Schaal TT door T.Spat
02 February 2026, 23:50:58
02 February 2026, 23:28:08
02 February 2026, 23:08:07
02 February 2026, 23:04:56
02 February 2026, 22:59:03
02 February 2026, 22:43:31
02 February 2026, 22:41:36
02 February 2026, 22:37:58
02 February 2026, 22:30:47
02 February 2026, 22:29:24
02 February 2026, 21:07:49
02 February 2026, 20:42:19
02 February 2026, 20:07:37
02 February 2026, 19:52:31
02 February 2026, 19:42:07
02 February 2026, 19:15:54
02 February 2026, 19:00:25
02 February 2026, 18:41:37
02 February 2026, 18:38:48
02 February 2026, 18:38:05
02 February 2026, 18:24:48
02 February 2026, 18:12:13
02 February 2026, 17:51:33
02 February 2026, 17:46:08
02 February 2026, 17:44:11
02 February 2026, 17:26:27
02 February 2026, 17:04:38
02 February 2026, 16:42:18
Roco 2025 door VAM65
02 February 2026, 16:31:42
02 February 2026, 16:29:13
Auteur Topic: Mallnitzer Tauernbahnstrecke ÖBB N Spoor  (gelezen 1960463 keer)
US modeller
Re: Mallnitzer Tauernbahnstrecke ÖBB N Spoor
« Reactie #3615 Gepost op: 15 November 2018, 19:51:33 »
Chris, precies wat ik bedoel!
Regards Joshua
Het spoor kent geen 'bochten', wel bogen.
  • Wir bauen fur Sie!! 🇦🇹
  • Bahnfahren ist ÖBB !!! 🇦🇹
« Reactie #3616 Gepost op: 16 November 2018, 06:20:11 »
Jos,het precies de nostalgie die het sporen zo mooi maakt!
Gr Chris
Gr Chris
« Reactie #3617 Gepost op: 17 November 2018, 07:34:20 »
Servus,
Om de bonte Nightjet verder uit te breiden is het onderstaande setje nog op weg naar Nederland.
Aangezien ik niets meer krijg van de Sint moet ik mezelf maar wat schenken.
Gr Chris
Gr Chris
Petertrein81
  • Taurus en Vectron fan!!
« Reactie #3618 Gepost op: 19 November 2018, 15:56:13 »
Voor de nachttrein liefhebbers.
Een simpel filmpje van mijn zo correct mogelijk samengestelde ÖBB Nightjet EN421 Düsseldorf - Innsbruck/Wien: https://youtu.be/MD_xI_12sc4
MvG Peter,
« Reactie #3619 Gepost op: 19 November 2018, 23:39:08 »
Ja precies Peter,
Mooi filmpje van een mooie bonte EN/Nightjet.
Gr Chris
Gr Chris
« Reactie #3620 Gepost op: 20 November 2018, 14:38:51 »
Servus,
Hop net binnengekregen per post op het werk!
Kijken of ik vanavond een paar foto’s kan maken.
Gr Chris
Gr Chris
« Reactie #3621 Gepost op: 20 November 2018, 19:56:07 »
Servus,
Ik heb een mooie afbeelding gevonden met de Bahn in mijn favoriete jaargetijden.
IMG_4056 by Chris van der Flier, on Flickr
Gr Chris
Gr Chris
« Reactie #3622 Gepost op: 21 November 2018, 00:00:54 »
Servus,
Ik heb net nog wat foto's gemaakt van de nieuwe aanwinsten van LS Models 97000.
Wat het meest in het oog springt zijn de nieuwe draaistellen die nu echt Super zijn.
Gr Chris
« Laatst bewerkt op: 21 November 2018, 00:20:28 door Schachbrett »
Gr Chris
« Reactie #3623 Gepost op: 22 November 2018, 21:45:35 »
Servus,
Het heeft inderdaad een tijdje geduurd,maar hier is weer eens een bouwupdate.
Gisteren kwam er van bouwen niets van op mijn vrije/papadag.
Maar vanavond heb ik lekker de zaag in de baan gezet.
Met de ondanks binnengekomen LS Models Slaaprijtuigen werd het nog eens bevestigd dat de bochten in niets zichtbare gedeeltes dadelijk veel te krap zijn.
Dus ben ik aan het zagen geweest om de openingen veel ruimer te maken onder de berg.
Zagen in een bestaande baan valt niet mee qua ruimte en bewegingsvrijheid.
Nu even doorzetten zodat alles weer dicht kan en er weer gereden kan worden.
IMG_4077 by Chris van der Flier, on Flickr
Gr Chris
Gr Chris
« Reactie #3624 Gepost op: 23 November 2018, 23:20:59 »
Servus,
Vanavond ben ik verder aan het zagen geweest aan de onderdoorgang of opening.
Ik had toch het idee dat de verruiming van gisteren te weinig solaas bood.
Dus heb ik alles maar een stuk ruimer gemaakt of verwijderd.
IMG_4083 by Chris van der Flier, on Flickr
IMG_4084 by Chris van der Flier, on Flickr
Gr Chris
Gr Chris
« Reactie #3625 Gepost op: 24 November 2018, 22:58:14 »
Servus,
Ik heb net nog heel effe gereden met de nieuwe 1293.001.
Deze was als testtrein onderweg met de Cityshuttle op weg richting de Tauerntunnel.
Gr Chris
Gr Chris
« Reactie #3626 Gepost op: 25 November 2018, 21:41:10 »
Servus,
De Brenner Jubileum lok komt het station Mallnitz-Obervellach binnengelopen met een slaaptrein aan de haak.
Gr Chris
Gr Chris
  • Michel
  • low-budget modelbouwer
    • Rangeerbanen
« Reactie #3627 Gepost op: 26 November 2018, 08:36:26 »
Ik had nog wat mooie foto's gemaakt bij Braz van voorbij razende Railjets met de 1116.217 en de 1116.243 in tandem.
Het is daar niet veel veranderd. Twee plaatjes van 1995:
De kwaliteit is niet geweldig, het was druilerig weer en ik had een oud fototoestel (wel spiegelreflex). Maar het geeft een leuke impressie. Ik weet niet of ik meer heb, mijn archief is tijdelijk opgeborgen ivm een verbouwing.
Overigens zag ik onlangs via Google-streetview St. Anton am A.. Toen schrok ik wel even heel erg van de veranderingen daar. Het toeristenplaatsje was compleet veranderd in een hotelresort. Wat er wel niet kan veranderen in ruim 20 jaar.
« Reactie #3628 Gepost op: 26 November 2018, 15:30:51 »
Hallo Michel,
Bedankt voor de mooie foto's.
Het is daar inderdaad niet veel verandert in die tijd.
Maar dat is misschien ook wel het mooie eraan het ademt nog wel wat nostalgie uit.
Gr Chris
Gr Chris
« Reactie #3629 Gepost op: 27 November 2018, 22:32:49 »
Servus,
Ik heb net nog even gereden na het voetbal.
Morgen ga ik weer verder met bouwen!
Dus loopt de 1116.158 Licht ins Dunkel station Mallnitz binnen met een Rex-zug aan de haak.
Gr Chris
Gr Chris
