carnaval
om 00:53:22
om 00:48:49
om 00:37:47
H0e pizza layout
18 February 2026, 23:50:13
Spoorwegmuseum in zwaar weer
18 February 2026, 23:23:17
Multimaus Zwart
Lars Smelter
18 February 2026, 23:21:35
MERG CBUS/VLCB gebruikers?
reinderlf
18 February 2026, 23:20:37
18 February 2026, 23:16:26
18 February 2026, 22:35:13
18 February 2026, 22:01:04
18 February 2026, 21:57:36
Daan Knoben
18 February 2026, 21:47:52
Jeroen Trainz
18 February 2026, 21:46:44
18 February 2026, 21:29:58
18 February 2026, 21:18:26
Te 2/2
18 February 2026, 21:03:17
Ronald A.
18 February 2026, 20:59:36
jdk
18 February 2026, 20:58:41
Jeugdbaan - VvMrZ
18 February 2026, 20:22:41
Dirk
18 February 2026, 19:29:43
18 February 2026, 18:58:55
Luud H
18 February 2026, 18:19:54
The Summer of 69
18 February 2026, 17:56:21
18 February 2026, 17:48:27
18 February 2026, 17:24:52
emmenaar
18 February 2026, 17:17:00
ceuleer
18 February 2026, 17:16:00
DJH E127 NS 3300
18 February 2026, 17:04:58
18 February 2026, 15:57:03
18 February 2026, 15:23:46
Schwarzburg-Neuffen-Bahn
Topic: Schwarzburg-Neuffen-Bahn (gelezen 4060047 keer)
Re:Schwarzburg-Neuffen-Bahn
Reactie #7410 Gepost op:
14 December 2012, 16:44:12 »
Nu een iets langer filmpje. Rangeeractiviteiten op Schwarzburg-Kalteneck:
http://youtu.be/FC1wXzhiVUs
tuurtje
Reactie #7411 Gepost op:
14 December 2012, 16:49:30 »
Ruud,
groetjes
Arthur
Spoor-0 & Spoor-1
Reactie #7412 Gepost op:
14 December 2012, 16:51:20 »
Leuk Ruud.
Gr. Jaap
Bas23
Reactie #7413 Gepost op:
14 December 2012, 17:29:10 »
Gaaf filmpje Ruud
Gr Bas
Esu Ecos II, Fleischmann profirails, Tijdperk II/III,
Esu,Fleischmann,Roco,Faller,Vollmer.
Bram w
Reactie #7414 Gepost op:
14 December 2012, 18:49:41 »
Mooi filmpje Ruud
groet Bram.
Bram is in 2025 overleden
jerrytrein
Reactie #7415 Gepost op:
14 December 2012, 18:57:41 »
gaaf zo
en ze lopen mooi langzaam
nog een klein vraag
welk nummer is de lollo
gr nero
Basilicum
Prae-adviseur
Reactie #7416 Gepost op:
14 December 2012, 20:47:04 »
@Ruud: Leuke film. Alleen geeft het geluid van de 64 en 78 ongeveer twee in plaats van vier slagen per omwenteling.
@ Jerry:
Roco 72855
DB V160 002
Lollo
Deining in Dönsdorf
Dahinterhofen im Bau
Reactie #7417 Gepost op:
15 December 2012, 15:32:01 »
Bas: ja, het synchroon lopen van geluid en slagen is bij stoomlocs heel vaak een probleem.
Ik had nog even gedacht m'n filmpje voor de wedstrijd in te zenden, maar als ik zie wat voor prachtige bewegende beelden daar nu aan het verschijnen zijn, heeft het weinig zin.
jerrytrein
Reactie #7418 Gepost op:
15 December 2012, 15:36:05 »
niet gestuurd is altijd mis
gewoon insturen
al is t alleeen om meerdere mensen te laten genieten
Reactie #7419 Gepost op:
15 December 2012, 17:17:24 »
Ik zal er nog eens over nadenken, Jerry.
Vandaag in Houten o.a. laadgoed van Bauer gekocht, een gigantische buis en stalen balken:
Voor m'n militaire-vervoer-trein-in-wording twee Unimogs, die uiteraard tzt met keggen en kettingen fatsoenlijk vastgezet moeten worden:
Van Trix een geinig setje bruinkolenstof in Houten gevonden:
Laatst bewerkt op: 15 December 2012, 17:56:50 door Ruud K
dimo1_dimo1
Reactie #7420 Gepost op:
15 December 2012, 17:54:52 »
Mooie lading heb je daar
groeten,
Auke
Reactie #7421 Gepost op:
15 December 2012, 18:19:05 »
Ja, Auke, in Houten kijk ik altijd naar leuke lading en vaak vind ik wel iets naar m'n gading. Bauer is op dat punt wel m'n favoriete fabrikant; duur, maar erg mooi. En je kunt zo'n laadgoedverzameling natuurlijk langzaam opbouwen.
Een tijdje geleden kreeg ik hier een tip over de Volvo P1800, gebouwd tussen 1961 en 1972. Heb ik toen op m'n lijstje gezet. Herpa heeft die in model. Vandaag gevonden, zowel de Coupé als de Combi Coupé-versie. Erg mooie modelletjes:
Laatst bewerkt op: 15 December 2012, 18:22:59 door Ruud K
jerrytrein
Reactie #7422 Gepost op:
15 December 2012, 19:03:44 »
ddv
Reactie #7423 Gepost op:
15 December 2012, 19:30:56 »
Hoi;
Mooi spul weer, ik zou die Unimogs op een gewone rongenwagen zetten ze zijn wat "licht" voor zo'n mooie zwaar-transport wagen. Ik kijk er nu al naar uit wat je van die "Mogjes" gaat maken !!
Groet Dieter
Reactie #7424 Gepost op:
15 December 2012, 19:54:58 »
Dat is een goede tip, Dieter! Ik heb al wat verf aangeschaft en ook met poeders zullen ze wel een beetje beter uiterlijk krijgen. Nog eens achter vastzet-kettingen aan. Ik meen ergens gelezen te hebben dat Conrad die verkoopt.
Vandaag ook nog twee rongenwagens van Roco aangeschaft (artnr. 46490) voor 15 euro per stuk. Die zijn voor tp III minder makkelijk te krijgen dan voor IV. Ik had dus geluk. Er ligt nu rails op, maar misschien sloop ik die er wel vanaf.
De rongen liggen er los bij; die moet ik er nog op zetten.
Laatste rollend materieel-aanschaf van vandaag en ook de duurste (57,50): Oriënt Expres-slaapwagen van LS Models:
In de livrei van 1952, maar de uitvoering voor tp IIIb, dus na 1956.
Laatst bewerkt op: 15 December 2012, 20:10:48 door Ruud K
