Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: verlijmen van Evergreen polystyreen strips  (gelezen 12684 keer)
Peter Spruit
  • SBB en BLS baan in opbouw - Project Goschensteg
« Gepost op: 07 December 2009, 13:11:49 »
Probeerde  van het  Week-end Evergreen strips onderling te verlijmen.
Ging dus niet  helemaal goed   >:( daar  de lijm verbinding niet echt  lekker ging.
Heb met volgende 2 lijmen ge-experimenteerd :
- superlijm van OLBA
- gewone plastic lijm Revell
? wat doe  ik dus verkeerd  ?
Tips  en trics  zeker welkom
Tx and Grtz
Peter
Petdig1
Hans_omBC
  • Fremo Brio
  • Team Mitropa
Re:verlijmen van Evergreen polystyreen strips
« Reactie #1 Gepost op: 07 December 2009, 13:15:41 »
Lijmen met ether of MEK.
Hans
Marty
  • Het Achtergrondmannetje.nl
« Reactie #2 Gepost op: 07 December 2009, 13:19:56 »
Zou in principe gewoon altijd goed moeten gaan. is zo zeker als nat worden in de regen  :)
Ik heb nog nooit meegemaakt dat er 2 stripjes niet blijven zitten.
Kan zijn dat ze vet zijn, of je hebt ze per ongeluk in olie laten vallen zonder dat je er erg in hebt.
De stripjes komen wel uit een origineel gesloten verpakking?
Als je gelijmd hebt, gaat het onderling nog draden of laat het gewoon los en ziet het styreen er onaangetast uit ?
Lijm niet over datum??
Andere dingen zou ik zo snel niet kunnen bedenken
Edit: inderdaad werkt MEK goed, maar lijmverdunner/verwijderaar van BISON werkt ook heel goed, droogt sneller. Maar met Revell zou het zeker ook moeten lukken, al droogt het wat langzamer, maar ook weer niet meer dan een zwik minuten
« Laatst bewerkt op: 07 December 2009, 13:21:33 door marty »
  • Team Mitropa - OHMB
« Reactie #3 Gepost op: 07 December 2009, 13:28:50 »
Gewoon met Faller Expert (rode dopje) daar heb ik al heel wat styreen mee gelijmd. Sterker nog, alles wat ik aan styreen heb gelijmd :) Wel is het inderdaad zinvol om te zorgen dat er geen vet of verf op de te verbinden delen zitten. En wanneer de verbinding onder spanning staat, altijd met een klem/plakbandje/elastiekje aan elkaar verbinden tot de lijm is uitgehard.
Bessel
RETROBAHN A.G.
HuubvG
« Reactie #4 Gepost op: 07 December 2009, 13:29:23 »
... ... Ging dus niet  helemaal goed   >:( daar  de lijm verbinding niet echt  lekker ging. ... ...
Kun je hier misschien iets duidelijker zijn? Wat ging er niet goed? Wat ging niet echt smakelijk?
Als je de kopse kanten aan elkaar wilt lijmen, kan ik me voorstellen dat het niet houdt. dan zou je extra steun moeten geven. Of droogde de lijm te snel? Of wilde je de lengtes aan elkaar lijmen en droogde de lijm al op terwijl je nog aan het insmeren was?
Foto? Misschien dat we op ideeën komen als je wat meer info hieromtrent geeft... want wat al gezegd is, het moet lukken met al de genoemde lijmsoorten eigenlijk.
Peter Spruit
« Reactie #5 Gepost op: 07 December 2009, 18:02:13 »
Het gaat dus inderdaad  over het  verlijmen van de  kopste  kanten
Vet of vuil waren ze zeker niet, recht uit de verpakking.
Ga vanavond nog eens een poging  wagen
Als je gelijmd hebt, gaat het onderling nog draden of laat het gewoon los en ziet het styreen er onaangetast uit ? :
nee dat was dus het rare..... het  styreen zag er inderdaad nog  vrij onaangetast uit.   Zou dus inderdaad ook deels aan de lijm kunnen liggen.
Enfin...bedankt voor  de tips en wordt  vervolgd
Peter
Petdig1
edwin1974
  • Allegra" treinstel
« Reactie #6 Gepost op: 07 December 2009, 18:07:55 »
Wat ik meestal doe voor dat ik stryeen ga lijmen is even licht opschuren met schuurpapier en dan de geschuurde delen in smeren met lijmen en dan op elkaar lijmen en in lijmtangen zetten.
groetjes edwin
Noppie.
  • Rock and roll is better than music.
« Reactie #7 Gepost op: 07 December 2009, 18:25:27 »
Ik lijm styreen al jaren aan elkaar met chloroform. Destijds bij de lokale apotheker gekocht. En nee niet een ieder krijgt het mee naar huis. Je kan er ook andere "dingen" mee doen (y)
Tip: houd het dopje goed op de fles, want het verdampt waar je bij ligt.... En ik kan het weten. :P
Greetz,
Noppie.
A world without heroes, Is like a world without sun, You can't look up to anyone, Without heroes.
HuubvG
« Reactie #8 Gepost op: 07 December 2009, 18:51:57 »
Het gaat dus om de kopse kanten. Mm, dat wordt lastig omdat dat geen vlees genoeg heeft om houvast te hebben. Wellicht dat dat met secondenlijm nog de sterkste las geeft, maar als het om heel dunne strips gaat, blijft het lastig.
@Edwin, aangezien het om de kopse kanten gaat, lijkt me de lijmklemmen niet veel nut hebben...
Mensen, wat moeten jullie toch met al die levensgevaarlijke stoffen, terwijl het in 99% van de gevallen met doodgewone styreenlijm, die dun en dik te verkrijgen zijn, ook heel goed lukt? Even wat meer geduld hebben levert een langer gezonder leven op zeg. Bovendien gaat dat agressieve spul snel verdampen, maar tevens lost er een hoeveelheid van de weekmakers in de styreen op zodat je er van die hele harde breekbare styreen aan overhoudt.
RobbertJan
  • Mcn NSR Groningen.
« Reactie #9 Gepost op: 07 December 2009, 19:05:14 »
Styreen rechtstreeks uit de verpakking lijm ik altijd met Revell Contacta.
Deze lijm maakt beide delen styreen iets week waardoor ze als het ware
in elkaar vloeien en een solide verbinding aangaan die redelijk flexibel blijft.
Het duurt wel even voor de verbinding goed vast is vanwege het uithardingsproces.
Neem dus wel de tijd tussen lijmen en bewerken.
Een andere lijm die ook zeer geschikt is: Faller Super Expert in de oranje verpakking.
Deze lijm heeft ongeveer de zelfde eigenschappen als Revell Contacta.
Overigens zijn kleine oppervlakken altijd lastig te verbinden, de mooiste oplossing is
om beide delen in te klemmen, lijm er op, en dan in de juiste positie tegen elkaar zetten.
Neem bijvoorbeeld een 3e handje en klem dan beide delen in de bekjes.
Laatst zelf nog gedaan met een stuk rond styreen van 1mm doorsnede waarvan ik een cirkel
had gemaakt voor een handrail op een silo.
Succes!
Cranmore Road. Brits 1:43,5
Peter Spruit
« Reactie #10 Gepost op: 07 December 2009, 21:42:00 »
Zo daarstraks nog even met diverse lijmen aan het experimenteren geweest...
Ondermeer de revell Contacta
Probleem zit hem dus inderdad in de  kopse kanten.
Wat ik eigenlijk probeer te maken is uit 1 mm dikke styreen stroken van pakweg 3 mm breed  en 7 mm breed zijn de plaatsnaamborden voor op mijn perrons.  Deze moeten uiteraard op " palen" staan die  ik dus uit 1 mm* 1 mm styreen strookjes wou maken...
De lijmoppervlakte is dus 1 mm2.
Vrees dat ik naar plan B moet  overgaan.   Klein gaatje in de kopsekant  boren en daar een meesing  pootje in frotten van 0.7 mm diameter
Eventueel door dit te verhitten en dan erin te laten smelten  ;D
Peter
Petdig1
Falkenberg
« Reactie #11 Gepost op: 07 December 2009, 22:13:59 »
Snelste voor Evergreen strips is Kibri 9995 Plastikkleber. Met een penseel het contactvlak bestrijken, 5 sec wachten en t zit vast. Het is ook in een grote fles verkrijgbaar voor de grootverbruikers onder de bouwers.
Maar zoals jij beschrijft wil je een paal kops op de stroken lijmen. Dat blijft nooit goed zitten. Daarvoor kun je het beste een messing draadje in een gaatje in de kopse kant van de palen bevestigen (met superglue) en hetzelfde stiftje dan in de borden in een gaatje lijmen. Met een boortje 0,4mm en een 0,35 messing draadje past dat makkelijk.
Dirkjan
Gerrit F
  • Zelfportret
« Reactie #12 Gepost op: 07 December 2009, 22:41:02 »
Ik heb afgelopen week ruim 46 stukjes styreen van rond 0,5 mm. op strip van 0,5 mm. geplakt.
Dit worden klemmetjes voor op de huif van de NS 450 waarmee de luiken vastzitten.
Het ronde profiel past mooi in een vulpotlood en daardoor word het allemaal wat hanteerbaarder en kun je het ook gemakkelijker op de strip vastdrukken.
Klik op plaatje = groter
Ik plak dit doormiddel van MEK.
Uiteinde even in de MEK dopen en direct op de strip drukken.
Niet te hard, anders druk je alles in elkaar want de MEK lost het ingedoopte eindje een beetje op.
Gerrit F
Gerrit F
Van de draad af....
  • Modelrailroading is fun!
    • Team USA Metusa Junction
« Reactie #13 Gepost op: 07 December 2009, 22:43:02 »
Ik lijm Evergreen al jaren met gewone Revell vloeibare lijm.... en er laat nooit iets los. Hier dus geen enkel probleem!
br212
« Reactie #14 Gepost op: 07 December 2009, 22:46:14 »
Sluit mij aan bij een aantal andere reacties: MEK. Probeer het eens. De ervaring zal je meer leren dan alle woorden op deze pagina denk ik.
Frans
