Speedbuild; "Switch'n Play"
om 00:21:32
Dienstregeling IC+
om 00:04:58
janw
08 February 2026, 23:58:41
08 February 2026, 23:48:37
08 February 2026, 23:31:24
08 February 2026, 23:10:23
Roco h0, NS 1200
Duikeend
08 February 2026, 23:08:56
08 February 2026, 23:02:49
Duikeend
08 February 2026, 22:53:13
Peter Kleton
08 February 2026, 22:51:24
08 February 2026, 22:44:04
08 February 2026, 22:15:59
Zermitz
08 February 2026, 22:03:50
08 February 2026, 21:30:36
Carl
08 February 2026, 21:26:30
08 February 2026, 21:17:44
08 February 2026, 21:14:26
08 February 2026, 20:57:44
WesleyMunnik
08 February 2026, 20:50:26
08 February 2026, 20:41:54
Miniature Holland
08 February 2026, 20:40:30
08 February 2026, 20:34:49
CityNightLine 1:1, 1:87, 1:160 en 1:120
08 February 2026, 19:56:09
BrauWelt, fantasiebaan in H0
Brouwersbaan
08 February 2026, 19:52:43
Vitrineplankje
08 February 2026, 19:50:10
08 February 2026, 19:49:35
Wohnzimmer AW werkrapporten
08 February 2026, 19:48:11
Drijfwerk bouten losmaken
08 February 2026, 19:07:42
nighttrain1
08 February 2026, 18:52:36
TonM
08 February 2026, 18:43:55
Modelspoorverenigingen (MSV)
BNLS Litter Bin
Topic: "Litter Bin" voor Brits spoor en Britse modelspoorprojecten (gelezen 3453555 keer)
iarnrod
Is fada an bóthar nach mbionn casadh ann
Reactie #14805 Gepost op:
08 April 2019, 15:43:42 »
Voor de liefhebber:
https://www.2dehands.be/hobby/modelbouw-schaalmodellen/modeltrein/ho-verzameling-rollend-materiaal-british-516860149.html
Wil, indien gewenst, eventueel wel voor postmen spelen.
(Komende zaterdag, op bezoek bij
https://verzamelaarsjaarbeurs.nl/
op de BMB 00 modulebaan:
Over en na de middag)
Gr,
Jan(tje)
Laatst bewerkt op: 09 April 2019, 00:54:30 door iarnrod
St00mboy
Reactie #14806 Gepost op:
08 April 2019, 16:09:38 »
@Jan,
De Verzamelbeurs is a.s. zaterdag 13 april, niet volgende week zaterdag hoor.
Leen.
iarnrod
Reactie #14807 Gepost op:
09 April 2019, 00:57:57 »
Oeps. Foutje. (Heb je met een aantal opeenvolgende weekends te moeten werken: Je begint de ene week te werken en je krijgt de vrije dagen in het midden van de daaropvolgende week...)
Hopelijks tot zaterdag!
Gr,
Jan(tje)
Sjoerd van de Wal
Reactie #14808 Gepost op:
10 April 2019, 20:29:36 »
Zojuist, na bijna 2 jaar geduld hebben, eindelijk het bericht gekregen dat mijn J70 van modelrailoffers uitgeleverd is.
Dus nog een paar dagen geduld hebben en in de gang wachten.....
Ben heel benieuwd, nu de rijtuigen maar eens bij mijn vader lospeuteren.
Knutselt thuis aan een Britse fantasie baan ergens in Yorkshire midden jaren 30.
St00mboy
Reactie #14809 Gepost op:
10 April 2019, 20:32:00 »
Mooi hoor.
Heeft je vader passende rijtuigen?
Leen.
Sjoerd van de Wal
Reactie #14810 Gepost op:
10 April 2019, 20:33:17 »
Dank je Leen,
Ja, hij heeft een brass kit met 2 rijtuigen.
Komend weekend maar eens heel lief aankijken, was al op zoek geweest maar zijn niet meer te vinden.
Dus....
St00mboy
Reactie #14811 Gepost op:
10 April 2019, 20:34:36 »
Dan mag je van geluk spreken, want een passende trein achter een J70 is heel bijzonder.
Leen.
Onshape Gebruikersgroep
Reactie #14812 Gepost op:
10 April 2019, 20:47:48 »
@Sjoerd,
Inderdaad wel een heel bijzondere loc. Hoop hem snel eens in het echt te zien.
Gr, Hans
https://spoormodelleren3d.nl/
Sjoerd van de Wal
Reactie #14813 Gepost op:
10 April 2019, 20:57:56 »
Ach, een sleepje ventilated vans of mineral trucks kan ook nog.
Maar in dit geval vindt ik een passagiers sleep wat leuker.
Waarschijnlijk op de juni rijdag Hans,
Gr.
Sjoerd
Jip
Van alles en niks
Reactie #14814 Gepost op:
12 April 2019, 00:17:25 »
was even afwezig, dank Leen en Hans voor jullie bijdrages. Als het meezit kan ik binnen afzienbare tijd met een stukje treinbaan beginnen. Worden geen modules want ik sleep er toch niet mee.
Hoe ik alles aan ga sturen, ik wil de baan digitaal maken want alle treinen die ik heb zijn voorzien van een decoder en of ik wissels etc verder digitaal wil aansturen daar twijfel ik nog over, neem er de tijd voor want de leercurve vind ik best lastig en ik wil niet overhaasten en fouten maken.
Dus alles op zijn tijd maar dank voor de hulp!
Groet Johanna
St00mboy
Reactie #14815 Gepost op:
12 April 2019, 18:34:31 »
Dat is de juiste aanpak!
Gewoon rustig een beeld vormen en uitproberen wat je het beste denkt te vinden.
Er zijn meer wegen die naar Rome leiden.
We staan dit weekend met onze Britse modulebaan in Hal 7 in de Jaarbeurs dus kom gerust langs als je zin hebt:
https://forum.beneluxspoor.net/index.php?topic=64485.msg3222026171#msg3222026171
Dit geldt uiteraard voor alle Litter Binners.
Leen.
Laatst bewerkt op: 12 April 2019, 20:55:15 door St00mboy
Reactie #14816 Gepost op:
15 April 2019, 09:29:20 »
Voor liefhebbers van informatie over Brits Modelspoor, kan ik onderstaande links naar de zeer omvangrijke publicaties aanbevelen van LBSCR.org
http://www.lbscr.org/Models/Digest/LBSCR-Modellers-Digest-1.pdf
http://www.lbscr.org/Models/Digest/LBSCR-Modellers-Digest-2.pdf
http://www.lbscr.org/Models/Digest/LBSCR-Modellers-Digest-3.pdf
http://www.lbscr.org/Models/Digest/LBSCR-Modellers-Digest-4.pdf
http://www.lbscr.org/Models/Digest/LBSCR-Modellers-Digest-5.pdf
http://www.lbscr.org/Models/Digest/LBSCR-Modellers-Digest-6.pdf
http://www.lbscr.org/Models/Digest/LBSCR-Modellers-Digest-7.pdf
http://www.lbscr.org/Models/Digest/LBSCR-Modellers-Digest-8.pdf
Gr, Hans
Merlin674
Reactie #14817 Gepost op:
16 April 2019, 21:27:56 »
Het is weer fraai met Hornby. Zit je ik weet niet hoe lang op de nieuwe Lord Nelson Class te wachten. Krijg ik hem vandaag eindelijk binnen en dan mankeert er van alles aan. Ik wilde rijden en hij maakt een ernstig ratelend geluid. Dus, lok open en dan zie je dit...
De motor zit niet goed in zijn houder vastgeklikt waardoor de cardanas scheef zit. Een kleine beweging en de cardanas valt er helemaal uit! Dus motor eruit en opnieuw (nu goed) geplaatst. Vervolgens is de pin waar de left-hand rocker van de motion op draait ook los waardoor de hele motion uit elkaar valt. Dit moet dus ook weer worden vastgezet. Bij het terug bouwen van de lok blijkt nu de kabelverbinding met de tender te kort te zijn waardoor het zooitje wéér uit elkaar moet!
Hornby, bedankt!
Ed
Verzonden vanaf mijn iPad met Tapatalk
Laatst bewerkt op: 16 April 2019, 21:30:29 door Merlin674
St00mboy
Reactie #14818 Gepost op:
17 April 2019, 11:14:21 »
Slordig! En helaas komen zulke dingen te vaak voor.
Hier is duidelijk een echte prutser mee bezig geweest.
Leen.
St00mboy
Reactie #14819 Gepost op:
17 April 2019, 11:16:41 »
We zijn het door de drukte rond de beurs helemaal vergeten, maar de Litter Bin bestond op 1 april 8 jaar.
Ik meen me te herinneren dat ik op 1 april wel een slokje genomen heb. Nou die is dan postuum op onze Litter Bin.
Leen.
BNLS Litter Bin
