07 October 2025, 23:55:21
info gezocht over ETS aandrijfunits door Tom Z.
07 October 2025, 23:18:42
Piko NS 5/600 Hippel 2025 door D_Loc
07 October 2025, 22:44:40
Show je werkplek door neudalhausenstadbahn
07 October 2025, 22:44:01
LS Models/Lemke CityNightLine samenstelling?? door jeremy23
07 October 2025, 22:39:36
Fleischmann rijtuig 5896 door grossraumwagen
07 October 2025, 22:25:06
Bouw spoor nul modulebaan, Bahnhof Königshofen, tijdperk III door bernhard67
07 October 2025, 22:21:51
Tankinstallaties voor dieseltreinen door Benelux795
07 October 2025, 22:08:18
07 October 2025, 21:46:54
07 October 2025, 21:43:55
MODELSPOOR by MTD - 2025 - 18 & 19 oktober 2025 in Edegem (B) door BrightonBelle
07 October 2025, 21:33:43
Beneluxspoor Forum Modulebaan is te zien bij Carmeliet op stoom in 2025. door Dick55
07 October 2025, 21:19:00
Pfarrerwinkel bahn door Paul1969
07 October 2025, 20:56:45
Märklin 2025 door barry1972
07 October 2025, 20:24:34
extra terugmeld module viessmann 5217 door Kolho005
07 October 2025, 20:09:10
Franse lantaarnijzers in 1:87 gezocht door Rob Ellerman
07 October 2025, 19:36:28
C12c rijtuig door Eelco Storm
07 October 2025, 19:35:38
Roco wagon openen door Herb73
07 October 2025, 19:33:02
Rondje door Lissabon met Lijn 28 door Wim1969
07 October 2025, 19:19:04
De bouw van mijn modelbaan in Thailand door Eric B
07 October 2025, 19:09:01
waterwagens door j.ossebaar
07 October 2025, 18:34:55
slechte stroomafname bij ROCO RH310 7120013 door Klaas Zondervan
07 October 2025, 17:10:31
07 October 2025, 16:49:12
07 October 2025, 16:47:15
't Boemeltje door RobVille
07 October 2025, 16:23:34
Big Scale Trains - NS SLT in H0 door Pauldg
07 October 2025, 15:33:53
07 October 2025, 14:55:36
07 October 2025, 13:44:42
07 October 2025, 13:35:20
Ik ben aan het opruimen. door hervé
07 October 2025, 13:33:31
Auteur Topic: Nederlandse AHOB in H0  (gelezen 36727 keer)
    • Het Groterdam Project
Re: Nederlandse AHOB in H0
« Reactie #75 Gepost op: 31 October 2007, 13:56:18 »
Zie schakeling, wie wil mij helpen ?
« Reactie #76 Gepost op: 31 October 2007, 13:59:32 »
Komt op hetzelfde neer Chris. Er is alleen gebruik gemaakt van een IC in plaats van transistoren met als nadeel dat je maar weer aan een lagere spanning moet zien te komen.
« Reactie #77 Gepost op: 31 October 2007, 14:01:06 »
onderkant
« Laatst bewerkt op: 31 October 2007, 14:12:49 door Chris van Diesen »
« Reactie #78 Gepost op: 31 October 2007, 14:12:25 »
Keurig op de juiste hoogte van het Preisertje, zo te zien.
Mooi hoor. Wat kost de AHOB ongeveer?
« Reactie #79 Gepost op: 31 October 2007, 14:13:09 »
€ 47,95
is au, maar wel fraai.
« Reactie #80 Gepost op: 31 October 2007, 14:16:36 »
Hm, zo te zien alterneren de leds door om te polen.  :( Dan gaat het schakelingetje van Busch niet werken.
Mooi ding trouwens.
  • Huiskat van Benelux en vriend van de Biljettencentrale.
  • Hengelooo 1:160
« Reactie #81 Gepost op: 31 October 2007, 14:21:35 »
€ 47,95
Per 2 bomen neem ik aan? Anders heb je een HAHOB.....
MRP_Peter
« Reactie #82 Gepost op: 31 October 2007, 14:26:50 »
Het schakelingetje van Chris is nog iets simpeler te realiseren.
Deze schakeling is gebaseerd op een SR-flipflop principe in vrijloop modus, oftewel een a-stabiele multi vibrator, opgebouwd met NEN-poorten.
Nu zijn er IC'tjes die dit standaard al in zich hebben, de HCF/HEF 4047 is zo'n IC.
Door middel van een enkele C en R is de tijd van deze a-stabiele multivibrator in te stellen.
Als je meer info wilt Chris zal ik het interne schema van de 4047 even scannen en hier neerzetten.
@Henk:
Deze schakeling werkt niet volgens ompoolprincipe.
Er komt beurtelings alleen een '1' of een '0' op de uitgangen te staan, oftewel...wel of geen spanning.
Peter.
« Reactie #83 Gepost op: 31 October 2007, 14:34:54 »
Als dat zo is, waarom heeft de AHOB dan maar twee aansluitingen? Het kan toch niet de bedoeling zijn dat alle leds tegelijk aan en uit gaan.
Of is de hele paal de derde aansluiting.
Chris?
« Laatst bewerkt op: 31 October 2007, 14:39:42 door henk »
« Reactie #84 Gepost op: 31 October 2007, 14:36:30 »
@Peter : Altijd handig  :)
@ Mispoes, Nope, dus 2 x 47 euro uitgegeven.
  • Hengelooo 1:160
« Reactie #85 Gepost op: 31 October 2007, 14:39:31 »
Dan is het inderdaad au.  :(
Spoorrelais
« Reactie #86 Gepost op: 31 October 2007, 16:13:23 »
Bij een Ahob is de afstand tussen weg en onderkant boom tussen de 95 cm en 1,05 meter. Dat is dus geen borsthoogte.
stig
« Reactie #87 Gepost op: 31 October 2007, 16:15:48 »
Ik vind het niet duur hoor voor zo'n kunststukje. Je mag in je handjes knijpen dat je het niet zelf hoeft te maken als je denkt dat je dat niet gaat lukken...
sneek
« Reactie #88 Gepost op: 31 October 2007, 17:18:11 »
Is de mast nu nog hoger dan het dak van de 1600 of lijkt dat op de foto zo? Ik heb ze zien liggen op Eurospoor en de palen kwamen mij aardig lang over....
Reinier Z.
« Reactie #89 Gepost op: 31 October 2007, 18:37:20 »
Hier een plaatje van een echte 1600 met AHOB:
http://www.trafficlinq.nl/findpictures/details.php?image_id=96&mode=1
Vergeet niet dat het voetje van de Ahob nog weggewerkt moet worden en dat de loc op de rails moet staan, dan kan je pas goed vergelijken.
Ik heb zelf het idee dat de lampen wat te hoog zitten, maar dat kan ook gezichtsbedrog zijn. De model-Ahob heeft een rood-witte paal, terwijl moderne ahobs een grijze hebben, dat kan de totaalindruk een beetje beinvloeden.
Verder een mooie ahob hoor. Veel strakker dan je doorgaans ziet.
Reinier
