Maarten-1-14
om 01:30:21
Tram groefrail
om 01:17:15
janw
om 00:03:50
13 January 2026, 23:49:18
Jewannes
13 January 2026, 23:23:29
13 January 2026, 23:17:55
Les Billards du Vivarais
13 January 2026, 22:52:12
13 January 2026, 22:50:09
13 January 2026, 22:49:06
gtw6016
13 January 2026, 22:48:36
13 January 2026, 22:41:44
13 January 2026, 22:27:37
13 January 2026, 22:03:21
Tramrail geometrie
13 January 2026, 21:41:26
Bahn-AG
13 January 2026, 21:34:11
Rail away
13 January 2026, 21:22:01
Roco 42616
13 January 2026, 21:10:50
MoBaBro.de
Dennis1984
13 January 2026, 20:43:10
Update: baan in de tropen
Arjen52
13 January 2026, 20:29:17
Slijptrein
13 January 2026, 19:31:40
Railz Miniworld
13 January 2026, 19:28:53
13 January 2026, 18:58:06
william_2
13 January 2026, 18:31:52
13 January 2026, 17:10:30
Wohnzimmer Rbf materieelshow
13 January 2026, 16:57:26
B2
13 January 2026, 15:29:15
Op Zuid (NL H0)
13 January 2026, 14:10:20
Jan den Haan
13 January 2026, 14:06:57
13 January 2026, 13:33:46
Karben
13 January 2026, 12:32:58
Verschil Roco DB150 62425 versu 63712
Topic: Verschil Roco DB150 62425 versu 63712 (gelezen 2947 keer)
Luc2000
15 November 2023, 19:35:34 »
Weet iemand wat het verschil is tussen
Roco 62425 en 63712
DB 150
Marco1044
ÖBB tp V (1985-2000)
Re: Verschil Roco DB150 62425 versu 63712
15 November 2023, 19:59:55 »
Nee, da’s 2x hetzelfde plaatje…
Gr Marco.
15 November 2023, 20:08:27 »
Gewoon even googlen op echte modelfoto's. Dan zie je de verschillen snel genoeg, namelijk het bedrijfsnummer en het type roosters
Marco1044
15 November 2023, 20:10:35 »
Roco 62425
Roco 68425 BR 150 2009–2010 Dig.8pol.
Digitaal DC (2-rail)
AC (3-rail) IV 150 127-9 DB Beige/Oceaanblauw
Roco 63712
Roco 69712 BR 150 2004-2005 Dig.8pol.
AC (3-rail) IV 150 120-4 DB Beige/Oceaanblauw
Wat ik kan, kan jij ook: effe Google raadplegen
De 62425 lijkt mij niets anders dan een heroplage van de 63712 maar dan met een ander locnummer.
Gr Marco.
ex-DR V100
1 gele trein maakt nog geen NS ...
15 November 2023, 21:11:19 »
De Roco -pagina plaatjes zijn hetzelfde. Gewoon het Roco -nummer Goochelen en dan zie je idd plaats roosters / nummer verscjhillend zijn.
Marc
bv
https://www.ricardo.ch/de/a/roco-br-150-120-4-der-db-art-63712-top!-1211686862/
15 November 2023, 21:41:58 »
De plaatjes bij ricardo zijn van dezelfde loc, de 150 120.
Links en rechts is de verdeling van de roosters/ramen verschillend. Dat is bij alle 150ers zo.
De 150 127 heeft zgn. Doppeldüsenlüfter (ventilatieroosters) met ronde hoeken, de 150 120 heeft Klattelüfter met rechte hoeken. Allebei de types hebben verticale lamellen.
Er waren ook nog 150ers (lage nummers) met Schweigerlüfter, deze hadden ronde hoeken en horizontale lamellen.
Arjen52
Oude meuk in h0
15 November 2023, 22:08:59 »
Op deze website staat de hele geschiedenis van de BR150 van Roco inclusief de detailverschillen tussen de verschillende versies:
http://www.bahnwahn.de/rocodb150/Geschichte/geschichte.html
Arjen
Cranicher Altbahn
Falkenberg
16 November 2023, 08:07:21 »
En alle Bauvarianten bij het voorbeeld vind je hier:
https://www.bundesbahnzeit.de/seite.php?id=607
Meer varianten dan Roco ooit kan maken
16 November 2023, 09:11:41 »
En tis een aardig lokje, gisteren nog mee gereden.
Alweer bijna 10 jaar in bezit, dat moet gevierd worden!
Roco 63712 DB E-lok 150 120-4 blauw/creme Wentink Doornenburg 18-01-14
Marco1044
17 November 2023, 18:58:01 »
En Luc, kan je hier wat mee? We horen het graag!
Gr Marco.
20 November 2023, 09:04:24 »
Ja Luc, je bent een vraagdraadje van jezelf toch niet weer vergeten?
Marco1044
20 November 2023, 20:12:35 »
Ik vrees het wel, gezien het uitblijven van een reactie op alle aangedragen verschillen tussen de locs.
Dit nodigt niet uit om je nog eens te helpen Luc!
Gr Marco.
Vinnie the who?
21 November 2023, 08:23:48 »
Overigens is het jammer dat Roco al z'n 150'ers voorziet van draaistellen met alle zandkasten; de helft is al vrij vroeg verwijderd. Vermoedelijk dus ook 1:1 bij deze 2 blau-beige uitvoeringen... iemand al eens gelukt deze netjes te verwijderen?
PS Piko heeft dit detail overigens wel meegenomen.
De groeten! Vincent
Arlbergbahn...?
Bf Kibronn
21 November 2023, 08:41:08 »
Piko is in ieder geval bij de groene 150 162 ook de mist in gegaan qua draaistellen, de 150 162 heeft bij Piko draaistellen met extra dempers, maar die werden pas bij een latere bouwserie gebruikt. En dat terwijl ze het juiste draaistel ook gewoon als onderdeel hebben, soortgelijke fout hebben ze gedaan bij de recent uitgekomen 110.3 in blauw-beige, die is uitgebracht met sneltreindraaistellen van de E10.12/13.
Storender (en opvallender) is dat Roco de hoogte van normale kastenlocs als uitgangspunt heeft genomen voor de E50, terwijl de lokkast van de E50 bij het grote voorbeeld 10cm hoger is. Dat valt met name op bij de fronten, doordat de ramen hoger zitten. Dat heeft Piko wel correct uitgevoerd.
Laatst bewerkt op: 21 November 2023, 08:46:13 door Quinzeedied
21 November 2023, 09:18:47 »
Nu ging het draadje niet over de Piko, maar we maken wel vaker mee dat de TS niet meer reageert dus maken we er maar ons eigen draadje van
Aangaande de Piko: van belang is denk ik wel te vermelden dat deze Einfach-lampen heeft, de laatst uitgebrachte Roco-modellen Doppellampen.
Juist bij Altbau-loks en ook meermaals bij Oostenrijkse vind ik Piko niet sterk in het smoelwerk van de verlichting. Ook deze uitvoering kan me niet overtuigen.
