Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: NS 6000 (in schaal 0)  (gelezen 184093 keer)
    • nulpunt
Re: NS 6000 (in schaal 0)
« Reactie #615 Gepost op: 16 November 2022, 16:27:00 »
Test 5:
Hetzelfde materiaal (Anycubic), maar dan op een onderdeel van 4x17 mm met hele kleine details.
Voor...
Kort stralen,
(te) Lang stralen (1 minuut). Het kan dus kapot  ;D
« Laatst bewerkt op: 16 November 2022, 20:45:42 door FritsT »
    • nulpunt
« Reactie #616 Gepost op: 16 November 2022, 16:33:08 »
Conclusie:
Plastic zandstralen kan, maar het is afhankelijk van de plastic. Dus meer printen dan dat je nodig hebt en vooraf goed testen met druk en tijdsduur.
Haal je alle printlaagjes weg zonder dat je kleine delen benadeeld? NEE.
Maar het is wel een manier om een gladder moedermodel voor het gieten te krijgen......
De Microblaster / Air Eraser kan je bij HBM kopen.
https://www.hbm-machines.com/nl/p/hbm-bd-178-airbrush-verfverwijderaar-straalpistool?_gl=1*nq4tfd*_up*MQ..&gclid=EAIaIQobChMI4s-j24Kz-wIVrYKDBx32OAYOEAAYASAAEgKKifD_BwE
« Laatst bewerkt op: 16 November 2022, 16:39:02 door FritsT »
    • nulpunt
« Reactie #617 Gepost op: 16 November 2022, 17:18:54 »
Ik kon het niet laten liggen tot vanavond....
  • Team Mitropa
« Reactie #618 Gepost op: 16 November 2022, 17:52:58 »
Perfect dat je het hebt uitgeprobeerd en het knapt er wel van op (y)
Die buffers zijn echt mooi geworden .
    • nulpunt
« Reactie #619 Gepost op: 16 November 2022, 18:55:29 »
In de buffersteel hebben we een priempje voor een boorgat aangebracht. Een draadje 0,4/0,5 er doorheen en ombuigen volstaat om de steel te verankeren, maar het kan ook met een M-06 boutje. (0,8 kan ook)  Hoe netjes wil je het hebben...
Pijpsleuteltjes in diverse maten bij Knupfer. Bestel dan ook de boutjes en moertjes daar want die van GHW wijken soms iets af en dan draait alles rond. Knupfer hoort bij Knupfer.
« Laatst bewerkt op: 16 November 2022, 20:39:27 door FritsT »
    • nulpunt
« Reactie #620 Gepost op: 17 November 2022, 11:20:52 »
Nog wat kleine werkzaamheden:
1. De Pyrometer. (= thermometer in het hoge bereik.)
Gietstukje waarin ik een buisje 0,4/0,6 heb gesoldeerd. Daar kan een 0,3 draad  (de leiding naar machinistenhuis) in worden gestoken.
2. Inspectieluiken op watertank en hijsogen.
Al eerder besproken, nu gemaakt.
De hijsogen zijn gelijk aan die op het dak. In VS.2 worden alleen deze twee een maatje kleiner.  De luiken zitten nu ook op de etsplaat.
GHW imitatiebouten art 355580 SW 0,8 Schaft 0,4
« Laatst bewerkt op: 17 November 2022, 11:26:28 door FritsT »
    • nulpunt
« Reactie #621 Gepost op: 17 November 2022, 21:06:34 »
Het laatste (?) item, de blazer. De appendages gisteren als gietdeel binnen gekregen en nu mooi de tijd om die te monteren.
Vanuit het machnistenhuis een draaistang en vanaf de afsluiter een leiding naar de zijkant van de rookkast.
Draad in vorm buigen en tijdelijk vastzetten om te positioneren voor de klemmetjes.
Gaatjes 0,5 in 2mm dik materiaal...boorkolom. Dat doe ik niet meer met de hand, brekie brekie.
Het laatst (?) geboorde gat van dit project ?
Dit moet het worden. Aan te brengen na het spuiten.
Maar alles natuurlijk wel even tijdelijk in elkaar zetten.
 :D :D :D :D KLAAR  :D :D :D :D :D
54268
    • nulpunt
« Reactie #622 Gepost op: 17 November 2022, 21:25:36 »
Uit de etsplaat Vs.1. is de lok dus al goed te bouwen. Ik (en Edwin met handmonster 2) heb eigenlijk nergens concessies hoeven te doen. Kleine aanpassingen daargelaten. De basis was gewoon goed.
Vanuit deze lok (SS-1200) is het nu zover dat de verdere ontwikkeling naar de NS-6000 gemaakt gaat worden, maar dat is niets anders dan nog meer gietdelen maken en documenteren en daar zijn we al een heel eind mee op weg. Alle mutaties uit Vs.1. zijn al in Vs.2. verwerkt.
Eigenlijk zijn we nu zo ver dat we de bestelling voor de etsplaten Vs.2 in Spoor-0 en Spoor-1 op korte termijn gaan doen.
Dus als het is gaan kriebelen...................
  • Team Mitropa
« Reactie #623 Gepost op: 17 November 2022, 23:54:25 »
gefeliciteerd met het prachtige eindresultaat  (y)
Even 42 bladzijden doorgenomen en ik kom dit tegen als onmisbare materialen.
knupfer:
boutjes
0,6x2
0,6x3
0,8x2
 1x8
 1x10
1,4x10
 2x10
onderlegplaatjes 1 mm
moertjes 0,6  0,8  1   1,4  2
pijpsleutels  0,6  0,8  1
wielen Slaters
7951S 3x
7951m 1x (Frits ?)
7872 3x
7837GP 4x
7960B 4x hornbloks
9B40L  1x gearbox
klinknagels Hasler
M97 frame  M98 draaistel  M99dak
plaatmateriaal
0,3  0,4  0,5  en 2 mm (2 mm Amazon is goedkoop 100x 200  eu 16,45)
albion
Div soorten buis , draad en strip
gewoon elke maat kopen
en fosforbrons voor stroomafnemers
halfrond strip 20 G = 0,8 ( ik heb het bij Etsy op de site gevonden, komt wel uit Amerika)
zachte buis 3mm (waar heb je dat vandaan Frits ?)
Bavaria 0,1 mm gaas
profielen
1x1 vierkant massief
1x1 L
1,5x1,5 L
2x2L
3x3L
5x3L
4x12 L
0,2 x 1,5 strip
0,2x4 strip
0,3 strip
0,5 strip
1x1 U
2x2 U
HBM
messingstaf 12 mm massief voor vonkenvanger rookkast
Hoogtemeter
En alles wat er nog meer in je mandje verdwijnt  (y)
Gietdelen Bauer
6061 scharnieren
3042 luchtslang
3505 steuerventiel
607 en 608 handrailhouders
Drijfhout
komet slijpschijfjes 0,3
Bijou moderne
draadtappers 0,6  0,8 1 1,4
Gr Jan
« Laatst bewerkt op: 19 November 2022, 08:00:07 door roadster36 »
    • nulpunt
« Reactie #624 Gepost op: 18 November 2022, 16:05:11 »
De loc heeft gelopen en rijdt door een Peco wissel, maar het is allemaal wel krap aan. Dus ik ben gaan kijken of er aanpassingen te doen zijn. Het is en blijft een handmonster om te testen.
De "draagkoppen" van het verenpakket van de bogie loopt bij mijn model net niet, maar dan ook net niet tegen het frame. Frame verder naar boven insnijden is een optie, maar dat zie je. Ik ben dus aan het slopen gegaan .....
De koppen van het gietdeel verwijderd.......veel veilger
Ook dan heeft de bogie nog niet de gewenste uitslag want het verenpakket op de 2e as stuit tegen de leibaan.
Afslijpen, rond maken.....zet geen zoden aan de dijk. Weghalen wel.
Maar niet alles mag weg. Er moet een klein stukje met "pieleke" overblijven om het veertje te ondersteunen.
Dan is er ineens ruimte en schuift dat restje gietdeel keurig onder de leibaan door.
Hoe storend is het (zie je het eigenlijk nog wel ? ) dat er geen verenpakket meer zit.?
En dan is er ineens de gewenste grotere uitslag en geen contact meer met het frame.
Slopen is toch wel handig ;D en het is maar op 1 as. Als dat nou een van de weinige concessies is, dan vind ik het best.
BeLu
« Reactie #625 Gepost op: 18 November 2022, 18:57:32 »
Frits,
Ik heb de bouw grotendeels gevolgd onder het zelf bouwen van van alles en nog wat. Het inspireerde me ook bij het oplossen van veel technische problemen. Hulde voor dit resultaat!
Wat een onderzoek, werk, evaluatie en dan de bouw zelf. Grote complimenten, ook voor het hele bouwteam uiteraard.
Bert
    • nulpunt
« Reactie #626 Gepost op: 18 November 2022, 19:22:22 »
 (y)
    • Raamsdonk spoor 0
« Reactie #627 Gepost op: 18 November 2022, 19:54:56 »
Het is zover, de eerste tekeningen zijn klaar, de vraag is, wiel heeft er interesse om mee te doen / een (super) SS1200/NS6000 te gaan bouwen met deze etsplaten???   Komt er in spoor 0, kort en lange versie waterkasten, in spoor 1 (voorlopig?) alleen met lange.
Kosten kan ik pas met zekerheid zeggen als ik de rekening heb van de etser, maar gaat zeker tussen de 600 en 1000 komen.
graag via pb.
Edwin
  • Team Mitropa
« Reactie #628 Gepost op: 18 November 2022, 21:10:40 »
yup pb verstuurd
SS korte waterkast en lazer frame  (y)
    • Raamsdonk spoor 0
« Reactie #629 Gepost op: 19 November 2022, 13:38:23 »
Nog een opmerking,  ondanks de zeer riante en goed gevulde werkplaats van Frits, is deze lok, ets en laser platen set, ook te bouwen zonder gebruik makend van draaibank , freesbank.
Eigenlijk heb je niet meer nodig dan een soldeerbout en brander, boormachine,  ruime hoeveelheid boortjes, en het standaard gereedschap.   Knip en rolbank is wel makkelijk.
Edwin
