Vandaag om 00:00:19
lichtsluis een bezetmelding laten geven door Peter J K
26 December 2025, 23:27:47
Raadplaatje door Hatsune Miku
26 December 2025, 23:00:13
Stub switches door Hans1963
26 December 2025, 22:53:48
Ombouw/Pimpen Bolle neuzen door T.Spat
26 December 2025, 22:45:43
De Hasseberg (spoor nul op 9mm) door T.Spat
26 December 2025, 22:42:42
26 December 2025, 22:40:29
Modellbundesbahn in Brakel sluit in mei 2026 door ruben derks
26 December 2025, 22:34:25
26 December 2025, 22:33:15
Fleischmania Nostalgia door Noordernet
26 December 2025, 22:23:19
Camp 3 door Noordernet
26 December 2025, 22:22:04
Layne, Somewhere South. door Noordernet
26 December 2025, 22:20:28
Bouwverslag BlueBrixx BR 01 No.108054 (plusminus 1:18) door MOVisser
26 December 2025, 22:17:19
"moderne" kolenbakken en kolenwagens in Nederland. door neudalhausenstadbahn
26 December 2025, 22:09:18
26 December 2025, 22:06:17
Het schrootverwerkings bedrijf in aanbouw door ruudns
26 December 2025, 21:43:51
Ontraxs 2026 door Ronaldk
26 December 2025, 21:19:43
Modelwensen 2026 door spoorzeven
26 December 2025, 20:52:53
Even voorstellen Niels uit Den Haag door Menno
26 December 2025, 20:49:51
Werkplaats Wael en Bosch door Forever Rocofan
26 December 2025, 19:31:49
26 December 2025, 18:55:18
26 December 2025, 18:42:25
Yamorc 7001 dood door Mar-Cas
26 December 2025, 17:58:06
Rheinburg, TP V/VI door Eric B
26 December 2025, 16:09:06
Berkina Volvo met Viessmann taxi bord door Eric B
26 December 2025, 15:33:23
Bahnstrecke 5867 door gdh
26 December 2025, 15:30:26
Leids spoor (voorheen Blauwpoortsbrug) door Frank 123
26 December 2025, 15:28:06
Station Steenwijk poging 2 door Eric B
26 December 2025, 15:11:02
Ermehuizen, dienstregelingsjaar 1973/1974 door NS264
26 December 2025, 14:37:02
Baanbouw: NL Baan Kleindrecht in H0 door mikeya
26 December 2025, 14:08:22
Auteur Topic: Bahnshop: BR 189, h0 en N,  (gelezen 6925 keer)
Eenerspoor
  • D813 Groningen 1972-73 grijs verleden met karakter
    • MSC-Roden
Re:Bahnshop: BR 189, h0 en N,
« Reactie #15 Gepost op: 22 July 2009, 23:03:28 »
Ik heb dus ook zo'n Tulpenlok besteld en vandaag ontvangen. Hij ziet er niet mooi uit, met een Pantograaf verbogen een onderdeel afgebroken. :(
De lak en een raam van één van de kabines zijn ook beschadigd, bovendien zitten er deuken in de dakrand:
Er is kennelijk nogal ruw omgegaan met het pakket waarin deze lok naar mij toegestuurd is. Hier werd ik niet vrolijk van!  :'(  :(  :o
Als je wilt weten waar die lak gebleven is, die zit binnen in de ovp, die ook flink gescheurd is:
De lok zat er helemaal verschoven in, waardoor die panto met geweld omhoog is gedrukt.
Inmiddels heb ik een mail gestuurd naar Bahnshop; nu maar ff op hun antwoord wachten.
H0 2-rail met  iTrain, Yamorc 7001, Digikeijs, Rosoft, LocoNet.
Remco.
« Reactie #16 Gepost op: 22 July 2009, 23:07:46 »
Zo dat is wel sneu voor je ja :(
Je zou haast verwachten dat deze niet goed in de verpakking gezeten heeft, als zelfs de lak eraf ligt  :-X
Ik hoop voor je dat ze het oplossen en je alsnog een goede lok krijgt (y) Je houdt altijd je hart vast als je dingen verstuurd...
Ik heb 1 keer laatst gehad dat iets mis was gegaan, werd gelukkig perfect opgelost, maar goed, ben altijd weer blij als het veilig
en wel is gearriveerd!
Gr. Remco.
« Laatst bewerkt op: 22 July 2009, 23:10:41 door Remco »
en_voyage
« Reactie #17 Gepost op: 23 July 2009, 00:33:34 »
Zonde van de Tulpenloc!
Helaas is het een bekend probleem met de verpakkingen van de Hobbyloc's van Piko. Bij ruwe behandeling tijdens verzending kan de transparante plastic binnendoos gemakkelijk gaan scheuren, waardoor het model kan gaan schuiven met soms schade aan het model tot gevolg. Dat is klaarblijkelijk bij jouw model het geval geweest.
Op andere (Duitse) fora komt dit probleem zo nu en dan aan de orde. Helaas heeft Piko tot op heden weinig aan de verpakkingswijze van de Hobbylocs veranderd. Voorlopig zal dit risico bij postverzending blijven bestaan. Als je dus een nieuwe van de Bahnshop krijgt toegestuurd, dan is het te hopen dat de posterijen iets zachthandiger met het pakje omgaan...
Succes ermee!
Gr. Geoffrey
« Reactie #18 Gepost op: 26 July 2009, 12:13:01 »
Aansprakelijkheid van de post zal wel lastig aan te tonen zijn. Kwestie van goodwill, lijkt mij.
Eenerspoor
    • MSC-Roden
« Reactie #19 Gepost op: 13 August 2009, 10:29:01 »
Op verzoek van Bahnshop heb ik de lok op hun kosten teruggestuurd, waarna ik per omgaande een nieuwe toegestuurd heb gekregen.  :D  8) En die is wel goed aangekomen.  (y)
Er zit inmiddels een decoder in, de lok is ingereden en de snelheid geijkt in Koploper. De Tulpenlok heeft haar plaats ingenomen op mijn (test)baan.  8)
