Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: Binnenbrandje Rivarossi mat 46  (gelezen 40833 keer)
  • Team Mitropa - OHMB
Re:Binnenbrandje Rivarossi mat 46
« Reactie #15 Gepost op: 24 January 2011, 10:31:14 »
Indien hier inderdaad sprake is van een stukturele klacht, is het verstandig als iedereen die dit defect heeft geconstateerd daarvan melding maakt. Niet om de importeur op de kast te jagen, maar het is met dit soort zaken van belang een goed beeld van de omvang van het probleem te krijgen.
Voor zover ik weet hebben de treinstellen tegenwoordig een serienummer, of anders een code op de verpakking. Noteer dat met aankoopgegevens en geef dat door.
RETROBAHN A.G.
Brabantspoor
« Reactie #16 Gepost op: 24 January 2011, 10:34:53 »
Hopelijk krijg je op korte termijn een nieuw exemplaar,  waar daar heb je wel recht op.
Voor het zelfde geld fikt heel je modelbaan af.
Je kan dit uitgebrandde ding altijd nog in het andere draadje "pimp mijn LimaRossi Mat '46" kwijt
alex1212
  • NS & DB ,mijn "Ok"
« Reactie #17 Gepost op: 24 January 2011, 10:41:19 »
Hallo,,,
Voordat we de importeur helemaal afbranden hiero :-X
1. Weet Overbeek dit al??  ( volgens mij nog niet )
2. Hebben ze er belang bij een ondeugdelijk product op de markt te zetten?? ( niet dus! )
3. Geven we Overbeek eerst eens een kans om dit op te lossen?? ( ja , toch ? )
4. Is dit bericht geplaatst ter info voor medespoorders?? ( dacht het wel )
Jan (y)
Jeroen Water
  • NS tijdperk IV (1973/1974)
« Reactie #18 Gepost op: 24 January 2011, 10:43:36 »
Nieuw exemplaar? Lekker zo'n "gevaarlijk ding" op je baan. Geld terug en een ander mooi model kopen. Je zal maar lekker wat gereden hebben en je stel nietsvermoedend in het schaduwstation weggezet hebben om vervolgens een bak koffie te gaan drinken beneden.....
Je moet er toch echt niet aan denken.
Of doneren aan de bouwer van Mijdrecht.....
Hallo,,,
Jan (y)
En dat lijkt mij ook. Terug naar de winkel met dat ding en laten de andere eigenaren van Rovarossi Mat'46'ers vooralsnog gewaarschuwd en op hun hoede zijn.
alex1212
« Reactie #19 Gepost op: 24 January 2011, 10:55:39 »
Even ter vergelijk..
4 jaar geleden kwam is s'morgens in mijn keuken, ik zie een oranje gloed in mijn AEG kombimagnetron.
Het grillspiraal was spontaan aangegaan..zonder aan het apparaat te zitten,..er stond gewoon spanning op..
hoe lang het heeft aangestaan, heeft weet ik niet, het pak met schocolademuisjes
in het kastje erboven, was reeds gesmolten.
Gelukkig geen brand gehad in mijn slaap !!, wel geschrokken.
Direct de Nederlandse importeur gemaaild, en deze geschreven wat het probleem was.
Binnen twee dagen bezoek gehad van de importeur , en nieuwe combi gekregen.
Oude kapote hebben ze meegenomen voor nader onderzoek.
Deugt dit merk nu voor mij nu niet meer..... jawel hoor, prima A merk.
Mijn Conclusie: dit kan ook met de beste merken gebeuren.
Groet ,jan
JSRail
« Reactie #20 Gepost op: 24 January 2011, 11:08:49 »
Bij het rijden viel het al op dat hij vrij veel vonkte en mede door het slecht rijgedrag door de treeplanken
 Zou het kunnen, doordat het draaistel wordt tegengehouden in scherpe bogen door de treeplanken, weerstand (wamte-ontwikkeling) in de aandrijving en stroomafnemers ontstaat ?  De lastregeling van de decoder zal toch proberen de vaart erin te houden door meer spanning richting aandrijving te sturen, ondanks dat de boel dreigt vast te lopen. Met het gevolg dat de spanning in de (dunne) stroomafnemers wordt omgezet in hitte.  Waardoor de boel in de fik kan vliegen. Nogmaals zou niet moeten mogen natuurlijk !
 Mijn gedachten..
« Reactie #21 Gepost op: 24 January 2011, 11:37:16 »
1. Weet Overbeek dit al?? Daarom moet je die informeren, maar wel via/ in overleg met je winkelier: daarmee heb je een koopovereenkomst wat hem verantwoordelijk maakt voor de staat van het geleverde produkt
Dat was ook helemaal niet de discussie, het gaat alleen om de kwaliteit van het treinstel zelf.
Zie mijn opmerking bij 1.
Ja, plus het advies melding te maken van elk ander treinstel met dezelfde klacht.
Voor het overige zou ik afwachten wat Jurgen met zijn winkelier overeenkomt.
Bessel
RETROBAHN A.G.
JurgeN65
  • Nieuwe gebruiker
« Reactie #22 Gepost op: 24 January 2011, 20:02:30 »
Ik heb nog een detailfoto gemaakt van het aangetaste deel. Opvallend is het losse draadje, die ik aan de andere kant overigens ook zie zitten (weet niet of dit het betreffende draadje is/was):
en van de zijkant:
Iedereen overigens heel erg bedankt voor alle reacties, hier kan ik wel wat mee.
JurgeN
JurgeN65
  • Nieuwe gebruiker
Re:Binnenbrandje Rivarossi mat 64
« Reactie #23 Gepost op: 24 January 2011, 20:03:20 »
werkt de booster beveiliging goed?
Het is een kale ESU rechstreeks op de baan aangesloten...
JurgeN65
  • Nieuwe gebruiker
« Reactie #24 Gepost op: 24 January 2011, 20:04:56 »
Bessel
We hebben vandaag al wel de winkel gebeld, maar die is op maandag gesloten, dus dat wordt morgen
JurgeN
ONR
« Reactie #25 Gepost op: 24 January 2011, 20:34:38 »
Nu is WEL duidelijk waarom we de HOOFDPRIJS moeten betalen voor een Rivarossi:
wat dachten jullie wat de BRANDVERZEKERING kost voor Hornby/Rivarossi/Overbeek?
Uiteraard geen leuke opmerking, maar dit mag toch echt niet gebeuren, stel voor dat het in een schaduw station was gebeurd en je hele baan was afgebrand......moeten we maar niet aan denken.  :-[ :'(
Ben zeer benieuwd wat Overbeek hierover te zeggen heeft.... :-\
  • Nervensäge.
    • belse roestkraam
« Reactie #26 Gepost op: 24 January 2011, 21:33:25 »
JurgeN
dat lijkt me t draadje dat aan de stroomafnemer zat. Als die zo warm is dat ie in de hens vliegt heeft soldeer nogal de neiging om los te gaan.
« Reactie #27 Gepost op: 24 January 2011, 21:41:12 »
Ik zie ook nog een zielig restantje van de stroomafnemer zelf onder de bevestiging uitpiepen.
  • Nervensäge.
    • belse roestkraam
« Reactie #28 Gepost op: 24 January 2011, 21:52:34 »
dat is dan inderdaad hamsterkonthaar zeg... De hele constructie is op zich goed verzonnen, uitvoering is een beetje jammer zo.
Coen Burki
« Reactie #29 Gepost op: 24 January 2011, 22:31:15 »
Beste forumlezers,
Ik vraag me af of de stroomafname bij de Lima uitvoering ook op deze wijze was uitgevoerd. Ik kan dit nu niet nazien omdat ik in het buitenland ben. Het lijkt mij van niet omdat hierover geen gelijke gevallen bekend zijn.Ik heb beide uitvoeringen (Lima zilverbuik met Faulhaber aandrijving en Rivarossi bloedneus ) maar deze liggen uit elkaar om te superen.
Tijdens het proefrijden met het Rivarossi exemplaar - na aanbrengen Lopi - heb ik niets gemerkt en was zeer tevreden over rijkwaliteit.
Nu ik dit lees ga ik de Rivarossi stroomafname zeker wijzigen. Er zullen op dit forum best wel goede oplossingen worden gemeld want wie wil dit risico lopen? Zeker digitaal rijders met constante spanning op de rails.
Nadat ik een keer een ontsporing op een wisselpunt in mijn schaduwstation heb gehad heb ik o.a. al de wisselpunten van een automatische zekering voorzien. Destijds was een geisoleerd wiel deels weggesmolten.
Ik gebruikte toen Lenz versterkers ( 3 amp!!.) welke ik inmiddels heb vervangen door de beter gezekerde Digirail exemplaren.
Sedertdien zet ik als ik niet bij mijn modelbaan ben (bijv.een kopje koffie ga drinken) altijd de baanspanning helemaal uit.
Ik blijf dit draadje uiteraard met aandacht volgen.
Coen.
