NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
Betrouwbare Stroomafname met Trix C-Rail door Floris Dilz
Vandaag om 00:01:16
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
28 January 2026, 19:55:14
Auteur Topic: Roco NS plan V  (gelezen 632204 keer)
Luc2000
Re:Roco plan V NS
« Reactie #180 Gepost op: 11 May 2012, 21:31:06 »
ik vind de afstand tussen de bagagedeur en reizigersdeur erg groot. Welke bedrijfsnummers reden in deze uitvoering?
Daan!
Re:Roco plan V NS
« Reactie #181 Gepost op: 11 May 2012, 21:37:55 »
Vraag is meerdere keren gesteld. Het is handig om even de laatste paar pagina's van draadjes door te lezen. Verder is google en wikipedia your best friend.
Even op google NS V1-V3 intypen bij afbeeldingen en dan heb je de juiste deelserie al te pakken:
Hier de versie zoals Roco hem gaat leveren, begin jaren'70:
Foto: Nico Spilt.
Deze deelserie is ook als enige serie Plan V's in het groen geweest:
Foto: Nico Spilt.
Hier de V1-V3 in de jaren '90, dus met klein raampje in de cabinedeuren:
http://www.flickr.com/photos/siccodierdorp/4957465770/
En hier de V1-V3 met DE reclame. Er waren een aantal stellen voorzien van koffie-automaat en die reden voornamelijk tussen Nijmegen en 's Hertogenbosch:
http://www.flickr.com/photos/siccodierdorp/4957465152/
Dan ook nog maar de V1-V3 na hun verlengingskuur. Hier zie je dat de bagagedeuren vervangen zijn door ramen:
http://farm7.staticflickr.com/6036/5914780129_e5dbb9912b_z.jpg
De Plan V's die anno nu nog rijden, komen NIET uit deze deelserie, maar zijn uit de deelseries V4-V6 of V7-V13.
V4-V6 (treinstel 442-483) hebben nooit een bagage-afdeling gehad, zie:
http://www.freewebs.com/falcoflipsen/Mat%2064%20Plan%20V.jpg
V7-V13 (treinstel 801-965) hadden een postafdeling. Dit is de deelserie waar Fleischmann een 1:100 model van gemaakt heeft. Zij hebben hun model ook in het groen uitgebracht, maar dat is dus niet correct. De V7-V13 zijn nooit groen geweest:
http://farm8.staticflickr.com/7166/6783199783_ce16ddd6c3_z.jpg
Bij een deel van deze stellen zijn de postdeuren vervangen door twee ramen, ook halverwege de jaren'90:
http://www.nvbs.com/Doximg/Fotorondzendingennw_25.jpg
Maar bij de rest van deze stellen zijn deze deuren nog wel aanwezig, maar alleen afgesloten.
En om het verhaal dan maar helemaal af te maken, heb je ook nog vierdelige stellen, maar dat heet Plan T (treinstel 501-531).
« Laatst bewerkt op: 11 May 2012, 21:41:16 door Daan! »
sixkiller
Re:Roco plan V NS
« Reactie #182 Gepost op: 11 May 2012, 21:45:14 »
Dat valt wel mee volgens mij, zie hier
Is het een idee om wat ze bij andere fora wel doen de eerste post te veranderen en daar alle interessante en relevante info van sommige gebruikers of persberichten en foto's in te zetten (gewoon kopiëren) zodat er makkelijk op 1 plek een klein overzicht met foto's en informatie ontstaat. Nu zijn de pagina's (nog) niet zo heel veel, maar bijv. met 2400 van ROco is dat een hele dikke draad geworden en soms lees je iets interessants wat je weer vergeet en uiteraard later weer nodig hebt (bijv. tijdperk/rev datum, oude voorbeeld foto's of een nummeroverzichtje ed).
Lokpaint
Re:Roco plan V NS
« Reactie #183 Gepost op: 11 May 2012, 21:56:19 »
@Sneek : Zo te zien zitten de ramen (nog) niet goed in de sponning.
Even aandrukken in de fabriek en klaar :)
Hoi
Mwa...de ramen zijn nog niet eens doorzichtig. Er komt dus nog iets ander voor in de plaats.
Maar die neus....  Alsof iemand er met een hamer op gemept heeft. ;D
Bart
  • Hengelooo 1:160
Re:Roco plan V NS
« Reactie #184 Gepost op: 11 May 2012, 22:00:03 »
En hoe komt dat?
Het is geen Märklin...
Lokpaint
Re:Roco plan V NS
« Reactie #185 Gepost op: 11 May 2012, 22:06:06 »
Ook   ;D
Nee joh..ik kan er de vinger niet opleggen wat het precies is.
Net of de lampenbak te hoog zit, de raampartij te groot is en de neus te vlak.
Aan de ronding op de hoeken van de lampenbak zie je al dat er iets niet klopt. Deze is bij het model spits, bij het origineel rond.
Eerst maar eens het daadwerkelijke model afwachten dus. Verder weet ik zeker dat het net zo goed een verkooptopper wordt, dus wat zit ik nou te l....n.
bart
« Laatst bewerkt op: 11 May 2012, 22:08:07 door Lokpaint »
Peter Korsten
Re:Roco plan V NS
« Reactie #186 Gepost op: 11 May 2012, 22:30:52 »
't Is gewoon rond, hoor, het zou hoogstens een sinusoïde kunnen zijn, wat wiskundig gezien overigens klopt.
Wat je ziet is volgens mij gewoon het ontbreken van een likje verf.
- Peter
Lokpaint
Re:Roco plan V NS
« Reactie #187 Gepost op: 11 May 2012, 23:04:25 »
Hoi
Ik weet niet..
Bart
Re:Roco plan V NS
« Reactie #188 Gepost op: 11 May 2012, 23:10:45 »
vergelijking gaat niet echt op omdat de hoek van de foto anders is en dat kan veel uitmaken.....
  • Spaar ze allemaal.
Re:Roco plan V NS
« Reactie #189 Gepost op: 11 May 2012, 23:12:00 »
Op het totaalplaatje vind ik de neus wel weer stukken beter lijken.
« Laatst bewerkt op: 11 May 2012, 23:16:58 door prutser »
jakop
Re:Roco plan V NS
« Reactie #190 Gepost op: 11 May 2012, 23:13:10 »
Ik ben het met Bart eens, al kan ik de vinger er op niet op leggen.
En niet omdat ik ook 3railer ben ;D
Iets is anders/fout/niet kloppend aan de kop, toch onmiskenbaar plan-v....en toch is er iets mee
't zal het succes niet in de weg staan denk ik
Jakop
Re:Roco plan V NS
« Reactie #191 Gepost op: 11 May 2012, 23:15:39 »
Bij die twee vergelijkplaatjes ziet de 1:1 neus er meer "opgeblazen" uit.
Het lijkt zelfs wel of beide foto's iets vertekend zijn.
« Laatst bewerkt op: 11 May 2012, 23:22:59 door prutser »
Viktor
  • BNLS spoorkaart NL
  • 77*
Re:Roco plan V NS
« Reactie #192 Gepost op: 11 May 2012, 23:17:56 »
Tja.. op de detailfoto's vind ik de neus kloppen, maar op het geheel klopt er bij mij toch iets niet..
Ik denk dat het komt omdat ik de huidige versie gewend ben en dat gele vlak bij de bagageruimte er niet in wil bij mij :P
Maar ik vind het een prachtmodel dus laat maar komen!
gr. Viktor
JAB van Ree
Re:Roco plan V NS
« Reactie #193 Gepost op: 11 May 2012, 23:23:08 »
De koppeling lijkt in model lager te zitten, waardoor de neus wat kaler lijkt...
Lokpaint
Re:Roco plan V NS
« Reactie #194 Gepost op: 11 May 2012, 23:24:53 »
Hoi
Het is ook een prachtmodel, begrijp me niet verkeerd.
En ik ben ook weer veel te kritisch. Het totaalplaatje is helemaal niet verkeerd.
Bart
