welke zimo decoder in roco SIK 72012
Goosie
om 07:29:08
Spoor010
om 07:20:33
Schaal TT
om 07:01:31
02 February 2026, 23:28:08
02 February 2026, 23:08:07
Exact-train 2026
Falkenberg
02 February 2026, 23:04:56
02 February 2026, 22:43:31
Petertje
02 February 2026, 22:41:36
Blausee-Mitholz
02 February 2026, 22:37:58
02 February 2026, 22:30:47
Blausee-Mitholz
02 February 2026, 22:29:24
02 February 2026, 21:07:49
Model cipressen in 1:87
grove den
02 February 2026, 20:42:19
Frank1965
02 February 2026, 20:07:37
The Rail Lab
02 February 2026, 19:52:31
02 February 2026, 19:42:07
Peter van der Leek
02 February 2026, 19:15:54
Mijn LEGO modellen.
02 February 2026, 19:00:25
02 February 2026, 18:41:37
02 February 2026, 18:38:48
openmaken philotrain 1500
Casmir
02 February 2026, 18:38:05
02 February 2026, 18:24:48
jack is back
02 February 2026, 18:12:13
02 February 2026, 17:51:33
02 February 2026, 17:46:08
Hout realistisch nabootsen
Robert vh Prutsert
02 February 2026, 17:44:11
De (3d) knutsels van Ronald.
DH1-3104
02 February 2026, 17:26:27
Fleischmania Nostalgia
02 February 2026, 17:04:38
02 February 2026, 16:42:18
Roco 2025
VAM65
02 February 2026, 16:31:42
Elektronica en analoog
Keerlusprint Wim Ros, 3 bezetmeldingen continue
Topic: Keerlusprint Wim Ros, 3 bezetmeldingen continue (gelezen 6892 keer)
Sander
Re: Keerlusprint Wim Ros, 3 bezetmeldingen continue
Reactie #30 Gepost op:
11 January 2009, 23:09:11 »
Hier de oudere versie van de print welke dus wel goed werkt.
Sander
Sander
Wim Ros
BHV
Reactie #31 Gepost op:
11 January 2009, 23:16:36 »
Nou Sander, dan weet je op welke print je het moet zoeken.
Mvg
Wim.
Intellibox via LocoNet-Interface met s88 via een s88 naar LocoNet adapter.Of L.NET-S88SD16-N Marklin 6021 via een 63820, LocoNet-Interface en een s88 naar LocoNet adapter. Lenz Digital Plus via LI101F of s88XPressNetLi s88SD16-n.
http://rosoft.boards.net
Sander
Reactie #32 Gepost op:
11 January 2009, 23:21:23 »
Wim,
op de bezetmeld print daar was ik al achter.
Die oude print is kwa opbouw echter nagenoeg hetzelfde als de nieuwe, alleen iets ruimer opgezet. Dus, 2 gelijke printen die verschillend reageren....
Sander
Laatst bewerkt op: 11 January 2009, 23:23:01 door Sander Lageveen
Sander
santerdam
Reactie #33 Gepost op:
12 January 2009, 00:05:38 »
Kun je niet enkele componenten van de 3 betrokken poorten uitwisselen met een andere kaart. Dan kom je er vanzelf achter welke component defect is. Zoveel componenten kunnen er niet bij betroken zijn.
Sander
