om 08:12:02
welke zimo decoder in roco SIK 72012
om 08:11:51
Spoor010
om 07:20:33
Schaal TT
om 07:01:31
02 February 2026, 23:28:08
02 February 2026, 23:08:07
Exact-train 2026
Falkenberg
02 February 2026, 23:04:56
02 February 2026, 22:43:31
Petertje
02 February 2026, 22:41:36
Blausee-Mitholz
02 February 2026, 22:37:58
02 February 2026, 22:30:47
Blausee-Mitholz
02 February 2026, 22:29:24
02 February 2026, 21:07:49
Model cipressen in 1:87
grove den
02 February 2026, 20:42:19
Frank1965
02 February 2026, 20:07:37
The Rail Lab
02 February 2026, 19:52:31
Peter van der Leek
02 February 2026, 19:15:54
Mijn LEGO modellen.
02 February 2026, 19:00:25
02 February 2026, 18:41:37
02 February 2026, 18:38:48
openmaken philotrain 1500
Casmir
02 February 2026, 18:38:05
02 February 2026, 18:24:48
jack is back
02 February 2026, 18:12:13
02 February 2026, 17:51:33
02 February 2026, 17:46:08
Hout realistisch nabootsen
Robert vh Prutsert
02 February 2026, 17:44:11
De (3d) knutsels van Ronald.
DH1-3104
02 February 2026, 17:26:27
Fleischmania Nostalgia
02 February 2026, 17:04:38
02 February 2026, 16:42:18
Roco 2025
VAM65
02 February 2026, 16:31:42
Station Uden
Topic: Station Uden (gelezen 27624 keer)
WVDD
WMU Projects.
Wout, WMU Projects.
Re:Station Uden
Reactie #105 Gepost op:
30 June 2010, 16:40:27 »
We zetten het zelf hier in elkaar, daar wordt het wel op maat gezaagd dat wel.
30,00 stuks Stalen hoek 40x40x40 mm
19,80 m Vuren 44x44 mm (op maat afgekort) Is geschaafd
49,00 m Vuren 18x70 mm (op maat afgekort) Is geschaafd zou niet geschaafd de afmetingen 22x70 mm hebben
7,63 m Berken multiplex 9 mm (op maat gezaagd) Raden ze aan bij de timmerman om voor modelspoor te gebruiken
Gr,
Wout
WMU Projects. Station Uden
www.wmu-projects.webklik.nl
WVDD
WMU Projects.
Wout, WMU Projects.
Re:Station Uden
Reactie #106 Gepost op:
30 June 2010, 19:56:25 »
Kom net van de timmerman terug en hij had een betere manier voor mij om de modulebakken in verstek te maken en dan met speciale lijm in elkaar te zetten dus geen schoeven hoekjes of weet ik veel wat. Dit is sowiesow ook veel goedkooper en heb ook een nieuwe sponsor. Ik hoef zelf maar voor 6 platen te betalen dat zijn alleen de bovenplaten en de planken die immers ook uit platen worden gezaagd krijg ik gratis van hem.
Gr,
Wout
Re:Station Uden
Reactie #107 Gepost op:
30 June 2010, 20:34:30 »
kijk dat gaat lekker zo, dat scheelt toch weer
gr, mathyn
www.MCKmodelbouw.nl
Nu ook op
instagram
Ronaldk
Re:Station Uden
Reactie #108 Gepost op:
30 June 2010, 20:47:14 »
Dat is geen slechte deal Wout... een betere maar toch goedkopere constructie! Hij zet ze ook nog in elkaar voor je? Dan heb helemaal in orde
Groeten Ronald.
WVDD
WMU Projects.
Wout, WMU Projects.
Re:Station Uden
Reactie #109 Gepost op:
30 June 2010, 21:52:46 »
Na ik mag de platen mee zagen em hij doet er een voor en dan mag ik de rest doen. Maar ja het is niet zo moeilijk, hij zij de planken lijmen en goed tegen elkaar aan zetten dan tape er om heen en dan ben je al klaar dan alleen nog maar laten drogen.
Dus ik ben ook zo klaar
Gr,
wout
HansQ
Daar waar de rook is, is de kortsluiting...
Re:Station Uden
Reactie #110 Gepost op:
01 July 2010, 01:46:32 »
Ik zou toch zeer aanbevelen geen gewoon vurenhout te gebruiken voor dingen die langer dan een cm of 10 zijn.
Gebruik vooral zoveel mogelijk multiplex, omdat dit veel minder 'werkt', bij voorkeur Okoumé omdat het minder splintert dan het veel gebruikte Meranti.
Niks zo frustrend als een stuk vaste baan of module waar je veel tijd in hebt gestopt die kromtrekt!
Zeker bij schaal N of Z maar ook al bij H0 betekent een paar mm dat je treinen gaan hobbelen of zelfs ontsporen!
Voor zaken als hoeklatjes en andere zaken die niet in de lengte kunne werken is vuren natuurlijk prima!
HansQ, RailClub Utrecht
WVDD
WMU Projects.
Wout, WMU Projects.
Re:Station Uden
Reactie #111 Gepost op:
01 July 2010, 10:13:19 »
Na ik ga gewoon Berken multiplex gebruiken, dat is immers ook al besteld.
Vrijdag wordt het geleverd en zaterdag kan ik daar komen zagen en in elkaar zetten!
Gr,
Wout
HansQ
Re:Station Uden
Reactie #112 Gepost op:
01 July 2010, 11:05:44 »
Berken, geen ervaring mee, maar vast ook prima (ik zie 'Pappelholz' gebruikt bij
www.meine-n-welt.de
bijvoorbeeld).
Veel succes en vooral plezier met je houtwerk!
Ronaldk
Re:Station Uden
Reactie #113 Gepost op:
01 July 2010, 11:16:17 »
Pappelholz = Populier = Peppel is een licht houtsoort. Iets lichter dan Berken. Berken is ook heel goed te gebruiken voor je baan, niets mis mee. Ik gebruik populieren multiplex bij
mijn baan
Wout, succes zaterdag met zagen en in elkaar zetten!
Groeten Ronald.
HansQ
Re:Station Uden
Reactie #114 Gepost op:
01 July 2010, 11:17:50 »
Ah, ik dacht dat Berken en Pappel hetzelfde was. Had ik moeten weten als zuiderling uit de klompenstreek...
WVDD
WMU Projects.
Wout, WMU Projects.
Re:Station Uden
Reactie #115 Gepost op:
01 July 2010, 19:55:54 »
Kijk zo leer je nog eens wat
kevinhhw
Re:Station Uden
Reactie #116 Gepost op:
01 July 2010, 20:09:32 »
dat heb je goed voor mekaar
WVDD
WMU Projects.
Wout, WMU Projects.
Re:Station Uden
Reactie #117 Gepost op:
01 July 2010, 20:31:10 »
Zeker ja hoef ik alleen maar zijn logo onder mijn tafel te hangen:P
Myron
NS jaren '90
Re:Station Uden
Reactie #118 Gepost op:
02 July 2010, 09:15:31 »
Laatst bewerkt op: 02 July 2010, 13:04:56 door Peter van der Leek
Grootspoor:
www.spoorpers.nl
en
Modelspoor:
www.spoorinmodel.nl
WVDD
WMU Projects.
Wout, WMU Projects.
Re:Station Uden
Reactie #119 Gepost op:
03 July 2010, 12:32:29 »
Vandaag een module bak gemaakt! Alles is gezaagt maar moet nu gaan werken. Ik heb nog geen foto's want was camera vergeten maar ik moet er nog negen maken, dus er komen nog zeker foto's. Ik kan wel zeggen dat in verstek maken ziet er erg netjes uit. Alleen dan nog schilderen en het lijkt net een stuk hout!
Gr,
Wout
Station Uden
