Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: Bröckenbahn  (gelezen 175184 keer)
Re: Bröckenbahn
« Reactie #390 Gepost op: 20 November 2018, 22:16:21 »
Deze is misschien beter, iets minder sfeer maar scherper (blijft iPad kwaliteit)..
Grenspaaltje tenminste wel herkenbaar :D
Am Ende der Strecke
Den gamla sågverket (gepland)
  • Eens komt het goed.
    • MIL MOD
Re: Bröckenbahn
« Reactie #391 Gepost op: 21 November 2018, 08:13:24 »
Heel mooi Frank  (y)
En lekker scherp!
Re: Bröckenbahn
« Reactie #392 Gepost op: 22 November 2018, 21:20:31 »
Zie nu pas dat ze weg gegaan zijn zonder de kabelgoot dicht te maken.. :o
Am Ende der Strecke
Re: Bröckenbahn
« Reactie #393 Gepost op: 24 November 2018, 17:39:17 »
Binnenkort kunnen de reizigers ook het eilandperron bereiken....... wel zo makkelijk.
Am Ende der Strecke
Re: Bröckenbahn
« Reactie #394 Gepost op: 25 November 2018, 21:56:33 »
Omdat het zondagavond is...
Mis aan deze kant eigenlijk alleen de seinen nog.
Am Ende der Strecke
  • Forummoderator
Re: Bröckenbahn
« Reactie #395 Gepost op: 25 November 2018, 23:17:24 »
Dit zijn plaatjes om van te smullen!
Een paar seinen zouden het hier ook leuk doen als extra kleurtje (rood/wit). En als extra vertikaal element.
Hoe zit het eigenlijk met de tunnelingang? Hij lijkt breed genoeg te zijn voor drie sporen terwijl de twee buitenste sporen allebei in een stootblok eindigen? Ik heb het even niet meer helder voor de geest of je een verhaal had qua "vroeger was het dubbelsporig".
Reinout
« Laatst bewerkt op: 25 November 2018, 23:21:09 door Reinout van Rees »
Rondje_HO
Re: Bröckenbahn
« Reactie #396 Gepost op: 26 November 2018, 09:56:40 »
Oh, die open kabelgoot moet ik even onthouden :) Da's net zo'n goed detail.
Re: Bröckenbahn
« Reactie #397 Gepost op: 26 November 2018, 19:53:27 »
Reinout
Hoi Reinout,
Bedankt voor compliment. Wat de tunnel betreft, in eerste instantie had ik een dubbelspoor de tunnel in. Ik was alleen niet tevreden over het sporenplan van het station. Dit was eigenlijk alleen op te lossen door met een enkelsporig traject naar/ van het station te gaan. Daarom geworden zoals het nu is. Direct in de tunnel ligt een (verborgen) wissel en gaat het direct weer naar dubbelspoor via de helix naar boven. Om tunnelingang niet te hoeven slopen heb ik het nu zo gemaakt als of er een van de 2 sporen buitendienst is gesteld en nu alleen nog opstelspoor is. Achter het stootblok liggen ook nog de resten van het oude spoor.
Wist geen betere oplossing. Als iemand een betere weet dan hoor ik het graag.
Gr Frank
Am Ende der Strecke
  • Forummoderator
Re: Bröckenbahn
« Reactie #398 Gepost op: 26 November 2018, 23:08:37 »
Prima oplossing hoor! Er zijn zat lijnen die dubbelsporig werden uitgevoerd (vaak met het oog op de wedstrijd Duitsland-Frankrijk zullen we maar zeggen) die in vreedzamer tijden slechts enkelsporig werden gebruikt.
Reinout
Re: Bröckenbahn
« Reactie #399 Gepost op: 27 November 2018, 08:21:02 »
Reinout
Dat is mooi, de baan is niet naar voorbeeld gemaakt maar de bedoeling is wel dat het realistisch is. Weet jij toevallig ook nog of er dan nog extra bebording oid gebruikt werd (naast het stootblok).
Zoals al aangegeven komen de (uitrij) seinen nog. Denk wel dat ik voor lichtseinen ga, waren in periode 3b naar mijn info al op diverse baanvakken aanwezig.
« Laatst bewerkt op: 27 November 2018, 08:22:43 door Frank 123 »
Am Ende der Strecke
Martin Hornis
Re: Bröckenbahn
« Reactie #400 Gepost op: 27 November 2018, 12:53:21 »
Lang gedupt maar toch maar besloten om voor lichtseinen te gaan. Waren periode 3b al ruimschoots te vinden en past ook beter bij de elektrische wisselaandrijving....
Dat wordt interessant. Vorige week was ik bij de modelbeurs in Veendam. Daar waren een paar treinbanen met seinen, die voortdurend op groen stonden...
Märklin K-rails met boogstralen > 500 mm; NS-lichtseinen met cijferbak: 4, 6 en 8 in één bak; iTrain; Intellibox I; OC32;
eigen treindetectiesysteem aangesloten op OC32;
controleprogramma voor OC32.
  • Forummoderator
Re: Bröckenbahn
« Reactie #401 Gepost op: 27 November 2018, 13:51:12 »
Nee, afgezien van het reguliere zwart-met-witte bordje op het stootblok niets aparts.
Soms werd het resterende spoor voor het gemak in het midden van de tunnel gelegd, maar vaak ook niet. Tussen Gerolstein en Trier (Eifelbahn) heb je een dubbelsporige tunnel waar nu enkelspoor door loopt èn een fietspad :)
Reinout
Re: Bröckenbahn
« Reactie #402 Gepost op: 28 November 2018, 20:11:32 »
Dat was niet de planning... maar volgens mij ook te voorkomen door het goed te programmeren in de treinbesturingssoftware. Zouden alleen formeel uitreisienen moeten worden, denk alleen dat ik dan rangeersstand (dus Hp0 icm Sh1) niet vaak zal gebruiken.
Am Ende der Strecke
Re: Bröckenbahn
« Reactie #403 Gepost op: 09 December 2018, 10:18:10 »
Ivm verjaardag Houten overgeslagen maar er was wel een tripje naar modelspoorwinkel gepland..
Aldaar nodige rails ingeslagen zodat ik eindelijk eens aan schaduwstation (en 2e keerlus) ga beginnen.
Daarnaast nog gesloten goederen wagon met sluitverlichting.
Vandaag mooie dag om maar meteen met de bouw te starten. Nog geen tujdsplanning maar hoop einde van de winter weer “rond” te kunnen rijden.
Am Ende der Strecke
Re: Bröckenbahn
« Reactie #404 Gepost op: 09 December 2018, 16:32:27 »
Helling naar schaduwstation is klaar. Houtwerk voor keerlus die aan andere kant komt ook..
Deze moet met houtwerk voor het station eerst passend gemaakt worden onder de baan. Dan weer los om op de grond de rails aan te leggen. Daarna wil ik alle in een keer op zijn plaats hangen. Zal niet meevallen maar is engige manier om deze extra laag onder de baan te maken. :(
Am Ende der Strecke
