Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: Station Arnhem jaren '80'  (gelezen 389143 keer)
Tulpendaal
  • Westlandbaan-Delft
    • DELFT
Re: Station Arnhem jaren '80'
« Reactie #795 Gepost op: 13 November 2019, 19:31:33 »
en jij geluk dat scheelt in tekenen 8)
Niels B
    • Arnhem in de jaren ´80
« Reactie #796 Gepost op: 20 November 2019, 20:12:03 »
Dat klopt Joke  ;D
Inmiddels heb ik het plan iets gewijzigd en ben ik gestart met het plakken van de platen vanaf het einde van het perron. Het perron bestaat uit twee MDF stroken welke achter elkaar liggen. Ze liggen op hun plek door middel van een aantal duvels.
Het voorste plaatje ligt op een andere strook dan het tweede plaatje. Het sluit mooi aan. Ook de zijkanten heb ik vastgeplakt:
Nu moet er nog een stripje aan de bovenzijde geplaatst worden en dan staat de basis. Helaas heeft lokale treinenboer geen styreen meer dus moet ik even wachten op een nieuwe levering. Hopelijk komt dat morgen binnen zodat ik weer kan gaan plotten.
Wordt vervolgd!
Grt,
Niels
Niels B
« Reactie #797 Gepost op: 28 December 2019, 20:22:47 »
Deze Kerstvakantie moest het maar eens gebeuren: het grote soldeerwerk onder de baan. Inmiddels zijn de eerste blokken en bezetmelders aangesloten en werken ze correct. Nu nog een manier vinden om de dradenzooi wat te fatsoeneren... Solderen, niet mijn hobby....
Testen met 10 locs daarentegen is dan wel weer leuk.  ;D
Morgen nog een dagje. Dan staat de andere zijde op de planning,
Grtz,
Niels
eichddraig
« Reactie #798 Gepost op: 28 December 2019, 22:42:14 »
Wel overzichtelijk
gr. Ed
  • Het leven op de weg.
    • Midland
« Reactie #799 Gepost op: 28 December 2019, 23:05:39 »
Af en toe bovenop kijken wat er gebeurd maakt het wel draaglijk, ja. :D
Gr Koen.
Niels B
« Reactie #800 Gepost op: 29 December 2019, 10:00:56 »
Wel overzichtelijk
Nee, nog niet echt. Er zit wel systeem in, maar het ziet er inderdaad nogal als een zooi uit. Ik sta open voor suggesties om het te verbeteren.
Grtz,
Niels
clickmaniac
  • The perfect is the enemy of the good
« Reactie #801 Gepost op: 29 December 2019, 12:18:58 »
Tja iets meer structuur kan geen kwaad. Wat Erik bij mijn baan gedaan heeft: eerst  alles onder verdelen in hoofd- en zijkanalen. Alles zit in een hoofdkanaal samen, maar per categorie (voeding wisselmotoren, bezetmelders, de min, voeding hartstuk?) is misschien nog mooier. De kanalen hang je dan op met tie-wraps, die weer aan van die plastic oogjes met voetje met dubbelzijdig plakband hangen. Tie-wrap niet te strak trekken! De hoofdkanalen hangen meestal paralel aan het spoor, de zijkanalen staan daar haaks op en zijn zo kort mogeliljk. Gaffer tape om de zij-kanalen tegen het "plafond" te plakken.
Bij bijvoorbeeld de min-kabel: eerst bepalen en opmeten waar de zijkanalen komen, dan op die plekken de isolatie lospeuteren en zijkanaal eraan solderen. Als de hele "boom" klaar is, eronder hangen. Soldeerverbindingen (mits ze goed zijn...) zijn veel duurzamer dan kroonstenen. Om ze van de buitenwereld te isoleren: krimpkousjes ipv plakband, ook veel duurzamer.
Heb je daar post-its gebruikt voor de labeling? Had ik ook, ooit. Op gegeven moment lagen ze allemaal op de vloer! Verschillende kleuren gaffer tape zou handig zijn, kan je ook op schrijven.
Nou, voilá. Tot zover de theorie... sterkte. Maar het wórdt wel wat!
Niels B
« Reactie #802 Gepost op: 29 December 2019, 13:35:31 »
Hoi Diederik,
Dank voor je toelichting.  (y) Wat bedoel je met hoofd en zijkanalen? Heb je hier wat foto’s van?
Ik heb zelf nu een ringleiding aangebracht waarbij de kroonsteentjes de verbinding vormen. Overigens niet voor de zwarte draad want die loopt er dwars doorheen.
Oveigens is dit wel het meest chaotische stuk waar een tien bezetmelders zitten, desalniettemin ben ik ook nog niet zo tevreden net het eindresultaat. ‘Gelukkig’ ben ik pas op de helft dus kan de andere zijde jouw tips opvolgen en dan later dit aanpassen.
De codering is overigens niet met post its maar met  stevige tape gedaan.
Ben wel zoekende hoe ik dit handiger kan doen.....
Grtz,
Niels
  • DB Tijdperk III
« Reactie #803 Gepost op: 29 December 2019, 13:42:23 »
Je zou ook kabelgoten kunnen gebruiken om de bedrading netjes weg te werken.
Zoiets dus:
« Laatst bewerkt op: 29 December 2019, 13:43:57 door basjuh1981 »
Die Sauerlandbahn
Mijn YouTube-kanaal
Menno
    • Mijn van-alles website
« Reactie #804 Gepost op: 29 December 2019, 14:06:35 »
Geloof me, wil je ook niet. Verhard op den duur en de lijm blijft op de kabel achter in onverwijderbare aangekoekte gelige troep.
Tie-wraps met aangegoten label om op te schrijven heb ik goede (professionele) ervaring mee.
RICROO
« Reactie #805 Gepost op: 29 December 2019, 22:06:39 »
Hallo Niels,
Inderdaad een lastig probleem. Ik denk dat de tie-wraps met aangegoten label een goede oplossing is. Wat je ook kan gebruiken is tape die je om de kabelader heen kan wikkelen met daarop een nummer geprint. Even uitleggen, je hebt strookjes met alleen het getal 0, 1, 2, 3 enz. Door je kabels te coderen met een strookje met het cijfer 0 en 2 (bijvoorbeeld) dan heeft die kabel de code 02. En zo verder.
Dit systeem wordt in de vliegtuig industrie gebruikt en de strookjes zijn van een soort zelfklevend lint achtige sticker gemaakt. Maar papier werkt ook en is natuurlijk prima zelf te produceren.
Ik werkte altijd wel met kabel bomen, dus van de diverse aansluitingen kwamen alle kabels op de hoofdkabelboom uit en verlieten deze weer op de plek waar dat nodig was. Die kabelboom begon dan dun, werd steeds dikker en nam op een gegeven moment weer af in diameter.
Ik hoop dat het een beetje duidelijk is.
Richard
Niels B
« Reactie #806 Gepost op: 09 February 2020, 19:45:22 »
Alweer een tijdje in huis, maar ik had hem nog niet laten zien:
Een mooie GSM semi tour van HB models. Ik had hem al weer een paar jaar geleden gezien en toen niet gekocht, altijd spijt gehad dat ik dat niet had gedaan. Onlangs in Houten toch maar gekocht. Misstaat niet op het Stationsplein West.
Ondertussen ook maar eens een nieuw bouwprojectje opgestart (omdat al mijn andere gebouwen natuurlijk al helemaal klaar zijn  :P). Rara, welk gebouw gaat dit worden?
Overigens zijn nog niet alle onderdelen gereed.
Gebouwen vind ik toch leuker dan dat gesoldeer....
Grtz,
Niels
Niels B
« Reactie #807 Gepost op: 09 February 2020, 19:46:35 »
Overigens Richard: jouw verhaal is duidelijk, daar had ik nog niet op gereageerd. Dank voor je uitleg, ik ben er mee bezig.  (y)
Frans van Meerwijk
« Reactie #808 Gepost op: 10 February 2020, 15:16:55 »
De Verkeersleiding wordt dus niet superCentraal, maar gaat netjes plaatsvinden vanuit het seinpaleis? (Of noemden we dat toen nog gewoon Post T)
(Overigens, als die semitour je tóch niet bevalt wil ik hem wel een veilige garage bieden... :angel:)
Frans
Niels B
« Reactie #809 Gepost op: 13 February 2020, 20:07:23 »
Helaas Frans, de semi tour heeft het hier prima naar zijn zin...  ;D
Het wordt inderdaad de VL. Er zit inmiddels meer vorm in en ik heb hem even op ongeveer de juiste plek gezet:
Het gebouw neemt aardig het zicht weg op de scherpe bocht. Dit weekend wil ik de onderrand afmaken en airbrushen waarna ik langzaam naar boven ga werken met baksteenplaat. Ook ben ik bezig met de opbouw waar de daadwerkelijke VL staat.
Grtz,
Niels
