EifelBurgenBahn door Eric B
Vandaag om 07:03:36
Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: Toon hier je nieuwe (model-) spooraanwinst(en)...  (gelezen 8046045 keer)
dh3201
« Reactie #2430 Gepost op: 22 December 2015, 17:54:09 »
Ja, geweldig dat je deze gevonden hebt, moet hem dus omnummeren naar 217 002-5.  Moet lukken. Bedankt, ik kwam alleen maar modellen tegen.
En wat raampjes en roostertjes verplaatsen....  ::) ;D
iarnrod
  • Is fada an bĂłthar nach mbionn casadh ann
« Reactie #2431 Gepost op: 22 December 2015, 18:05:42 »
Bij deze heb ik mijn twijfels, ga nog eens goed uitzoeken of deze uitvoering daadwerkelijk bestaat / heeft bestaan.
Van de BR 215 in TEE kleuren vind ik voorlopig niks terug.
Wel es tijdens een treinsafari met de BR218 in Dubbeltraktie in een EC meegereist van Lindau - Kempten - Munchen
Misschien es in deze ompimpen:
https://www.youtube.com/watch?v=WPy7qVym4SQ
https://www.youtube.com/watch?v=H_x81ENDzWE
http://www.78er.de/BIM/BIM0908/09082/09083/09084/09085/217002-lssTEE-Lauda-20090725-UdoPlischewski-apkl.jpg
Nog niet met deze nummering tegengekomen: http://img18.imageshack.us/img18/4982/dia75176.jpg
gr, Jan
« Laatst bewerkt op: 22 December 2015, 18:19:43 door iarnrod »
V200-G2000
    • Richie's homepage
« Reactie #2432 Gepost op: 22 December 2015, 18:10:29 »
Binnen 2 weken zelfde type locjes op Ebay gekocht van 2 verschillende aanbieders. De eerste als nieuw, zogenaamd vitrine model, analoog.
De tweede kwam vandaag binnen. Gebruikt, digitaal, defect, zogenaamd 'Bastlerschrott'. Maar de behuizing is als nieuw. Of de decoder ook defect is weet ik nog niet, analoog rijdt hij in iedergeval niet, lampjes branden wel. Dat moet nog verder onderzocht worden. Maar voor 78 euro heb ik het risico wel genomen. Ik kan in iedergeval vergelijken met een werkend model, de binnenkant is verder hetzelfde als bovenstaande.
BaRo
« Reactie #2433 Gepost op: 22 December 2015, 18:36:08 »
Via Marktplaats een SNCF Y51100 met een wagonnetje.
  • Team Beurzen en PR
  • Lid MSG Haarlemmermeer
« Reactie #2434 Gepost op: 22 December 2015, 21:02:39 »
De blauwe NS 1200 van roco heeft ook mijn baan bereikt:
Rechts de versie van Märklin/Trix even als vergelijk.
Vr. groeten,
Bob
Afgelopen
« Reactie #2435 Gepost op: 22 December 2015, 22:08:14 »
Zo ver wil ik niet gaan, valt trouwens best mee en omdat ik een fantasiebaan heb is dat ook niet zo belangrijk. Wel leuk dat ik nu ook foto's en filmpjes heb van het voorbeeld en de bijpassende wagons kan opzoeken.
  • Michel
  • low-budget modelbouwer
    • Rangeerbanen
« Reactie #2436 Gepost op: 23 December 2015, 11:41:06 »
Met zo'n lokje kan je leuke dingen doen. Al racen ze wel over de baan.
@Bob: Weet jij of Roco ook met een 2700 uitkomt?  ;)
« Laatst bewerkt op: 23 December 2015, 11:42:52 door tothebeach »
  • Duitsland TP III/IV
« Reactie #2437 Gepost op: 23 December 2015, 12:06:48 »
Overgenomen van een Forumlid(naoorlogsNS), waarvoor dank. Was naar deze al geruime tijd op zoek.
NS Bc 7011.
NS Bc 7015
Grt, Ronald.
« Laatst bewerkt op: 23 December 2015, 12:55:43 door Ronald69 »
Grt, Ronald.
V200-G2000
    • Richie's homepage
« Reactie #2438 Gepost op: 23 December 2015, 20:27:27 »
Inmiddels verder onderzocht. Er zit niet meer de originele motor in, maar een kleiner opengewerkt model geplakt op twee stukje hout. Ik mijn oude Fleischmann trafo (ja die met een groene behuizing en rode knop) uit de mottenballen gehaald, ampere meter ertussen en de motor vraagt zo'n 1,5 ampere en dan nog moet je hem een draai met de hand geven voordat hij gaat draaien.
Dus eerst maar eens een originele motor bestellen.
« Reactie #2439 Gepost op: 23 December 2015, 20:35:39 »
Nummervariant nummer 10 van de Lima SJ flisvagnar gevonden.
Mvh Steef
  • Schwarzburg-Neuffen-Bahn
« Reactie #2440 Gepost op: 23 December 2015, 21:38:47 »
Wat een leuk oud spul. Heb ik heeeel lang geleden ook gehad, van Jouef. Is dit ook Jouef? Die typisch Franse dubbeldeksautotransporter op de achtergrond is ook gaaf. Wordt binnenkort opnieuw uitgebracht door Makette.
DV modelspoor
    • DV modelspoor
« Reactie #2441 Gepost op: 23 December 2015, 21:50:16 »
Mijn kolentrein van ±40 bakken heeft eindelijk een passende trekkracht (y)
En voor het idee met een deel van zijn toekomstige aanhangsels
Blij mee, nu nog eens kijken wanneer ik de complete trein kan uitlaten ;D
Voorheen NaoorlogsNS, naam aangepast nu gelijk aan Instagram account!
https://www.instagram.com/dvmodelspoor/
BaRo
« Reactie #2442 Gepost op: 23 December 2015, 22:10:04 »
Ja, oude Jouef. Ik heb 6 van die zwarte dubbeldekkers beladen met de Jouef autootjes in de versie met 'witte bandjes'. Helaas iets te weinig Citroen DS erop: die sneuvelden blijkbaar het eerst. Dat van Makette ga ik volgen.
Herbert Krijnen
  • (Her-)Intreder
« Reactie #2443 Gepost op: 23 December 2015, 22:12:14 »
Als Ruud niet gereageerd had, was dit niet geplaatst  ;D
Nieuwe aanwinst: Fleischmann BR64, naar schatting 30 jaar oud, was nog met lampjes met schroeffittingen en natuurlijk zonder diodes (maar nu met LOPI en led) en JAWEL een trein van 50 jaar oude JOUEF wagens!
MM, Tillig, oud materieel. Nederland, Ep IIIa (probeer ik)
Robert E
    • Robert’s Modelspoor Pagina
« Reactie #2444 Gepost op: 23 December 2015, 22:34:17 »
Roco Hippel
en Piko 189-er. Staat wel eens in Blerick.
Groet
Robert
MDRRC-II (Lite) goedkope DIY centrale voor DCC en MM.
Heb je een vraag, stuur me dan een mail via mijn site ipv persoonlijk bericht...
