Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: Station Arnhem jaren '80'  (gelezen 389147 keer)
RICROO
Re: Station Arnhem jaren '80'
« Reactie #810 Gepost op: 13 February 2020, 21:29:14 »
Hallo Niels,
Zit weer leuk beweging in. Blijf het volgen.
Richard
  • Het leven op de weg.
    • Midland
« Reactie #811 Gepost op: 14 February 2020, 10:14:27 »
Hoi Niels,
Het schaduwstation is nu dus zo goed als afgerond?
Aangezien je bovenop bezig bent.
Gr Koen.
Niels B
    • Arnhem in de jaren ´80
« Reactie #812 Gepost op: 14 February 2020, 22:13:25 »
De laatste tijd weer wat meer tijd en zin in de hobby inderdaad. Er zit nog meer in de planning, maar daarover later meer.
Het schaduwstation is op zich klaar, er moet nog wel wat aan de onderzijde gesoldeerd worden. De planken op het stationsniveau liggen nog los. Ik ben bezig om die definitief te plaatsen waarbij ik steeds twee delen die aan elkaar zitten makkelijk kan weghalen. Dit in geval van storing of onderhoud aan het schaduwstation. Ik heb hier een constructie voor bedacht, hout gehaald maar nog geen tijd gehad om er aan te beginnen. Dat is het leuke van een project zoals de VL, daar kun je lekker ‘s avonds een uurtje aan werken zonder al te veel herrie te maken.
Grtz,
Niels
Frans van Meerwijk
« Reactie #813 Gepost op: 15 February 2020, 16:05:16 »
Ik kén Arnhem rond de jaren '60 en dus ook het bouwwerk van de VL/Post T (wat je ook wilt...), maar realiseer mij eigenlijk nú pas hoe groot dat gebouw was/is! Is dit ook niet één van de éérste VL-posten waar een "meer gecentraliseerde Verkeersleiding" begon?
Groeten van Frans
Niels B
« Reactie #814 Gepost op: 16 February 2020, 17:38:48 »
Het gebouw is inderdaad enorm. Voor mij komt dat goed uit, want het maskeert de entree naar het schaduwstation mooi.
Vandaag wat tijd gehad om verder te gaan. Planning was om de plint af te maken. Dat heb ik natuurlijk niet gedaan want ik vond dit veel leuker:
De dakopbouw begint zijn vorm te krijgen. Ik denk wel dat ik het brede deel nog een centimeter moet ophogen om de verhoudingen beter te krijgen.
Grtz,
Niels
Jasperkc
« Reactie #815 Gepost op: 28 April 2020, 23:14:03 »
Hallo Niels,
Ziet er zeker weer mooi uit! Vergeet vooral niet de 2 kopspoortjes met de 1300en. Ik heb er foto's van!
Groet, Jasper.
Carel Ruysink
« Reactie #816 Gepost op: 29 April 2020, 10:04:28 »
Deze spoortjes?
Mei 1997
Niels B
« Reactie #817 Gepost op: 29 April 2020, 10:28:33 »
Dank Jasper.  (y)
@Carel: mooie foto, ik zie weer details die ik eerst niet zag...
De kopspoortjes komen er zeker, je ziet ze al liggen op de laatste foto. Inmiddels ben ik al weer een stukje verder met de VL maar gaat de aandacht momenteel vooral uit naar het leggen van de sporen in het station. Overigens zijn foto’s zeer welkom. Ik zou nog wel willen weten welke kleur de beplating vroeger had die onderaan de raampartij aansluit. Ik kan dat steeds niet goed zien, ik denk dat het bruin was, maar weet het dus niet zeker.
Afgelopen week ben ik dan eindelijk gestart met de sporen definitief te leggen en met het maken van de blokken. Ik heb de bovenzijde, zoals in de post van 14 februari staat, in modules gemaakt nu. Hierdoor kan ik beter bij de onderzijde komen en kan ik ze zelfs mee naar buiten nemen. Inmiddels ligt de bekende wisselstraat op de goede plek, zijn de eerste wisselmotoren geplaatst en is de bedrading van dit deel al bijna gereed.
Op MP afgelopen week een hele batterij wisselmotoren weten te bemachtigen, daar moet ik alleen nog nieuwe draden in weten te frommelen...
Grtz,
Niels
martijnhaman
« Reactie #818 Gepost op: 29 April 2020, 10:48:53 »
Voor zover ik het kan zien op foto's is er geen sprake van beplating, maar ramen tot aan de onderzijde. Door de luifel valt er licht op de onderste helft wat suggereert dat er beplating is. De ramen zijn getint.
Martijn
Niels B
« Reactie #819 Gepost op: 29 April 2020, 11:03:59 »
De ramen staan iets naar buiten toe. Daaronder zit een afserking die de ramen weer laat aansluiten op de gevel.
Deze rand is nu blauw, net als de top van het gebouw. De top was vroeger bruin, daarom vermoed ik dat deze rand dat vroeger ook was:
Grtz,
Niels
Niels B
« Reactie #820 Gepost op: 01 June 2020, 20:50:22 »
Hallo allemaal,
Vandaag getuiniert zoals ik graag doe: lekker modelbouwen in de achtertuin.  ;D
Aangezien ik niet tevreden was met de onderste rand van de VL heb ik deze verwijderd en opnieuw genaakt. Om het geheel strak te houden ben ik begonnen met de bakstenen en ga ik daar tegenaan werken.
Dit was de oude onderrand:
Dit is de nieuwe in wording:
Vandaag vooral bezig geweest met de baksteenplaten en de opbouw. Het resultaat na een paar uur prutsen:
Ik ben redelijk tevredden met de vorm. Eens kijken of ik ik deze week nieuwe styreen kan scoren!
Grtz,
Niels
« Laatst bewerkt op: 02 June 2020, 10:09:15 door Niels B »
spoorzeven
« Reactie #821 Gepost op: 01 June 2020, 21:02:57 »
Niels, is dit een foto van de bouw van de post (160679)?
Groet, Frank
    • Midland
« Reactie #822 Gepost op: 01 June 2020, 22:02:49 »
Dat gaat er goed uitzien dat pand.
Gr Koen.
Niels B
« Reactie #823 Gepost op: 02 June 2020, 10:07:01 »
@spoorzeven: dat lijkt er wel op! Gave en unieke foto! Ik had wel wat foto's van de bouw, maar nog niet vanaf het station genomen.  (y)
@Koen: Thnx! BTW: je plot is klaar, ik probeer hem vandaag even te posten.
Tulpendaal
  • Westlandbaan-Delft
    • DELFT
« Reactie #824 Gepost op: 03 June 2020, 19:50:24 »
Super mooie bussen. (y)
...en gatver wat is dat een lelijk gebouw, maar wel mooi gebouwd (y)
Het spannende van bouwen wat er echt gestaan heeft er voor zorgt dat ook zulke gebouwen aan de beurt komen en het er veel realistischer uitziet (y)
Blijf volgen Gr Joke
