Vandaag om 07:51:03
Acme nieuwe ICNG door virmfan
Vandaag om 03:32:28
Vandaag om 03:09:43
Ardennen-express 1139/1138 door de jaren heen door Jos B.
Vandaag om 01:53:41
Vandaag om 00:11:40
Vandaag om 00:09:03
25 April 2026, 23:56:58
25 April 2026, 23:52:22
25 April 2026, 23:32:15
25 April 2026, 23:03:22
25 April 2026, 23:02:14
25 April 2026, 23:00:32
Alp Adrei door JurS
25 April 2026, 22:04:05
25 April 2026, 21:10:11
25 April 2026, 21:00:08
25 April 2026, 20:34:20
25 April 2026, 20:20:49
25 April 2026, 20:00:08
Ontraxs 2026 door Hans1963
25 April 2026, 19:51:41
25 April 2026, 19:48:28
25 April 2026, 19:19:33
25 April 2026, 19:14:55
25 April 2026, 17:54:02
25 April 2026, 16:59:33
25 April 2026, 16:52:06
25 April 2026, 16:37:51
25 April 2026, 16:24:32
25 April 2026, 14:40:40
25 April 2026, 13:36:58
25 April 2026, 13:12:43
Auteur Topic: Dapol 00 Gauge Motorized Track Cleaner  (gelezen 47699 keer)
Remco.
« Gepost op: 10 January 2009, 19:16:32 »
Foto van Dapol site
OO gauge motorised track cleaner
Dapol B800 HO/OO gauge DCC ready 5way track cleaner.
This model uses the latest in technology to aid you keeping your track clean and is perfect
for those hard to reach places such as tunnels, at the back of layouts or under catenary
wires.
It is DCC ready and features an 8pin DCC socket that can take either UK or USA
configured
decoders (orientated), and needs a chip that can operate the motor to function on DCC. It
can be run on DC as a normal item with the motor sharing power with the locomotive that is
needed to haul it. There is an onboard on/off switch to aid this.
The motor within the unit powers, at the modellers choice, either the vacuum function or the
sprung abrasive/polishing head.
There is also an underbody brush for basic removal of dirt/fluff etc, and a reservoir that can be
filled with any non flammable, plastic friendly track cleaning solution that feeds down onto a
sponge (included) that rubs the rail head (to be used before the sprung buffing head).
It is fittest with the best of darkened profile wheels set to a 14.4mm back to back and to
RP25.110 standards, and is fitted with standard UK type couplings within an NEM coupling box.
B801 with KayDee couplers is only available directly from Atlas USA and not Dapol
B802 with European \'Roco\' couplers is only available form Japan model Railways and
not Dapol
5 way refers to, liquid application, sprung polishing, abrasive scraping, brushing
and vacuuming.
Hier een draadje over alles wat met de Dapol te maken heeft, ik heb er zelf 1 besteld ( Samen met 2 andere forumgenoten beide ook 1 )
Mede dit draadje gemaakt om het Lux draadje niet te vervuilen
De eerste vraag waar ik mee start, welke decoder gebruiken jullie in je Dapol, ik ben zelf voornemens een Lopi3 te plaatsen, heeft iemand die ook in gebruik en heb je evt wat aangepast aan de CV's oid ?
Gr. Remco.
Re: Dapol 00 Gauge Motorized Track Cleaner
« Reactie #1 Gepost op: 10 January 2009, 19:30:06 »
Is deze ook bij de handel op Houten verkrijgbaar?
Gr, Ben.
Remco.
« Reactie #2 Gepost op: 10 January 2009, 19:36:26 »
Ja dan zijn ze 85 euro zonder decoder, de man die ze verkoopt staat ook op marktplaats. Maar gezien de lage pond - euro wisselkoers is kopen in Engeland erg goedkoop nu, +- 62 euro voor de machine :)
Gr. Remco.
Daan!
« Reactie #3 Gepost op: 10 January 2009, 19:37:35 »
hij polijst, schuurt en zuigt toch? Ik meen dat schuren niet zo goed is voor je rails....?
Remco.
« Reactie #4 Gepost op: 10 January 2009, 19:38:37 »
Volgens mij kun je dat zelf bepalen door de verschillende koppen die erbij zitten, dat heb ik al ergens gelezen maar waar weet ik ook even niet meer :)
En echt schuren is niet goed, maar als het gaat met een blokje zoals wat Roco heeft is er niets mis mee.
Gr. Remco.
Peter1
  • Nieuwe gebruiker
« Reactie #5 Gepost op: 10 January 2009, 20:21:56 »
Denk een oude Lenz die ik nog ergens heb liggen - iets gesofistikeerds (lastregeling bv.) is hier m.i. niet nodig.
Gr. Remco.
Iétsje meer nl. £59,95 x 1.12 (huidige wisselkoers) = 67€
« Laatst bewerkt op: 10 January 2009, 21:55:00 door Peter1 »
    • Het Groterdam Project
« Reactie #6 Gepost op: 10 January 2009, 22:09:03 »
Importeur is er mee bezig voor NL  ;)
Arreman
« Reactie #7 Gepost op: 10 January 2009, 22:17:02 »
Ik heb er ook al een. Ik heb er een simpele decoder ingedaan die ik nog had liggen, zonder lastregeling. Dit werkt goed.
Door het verwisselen van de draaischijven kan je kiezen tussen zuigen, polijsten en schuren.
Hij werkt zeer goed (ik wist niet dat ik zoveel stof op mijn baan had liggen), soms iets te goed. Ik heb in een geballast wissel blijkbaar niet overal genoeg lijm gebruikt en nu heeft hij alle ballast tussen de dwarsliggers weg gezogen.... Tja.. je kan hem ook zachter laten zuigen natuurlijk..
Gr Bart
H0, DCC, Intellibox, Koploper
Karst Drenth
    • Plan U op Sleutelspoor
« Reactie #8 Gepost op: 10 January 2009, 22:58:09 »
Wentink Arnhem levert ze ook, kreeg vandaag een mailing daarover.
Grtzz,
Karst
Remco.
« Reactie #9 Gepost op: 10 January 2009, 22:59:54 »
Ja toch wel he! Ik dacht het ook, maar kon het niet op hun site vinden dus dacht me vergist te hebben. Daar kost hij toch 100 euro ?
Gr. Remco.
Karst Drenth
« Reactie #10 Gepost op: 10 January 2009, 23:00:44 »
Remco.
« Reactie #11 Gepost op: 10 January 2009, 23:03:05 »
Ok, dat is nog wel 10 euro duurder dan op Houten, maar goed het loont dus nog om er 1 in Engeland te kopen :)
Gr. Remco.
Esperopt
« Reactie #12 Gepost op: 10 January 2009, 23:08:00 »
Zoiets had ik al begrepen, daarom nog niet in de UK besteld.
[off-topic] Had ze eigenlijk al als aanbieding op de site verwacht  ;D, doe mij maar 2 [off-topic]
Gerard.
Remco.
« Reactie #13 Gepost op: 10 January 2009, 23:12:29 »
2 Stuks Gerard ?
Ik begrijp dat je rails door het hele huis gaat en je laat stofzuigen ;D
Gr. Remco.
Karst Drenth
« Reactie #14 Gepost op: 10 January 2009, 23:16:05 »
Gerard heeft net als ik een Laminaat baan  ;D ;D
( en geloof ik een vrouw met lang haar  ;D ;D ;D ;D )
Dus een hele goede keus  :P
Grtzz,
Karst
