Vandaag om 01:40:35
Spoorwegmuseum in zwaar weer door tinus
Vandaag om 01:09:59
12 February 2026, 22:30:31
12 February 2026, 22:25:10
Spotten in Sloehaven en Zeeuws Vlaanderen door Huibert
12 February 2026, 22:11:03
Lok adres programmeren lukt niet met multimaus door Cegielski
12 February 2026, 22:02:11
12 February 2026, 21:55:06
Stub switches door Klaas Zondervan
12 February 2026, 21:28:45
12 February 2026, 21:15:21
RailBOX Accessoire Decoder RB4400 door Steven Loosman
12 February 2026, 21:15:20
Traincontroller software gaat stoppen. door reinderlf
12 February 2026, 21:12:47
12 February 2026, 21:09:20
Bediening OOC terminal Oss door timtrein
12 February 2026, 19:50:02
12 February 2026, 19:42:24
12 February 2026, 18:50:46
Toon hier je nieuwe (model-) spooraanwinst(en)... door Robkop
12 February 2026, 18:42:35
Roco 70788 2400 met Zimo MX645 acceleratie settings door Steven Loosman
12 February 2026, 18:12:17
Station Weesp door virmfan
12 February 2026, 18:05:15
12 February 2026, 18:01:04
Voordelige treinkaartjes door Quinzeedied
12 February 2026, 18:00:49
12 February 2026, 17:46:46
12 February 2026, 17:29:22
12 February 2026, 17:18:29
12 February 2026, 17:03:17
4 april Het Stoomgenootschap naar Köln door Seinhuis
12 February 2026, 16:55:32
Minstens 5 jaar geen treinverkeer Groningen-Leer [D] door Noordster
12 February 2026, 16:51:57
12 February 2026, 16:42:09
Spoor vernieuwing Oisterwijk door Charles_
12 February 2026, 16:42:05
Nederlands-materieel in Spoor-1 door FritsT
12 February 2026, 16:41:07
Spoor vernieuwing Oisterwijk door Daan Knoben
12 February 2026, 16:25:59
Auteur Topic: Samenstelling blokkendoostrein spoorwegmuseum.  (gelezen 4555 keer)
Thom
Re:Samenstelling blokkendoostrein spoorwegmuseum.
« Reactie #15 Gepost op: 05 June 2009, 00:01:10 »
8553 is het originele nummer
Cec is de normale aanduiding van het rijtuig geweest
Was het dan de Ces die doorgenumemrd was, of ben ik compleet abuis ?
Peter Wijshake
« Reactie #16 Gepost op: 05 June 2009, 00:38:00 »
Ja dat klopt, daarvan zijn er ooit drie gemaakt (8101 - 8103); de nu bestaande Ces 8104 is verbouwd uit de voormalige motorwagen mCv 9411 (waarbij de 'v' staat voor vouwbalg, vroeger luidde de benaming overigens mCd [d = doorgangsrijtuig, niet te verwarren met de grote 'D' van bagage]). Qua zijwandindeling waren de Ces-rijtuigen gelijk aan de mCv's; aan het dak is nog te zien dat de Ces 8104 een voormalige motorwagen is (aan de plaatsing van de ventilatoren).
Peter
robin binsbergen
« Reactie #17 Gepost op: 05 June 2009, 00:38:37 »
Je hebt helemaal gelijk hoor Thom,
Omdat het (in eerste instantie) een tweewagenstel was, was het handiger om een rijtuig van dit type op te bouwen, gelijk aan de 3 stuurstandrijtuigen welke bestemd waren voor de lijn naar Ijmuiden. Aangezien er geen originele rijtuigen meer voorhanden waren van dit type werd dit rijtuig dus opgebouwd uit een ander rijtuig en gewoonweg doorgenummerd zodat dit rijtuig nu het nummer 8104 draagt.
Voor meer gegevens, zie: http://www.nmld.nl/index.php?page=object&id=2176&lan=nl
Robin
Peter Wijshake
« Reactie #18 Gepost op: 05 June 2009, 00:47:02 »
Volgens mij was het oorspronkelijke plan zelfs zo, dat Blokkendoos-rijtuig Cecs 8107 (ex Cec 8506, verlengd met een stuurstand dus, daar waren er vier van) van de Hoogovens Excursietrein genomen zou worden als stuurstandrijtuig. Maar daarvan was de technische staat te slecht, zodat het rijtuig uiteindelijk is gesloopt.
In dat geval zou de - historisch juiste - combinatie mBD - Cecs ontstaan zijn.
(Voor Cecs kan men ook lezen Cesc, de bedoeling is hetzelfde, maar beide typeaanduidingen worden in de literatuur gebruikt).
Peter
  • Modelspoor is emotie...
« Reactie #19 Gepost op: 05 June 2009, 09:41:22 »
Robin
Met betrekking tot de link een kleine opmerking: er staat in de aanhef vermeld 'motorrijtuig C 8104'. Dit klopt niet, daar het hier om een stuurstandrijtuig zonder aandrijving gaat.  Minor detail...
Tbinnebarretije…
  • Lid Houtense Koekenclub
  • Spoor N
« Reactie #20 Gepost op: 05 June 2009, 17:16:40 »
DankU  ;D
Vandaar ook trouwens het nummer, Cecr 8553, wat een opvolgend nummer is van zijn originele bouwserie.
Verder hebben we het trouwens over de mBD 9107 en Ces 8104
Is de 8104 niet het opvolgende nummer van de originele serie?
« Reactie #21 Gepost op: 05 June 2009, 17:21:34 »
Ja! Maar dat werd ook al geschreven door Robin van Binsbergen...
« Laatst bewerkt op: 05 June 2009, 17:23:11 door Wijktrein »
Tbinnebarretije…
Peter Wijshake
« Reactie #22 Gepost op: 05 June 2009, 17:25:14 »
En daar boven staat het ook al  ;D
  • Spoor N
« Reactie #23 Gepost op: 05 June 2009, 18:09:39 »
Ja, dat komt ervan als je de tweede pagina over het hoofd ziet. :-[
mpol
« Reactie #24 Gepost op: 24 June 2009, 22:09:25 »
Peter
Dit is leuke info!!
Ben bezig een mC van Roco te 'verbouwen' tot de z.g. Jaap. Aangezien de mBD van NSM ook een 'geel' dak heeft neem ik deze direct mee in spuit sessie. Volgende stap is dan de Ces en een nieuwe Roco Cec om te bouwen in Cerc.
Had dus bijna een Ces van Roco gebruikt voor museumtrein, maar begrijp nu dat ik hiervoor een mCv moet gebruiken.
 (y)
Wordt leuke uitdaging......
Peter Wijshake
« Reactie #25 Gepost op: 24 June 2009, 22:18:24 »
Nou ja... Als je het stuurstandrijtuig wilt maken (de 8104 dus), dan is feitelijk wel het makkelijkst om een Ces van Roco te nemen en de ventilatoren aan te passen. Als je 'm echt vanuit een mCv wilt maken, moet je het hele dak kaal halen. Da's én meer werk én het kost meer geld. Uiterlijk zijn ze verder identiek...
Succes met de verbouwing!
Peter
Rudolfph
« Reactie #26 Gepost op: 24 June 2009, 22:21:47 »
Je kan gewoon de Ces gebruiken, eventueel nummer je hem om in 8104. De oorsprong van de 8104 mag dan wel een mCv zijn, maar dat is nu ook gewoon een Ces hoor. Of je moet, net als in het echt, een mCv in een Ces willen ombouwen, maar dat lijkt me een beetje zonde van de moeite. ;)
Gezocht: (kopieën van) NS VPM en VRM en DB Zp AR, AU, BR, BU, CR en CU voor mijn website over treinsamenstellingen: http://treinsamenstelling.wordpress.com/
Bijbehorend forumdraadje: https://forum.beneluxspoor.net/index.php?topic=56271
mpol
« Reactie #27 Gepost op: 24 June 2009, 22:45:10 »
Peter
Zal wat ventilatoren bestellen (kijken of Philotrain me op weg kan helpen) en er mee aan de slag gaan.
Vind het iig leuke info, want anders had ik Ces van Roco alleen maar omgenummerd........
Peter Wijshake
« Reactie #28 Gepost op: 24 June 2009, 22:52:27 »
Ik weet niet helemaal of het aantal ventilatoren klopt, anders is het slechts een kwestie van verplaatsen... Volgens mij heeft een Ces meer ventilatoren dan een mCv (misschien dan Arjen [AB.... met een of ander nummer  ;) ] dat zo uit zijn hoofd weet.
Het dichtmaken van de gaatjes op het dak is zo gebeurd, stukje Evergreen strip er in lijmen en glad schuren.
Suc6!
Peter
Post49
  • NS Tijdperk II-B / III-A&B Vlaardingen
« Reactie #29 Gepost op: 24 June 2009, 23:07:29 »
Aantal dakluchters is bij de mCv/mCd, Ces en Cec gelijk. Namelijk 6. 2 Per compartiment, maar bij de motorwagens moeten er nou eenmaal nog panto's op ;).
Erik.
