14 January 2026, 23:48:20
Les Billards du Vivarais
JeanR
14 January 2026, 23:37:38
Ronald A.
14 January 2026, 23:35:27
Dennis1984
14 January 2026, 23:24:12
eitreb
14 January 2026, 23:21:36
14 January 2026, 23:20:09
14 January 2026, 23:08:48
Tram groefrail
14 January 2026, 23:03:56
eitreb
14 January 2026, 22:40:13
14 January 2026, 22:20:15
Bert Jolink
14 January 2026, 22:20:14
Jeroen Water
14 January 2026, 22:13:33
Hlv53
14 January 2026, 21:42:11
14 January 2026, 21:38:18
mamory
14 January 2026, 21:20:26
14 January 2026, 20:16:49
Maartenw
14 January 2026, 20:07:34
14 January 2026, 19:55:44
14 January 2026, 19:53:29
14 January 2026, 19:37:58
Frans loodsje et cetera
Noordernet
14 January 2026, 19:32:58
14 January 2026, 18:56:03
14 January 2026, 18:39:58
14 January 2026, 17:59:02
Once upon a time...
14 January 2026, 17:48:03
Een leuke vrachtwagen
14 January 2026, 17:34:55
Martijnstein
14 January 2026, 17:17:03
14 January 2026, 16:51:15
14 January 2026, 16:49:53
14 January 2026, 15:12:58
liliput L131002 BR75 HO digitaal werkt verlichting niet
Topic: liliput L131002 BR75 HO digitaal werkt verlichting niet (gelezen 1695 keer)
matrix
Nieuwe gebruiker
18 October 2011, 00:40:53 »
ESU decoder geplaatst testen, en lok loopt achteruit i.pv. vooruit en geen verlichting.
snelheids stappen op 14 gezet 0 resultaat, motor omgepoold via decoder 0 resultaat.
Wat nu ? print doormeten motor en stroom afnemers rechts zat links dus veranderd
Test 0 resultaat. wat nu help me
groeten matrix
Karst Drenth
Re:liliput L131002 BR75 HO digitaal werkt verlichting niet
18 October 2011, 01:38:18 »
Als het een 8-polige decoder is, stekker 180' draaien.
Grtzz,
Karst
Hans sprinter
Vriend van vlaflip
18 October 2011, 08:28:37 »
Citaat van: matrix op 18 October 2011, 00:40:53
En uiteraard je veranderingen weer ongedaan maken.....
matrix
Nieuwe gebruiker
18 October 2011, 22:39:44 »
Karst en Hans bedankt voor de tip, maar helaas motor werkt verlichting niet.
bedankt voor de moeite groeten matix
phdirk
21 October 2011, 17:24:41 »
Hallo Matrix,
Als je er een andere decoder inzet, werkt het dan wel? Het lijkt namelijk een beetje op een gedeeltelijk overleden decoder. Dat kun je echt vaststellen als je er een andere decoder inzet.
Een andere mogelijkheid kan nog zijn dat de lampen gedeeltelijk via het frame worden gevoed en dat het frame ook contact maakt met de negatieve pool van de stroomafnamen. Dan heb je bij digitaal rijden een probleem. De stroomvoorziening van de lampen moet namelijk volledig geïsoleerd zijn van de stroomafname.
Met beste groeten,
Dirk Meijer
MartOnTheWeb
21 October 2011, 19:15:49 »
Hallo Matrix,
heb je de decoder ook al in een andere locomotief getest. Ik had in 2009 ook problemen met een Liliput treinstel, toen bleek dat de bedrading vanaf de stekkerinterface naar de motor niet correct was.
Zie het draadje
http://forum.beneluxspoor.net/index.php/topic,6762.0.html
Su6
Mart
matrix
Nieuwe gebruiker
21 October 2011, 19:53:10 »
Best Dirk en Mart bedankt voor de tips maar de decoder is perfekt namelijk getest met de
esu decoder tester
