Spoorwegmuseum in zwaar weer door Marty
Vandaag om 02:22:21
Baanplan naar oud plan Fleischmann 4306 door Peter J K
Vandaag om 01:25:33
Vandaag om 01:09:05
Vandaag om 00:12:33
14 February 2026, 23:59:00
14 February 2026, 23:28:46
14 February 2026, 23:23:18
14 February 2026, 23:19:17
14 February 2026, 23:15:05
De schakelstations van Sleutelspoor gebouwd door Casmir
14 February 2026, 23:05:45
14 February 2026, 23:04:11
14 February 2026, 22:33:37
14 February 2026, 22:27:45
14 February 2026, 22:24:12
14 February 2026, 21:58:41
Het oude station Blaak in H0 1970 - 1993 door Jeroen95
14 February 2026, 21:54:37
14 February 2026, 21:30:58
14 February 2026, 21:29:32
14 February 2026, 21:22:51
19 Toen door GerardvV
14 February 2026, 21:21:52
14 February 2026, 21:21:34
14 February 2026, 21:08:27
14 February 2026, 21:02:15
14 February 2026, 20:59:53
servo aansturing door Henk G
14 February 2026, 20:47:09
14 February 2026, 20:33:30
14 February 2026, 20:16:33
14 February 2026, 18:48:27
14 February 2026, 18:48:02
14 February 2026, 18:38:09
Auteur Topic: Young meets old  (gelezen 3223 keer)
ivk
Young meets old
« Gepost op: 05 September 2011, 14:08:58 »
Ik werd geattendeerd op het volgende filmpje: Young meets old.
Leuk om te zien dat jong en oud elkaar óók in het groot tegen komen.
Jes
    • Gebeurt er nog wat in Tiel?
Re:Young meets old
« Reactie #1 Gepost op: 05 September 2011, 14:21:53 »
met vriendelijke groet, Jesse
NS-Reiziger
Re:Young meets old
« Reactie #2 Gepost op: 05 September 2011, 14:23:37 »
Leuk filmpje, alleen zitten er twee fouten in de link.
Zo, klik, doet ie het wel.
:edit: ...en Jes was mij dus net voor. (y)
Vriendelijke groet,
Keesjan
Jan-Peter
  • Bnlx treinendokter.
Re:Young meets old
« Reactie #3 Gepost op: 05 September 2011, 21:54:19 »
Heren,
De stoomlok was overigens nog sneller dan zo'n ICE  ;D
Begin ik oud te worden, of was vroeger alles beter.....  ;)
Jan-Peter
Forever Rocofan
Re:Young meets old
« Reactie #4 Gepost op: 05 September 2011, 22:21:25 »
@ Jan - Peter,
Jammer dat de treinen niet dezelfde kant op reden anders had die ouwe stoomreus er mooi voorbij gedenderd  ;D
Vraag me nu wel af welke van de twee sneller op gang komt vanuit stilstand.....de ICE is wel modern maar ook behoorlijk lang en zwaar.....dus als je de stoomloc met 3 rijtuigen er naast zet en ze vertrekken gelijk.......
Heb het gevoel dat de stoomloc best een eind vooruit zou kunnen sprinten op het eerste stuk.....
Ik ken wat mensen bij de SSN, dus die stoomlok met 3 rijtuigen kan ik wel organiseren, wie regelt de ICE, dan kunnen we het testen. ( geintje )
Groeten Ruud B.
Groeten Ruud B.
Anoniem
Re:Young meets old
« Reactie #5 Gepost op: 05 September 2011, 22:26:01 »
Ja hallo.... een Fiat Panda trekt ook sneller op dan een Lamborghini die een caravan vol lood trekt. Dat is geen vergelijk natuurlijk ;D. Wat je werkelijk wilt weten, is of die stoomloc de ICE er ook uittrekt met 8 rijtuigen aan de haak. En dan is het antwoord meer dan hoogstwaarschijnlijk "nee" ;).
ivk
Re:Young meets old
« Reactie #6 Gepost op: 08 September 2011, 13:21:47 »
De juiste link: http://www.youtube.com/watch?v=rRM2cnZOn3s&feature=youtu.be
Bedankt (y). Als je iets knipt en plakt moet je het natuurlijk wel goed doen :-[.
Jeroen Water
  • NS tijdperk IV (1973/1974)
Re:Young meets old
« Reactie #7 Gepost op: 08 September 2011, 13:50:50 »
Het vergelijk tussen het optrekken van een ICE of een stoomloc gaat sowieso mank, aangezien de ICE-3M geen motorwagen heeft, maar de tractiemotoren over meerdere draaistellen en dus onder een aantal bakken zijn aangebracht.
mmhajvth
  • fulltime busy
  • IC met 1762+1773 op Ht richting Mt op 23-4-06
    • Markenburg
Re:Young meets old
« Reactie #8 Gepost op: 08 September 2011, 13:55:45 »
Dan zorg je toch voor een ICE en 8 stoomloc's?  ;)
m.v.g.
Mark
love to build realistic     let's be kind.
Anoniem
Re:Young meets old
« Reactie #9 Gepost op: 08 September 2011, 13:58:57 »
Nou ja, dat hoeft nog niet mank te gaan. Je kunt een loc (eender welke) met een zooi rijtuigen best naast een ICE 3M zetten en kijken welke er sneller optrekt, juist om de verschillen bloot te leggen. Wat je alleen wèl moet doen, is zorgen voor dezelfde "payload"-capaciteit, in dit geval: hetzelfde aantal reizigers dat je zou kunnen vervoeren in dezelfde omstandigheden. Dus: x zitplaatsen 1e klas, y zitplaatsen 2e klas en een restauratierijtuig compleet met apparatuur. Dan zul je - logischerwijs - op ongeveer 8 rijtuigen uitkomen, en ik ben er nog steeds tamelijk van overtuigd dat de stoomloc dat verliest...
Petertrein81
  • Taurus en Vectron fan!!
Re:Young meets old
« Reactie #10 Gepost op: 08 September 2011, 13:59:48 »
Moet je de test wel eerlijk doen en dan dus in Duitsland, want onder Nederlandse gelijkstroom
wordt de ICE3M behoorlijk geknepen, slechts 4400 kW ipv 8000 kW.
Overigens kan ik je uit persoonlijke ervaring vertellen dat een ICE3 op droge rails onder wisselstroom een aardige 0 tot 100 sprint in de benen heeft.
Ik denk dat de stoomlok zelfs met slechts 3 rijtuigen weinig kans maakt.
Groet Peter,
« Laatst bewerkt op: 08 September 2011, 14:02:51 door Petertrein81 »
Anoniem
Re:Young meets old
« Reactie #11 Gepost op: 08 September 2011, 14:06:43 »
Nee, je kunt die test ook gewoon in Nederland doen, je vraag is immers of de ICE zou winnen onder Nederlandse omstandigheden, niet of-ie zou winnen onder optimale omstandigheden. Bovendien zegt het vermogen niet zo veel over de acceleratie van een voertuig. Vrachtwagens hebben veel meer vermogen dan standaard personenauto's, en toch trek ik altijd alle vrachtwagens eruit bij het stoplicht ;D.
mmhajvth
  • fulltime busy
    • Markenburg
Re:Young meets old
« Reactie #12 Gepost op: 08 September 2011, 14:11:53 »
Hey Wesley,
Heb jij ook een dikke oplegger achter je wagentje hangen dan?
(Om niet mank te gaan natuurlijk  ;))
m.v.g.
Mark
Petertrein81
Re:Young meets old
« Reactie #13 Gepost op: 08 September 2011, 14:14:48 »
Dat zou alleen kloppen als het aanzetkoppel van de ICE onder beide stroomsystemen gelijk is.
Dat maakt voor de stoomlok in ieder geval niet uit, die heeft altijd evenveel koppel, mits er genoeg druk is.
@Wesley, heb je dat ook al eens geprobeerd met een vrachtwagentrekker zonder trailer.
Die trekken je er namelijk dik uit bij het stoplicht met je middenklassertje.
Groet Peter,
Anoniem
Re:Young meets old
« Reactie #14 Gepost op: 08 September 2011, 14:26:36 »
Jongens, nooit het idee van een metafoor meegekregen? Die neem je dus niet letterlijk... ::)
Wat ik aan wilde geven, is dat motorvermogen niets zegt over acceleratie. Daar heb je andere gegevens voor nodig, zoals - inderdaad - het aanzetkoppel. En dát wordt weer bepaald door een groot aantal variabelen, waaronder motorvermogen, maar ook de massa van het voertuig (which is why ik geen enorme oplegger achter mijn Volvo hoef te hangen, noch de truck zijn oplegger hoeft achter te laten...).
