Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: verlijmen van Evergreen polystyreen strips  (gelezen 12694 keer)
Karst Drenth
    • Plan U op Sleutelspoor
Re:verlijmen van Evergreen polystyreen strips
« Reactie #15 Gepost op: 08 December 2009, 00:34:34 »
Een lijm die dit klusje, naar eigen ervaring, echt goed klaart is PlasticWeld van PlaStruct ( glazen flesje, zwarte dop, oranje label )
Grtzz,
Karst
    • sleutelspoor
« Reactie #16 Gepost op: 08 December 2009, 08:11:00 »
Het probleem zit hem niet vaak in het verlijmen maar om de lijm (oplosverbinding) stabiel te houden. Je lost de kunstof op en het duurst wel 24 uur voordat de volledige oplossing stabiel geworden is. Waar je dus moet opletten is om de lijmverbinding stabiel te kunnen houden voor een langere tijd. Hoe meer lijm je gebruikt hoe meer er oplost dus hoe langer het duurt voordat de verbinding stabiel is. Zoek dus een evenwicht in de hoeveelheid lijm die je gebruikt.
Gr. Gerco
« Laatst bewerkt op: 08 December 2009, 09:04:18 door Gerco van Beelen »
Noppie.
  • Rock and roll is better than music.
« Reactie #17 Gepost op: 08 December 2009, 11:07:29 »
Mensen, wat moeten jullie toch met al die levensgevaarlijke stoffen,
Huub.
Ik werk al jaren met dit goedje, en ik kan je verzekeren, ik weet wat ik doe. Als je maar consequent de dop na het openen, kwastje erin, er weer op draaid is er niets aan de hand. En goed ventileren, maar dat geld eigenlijk bij alle lijmsoorten.
Het was een beetje overtrokken :P, Maar als je de uitwerking niet kent, tsja, dan moet je het niet gebruiken. En nogmaals ik heb wat papier moeten invullen, en de apotheker overtuigen, over het hoe en waarom. Heb gewoon tekeningen en een proefmodel van styreen mee genomen, welke ik eerder met een ander soort lijm in elkaar had gezet.
Maar er zijn zeer goede alternatieven zoals hier al beschreven. Als chloroform op is zal ik ook naar iets anders uitkijken. Het verdampt heel erg traag, na zo een 2 jaar is het weg. Zelfs met de dop er op.
Greetz,
Noppie.
A world without heroes, Is like a world without sun, You can't look up to anyone, Without heroes.
edwin1974
  • Allegra" treinstel
« Reactie #18 Gepost op: 08 December 2009, 15:38:31 »
Sluit mij aan bij een aantal andere reacties: MEK. Probeer het eens. De ervaring zal je meer leren dan alle woorden op deze pagina denk ik.
Ik denk dat ik vanavond enkele proeven ga doen met een product die jij op de in het citaat genoemde pagina.
Ben wel benieuwd naar de resultaten hier van  ;)
Want misschien heb ik er iets aan voor een project waar ik binnenkort mee start :-X
Groetjes edwin
« Laatst bewerkt op: 08 December 2009, 15:40:51 door edwin1974 »
Peter Spruit
  • SBB en BLS baan in opbouw - Project Goschensteg
« Reactie #19 Gepost op: 08 December 2009, 16:45:07 »
LOL..... ik dus ook....
ga  straks  achter een fles Bison ontvetter.    Zeer benieuwd  naar het  resultaat  :D
Peter
Petdig1
Gerrit F
  • Zelfportret
« Reactie #20 Gepost op: 08 December 2009, 17:06:09 »
Eh...ik weet niet of het hier al eens is gemeld...maareu,  niet roken bij dit werk.
Alle eerder genoemde producten zijn zeer licht ontvlambaar!
En voor de komende grapjurken  ;) , nee ik heb hiermee geen ervaring.
Ik rook niet en de kerst is ook nog redelijk ver weg.  ;D
Gerrit F
Van de draad af....
edwin1974
« Reactie #21 Gepost op: 08 December 2009, 18:12:20 »
Zo ik ben even wat wezen uit proberen met Bizon ontvetter en de proef stukjes liggen nu te drogen.
Ik ben benieuwd morgen  :)
@peter
Ik ben benieuw naar jouw ervaring..LOL..
groetjes edwin
« Laatst bewerkt op: 08 December 2009, 18:30:44 door edwin1974 »
cevenol
  • Nieuwe gebruiker
« Reactie #22 Gepost op: 09 December 2009, 00:07:51 »
Huub.
Greetz,
Noppie.
Dat komt waarschijnlijk doordat je het in een plastic fles bewaart. Chloroform, maar ook MEK, verdampt door de plastic fles heen. Gebruik dus een glazen flesje, met een bakelieten dop.
Groet, Wim.
Gerrit F
  • Zelfportret
« Reactie #23 Gepost op: 09 December 2009, 00:19:19 »
Maar de MEK die ik hier heb staan, wordt door de fabrikant verkocht in een "plastic fles".
MEK.
Zij geven aan dat ze het probleem van het doorlaten van damp, vrijwel onder de knie hebben.
Dit is mijn MEKplak set.
Info komt uit dit topic.
Gerrit F
Van de draad af....
« Reactie #24 Gepost op: 09 December 2009, 09:10:23 »
Klopt, Chloroform moet je in een glazeflesje met bakkeliete dop bewaren. MEK ook!
Chloroform kun je trouwns ook iets dikker maken door er restjes van de raampjes-gietbomen in op te lossen.
Je kunt er ook gewoon de bouwpakketten van Faller, Volmer enz mee plakken. De delen tegenelkaar zetten en de chloroform met een klein penseeltje er tegen houden. Die kruipt dan gelijk in het naadje. Even vasthouden en klaar.
Deka
« Reactie #25 Gepost op: 09 December 2009, 09:18:28 »
Ik heb het al vaker gemeld: je kan een gewoon flesje met willekeurige dop gebruiken, mits je tussen dop en flessehals een stukje huishoudfolie aanbrengt (is polyethyleen).  Ik heb zo al jaren   aceton, MEK en wasbenzine in huis, en er is niets verdampt.
Noppie.
« Reactie #26 Gepost op: 09 December 2009, 10:29:36 »
Dat komt waarschijnlijk doordat je het in een plastic fles bewaart. Groet, Wim.
Nou het is wel een glazen flesje, maar met een plastic dop. Er daar zal het dan wel door verdampen. Zal eens zien of de apotheker nog een exemplaar heeft liggen. ;D
Greetz,
Noppie.
hmmglaser
Re: verlijmen van Evergreen polystyreen strips
« Reactie #27 Gepost op: 11 February 2024, 13:06:56 »
Ik probeer op het moment styreen profielen aan elkaar vast te lijmen met Revell contacta, maar het valt me tegen hoe vast het zit!
Ik kan ze redelijk makkelijk weer los trekken, je ziet duidelijk dat de lijm in het styreen smelt maar het zit niet muur vast wat je bij modellen van Revell of Faller wel hebt.
Heeft iemand hier een oplossing voor andere lijm of?
Mvg Mark
« Reactie #28 Gepost op: 11 February 2024, 13:43:15 »
Ik denk dat in dit draadje alle antwoorden al gegeven zijn. Om wat voor profielen gaat het? Weet je zeker dat het polystyreen is?
Het kan zijn dat je te ongeduldig bent, soms kan het wel een half uur duren voordat het goed vast it.
Karst Drenth
« Reactie #29 Gepost op: 11 February 2024, 13:47:19 »
Citaat van: hmmglaser
Uit eigen ervaring: Contacta heeft ongeveer 4 uur nodig om helemaal uit te harden. Juist omdat het het styreen lichtjes oplost.
Langer wachten ;)  ( oh... en niet bewegen tijdens het uitharden )
Grtzz,
Karst
