Reactie #625 Gepost op: 17 August 2019, 11:03:29 »
Ik ga overigens ook nog een alternatieve opzet uitwerken. Soort van u- vormige baan langs de randen van de ruimte waarbij het schaduw station in vaste opstelling komt en de het zichtbare deel in modules hier bovenop.
Ben nu nog even aan het uit dokterren hoe ik dit constructief het beste kan doen.
Am Ende der Strecke
Re: Bröckenbahn
« Reactie #626 Gepost op: 18 August 2019, 22:28:39 »
Zo... alle spanten zitten er op..
Komende week verder met de rails op niveau 1 en 2.
Am Ende der Strecke
Re: Bröckenbahn
« Reactie #627 Gepost op: 19 August 2019, 20:55:14 »
Drank probleem ??
Am Ende der Strecke
willem7853
Re: Bröckenbahn
« Reactie #628 Gepost op: 20 August 2019, 12:07:42 »
Drank problemen ontstaan als het op is, of niet meer kan betalen. ;D
(Maak er nu wel een geintje over, maar is voor sommige mensen een groot probleem dat je niet mag baggataliseren.)
thuis ben ik de enige die (model)spoort
  • Forummoderator
Re: Bröckenbahn
« Reactie #629 Gepost op: 20 August 2019, 18:12:01 »
In een Fremo blaadje las ik eens over een 0e baan waar bezoekers ook rond mochten rijden. Maar eerst een rijbewijs halen: een gevuld borrelglaasje moest met een open wagon zonder morsen van het ene eind van de baan naar het andere gereden worden... :)
Reinout
