Toon hier je pas gereed gekomen (model-)spoorbouwsels ... door Martijn193
Vandaag om 05:45:55
Vandaag om 03:15:40
Holland Scale huisjes bouwen en pimpen. door roadster36
Vandaag om 03:10:48
Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
Auteur Topic: Nieuwe fabrikant: YAMoRC: Yet another Model Railroad Company  (gelezen 68281 keer)
eichddraig
Re: Nieuwe fabrikant: YAMoRC: Yet another Model Railroad Company
« Reactie #150 Gepost op: 04 October 2022, 06:57:03 »
Of je stelt ze in met een pc die wel aan internet hangt en plaatst ze dan op je baan of zie ik dan iets over het hoofd?
gr. Ed
Martin Domburg
  • Discussie is gezond
    • Domburg Train Support
« Reactie #151 Gepost op: 04 October 2022, 07:46:38 »
Karst ,
dat is juist de moeilijkheid, die verfijningen.
Mijn PC van de baan staat niet in verbinding met het I-net ( te verouderde beveiliging - XP ), dan kan ik ze niet feiregelen met de PC doordat er geen I-net verbinding kan gemaakt worden.
Dan zal ik helaas voor uitbreiding moeten overschakelen naar Digikeys, nu Wim ermee gestopt is.
grtjs,
saskia
Je hebt geen internet nodig.
Download de software ergens naar een USB stick en installeer ze op de pc waar je baan mee word bestuurd.
En als het echt problematiek blijft, wij kunnen ze alvast voorinstellen voor je.
Verstuurd vanaf mijn SM-G996B met Tapatalk
Ik heb een mening, helaas uit ik die wel eens.  Ach ja beter een ster op je ring, dan een ring in je ster. Dan vallen je treinen om.
Hé een vogeltje! sorry waar ging het over?
Karst Drenth
    • Plan U op Sleutelspoor
« Reactie #152 Gepost op: 04 October 2022, 10:15:27 »
Hoi Saskia,
Citaat van: saskia
Alle YaMoRC modules zijn fabriek met instellingen voorgeconfigureerd, die voor ( naar onze schatting ) meer dan 90% van de gebruikers prima zullen zijn.
Van de spullen die je nu gebruikt, zijn naar ik zo beoordelen kan alleen de WDD's instelbaar. De rest heeft geen instelbare parameters, of zijn op dezelfde manier ( adres, aantal contacten etc. ) instelbaar als de YaMoRC modules.
Citaat van: saskia
Zoals Martin al schreef, je PC hoeft niet aan het Internet te hangen, zelfs niet aan een intern netwerk bij jou thuis. De Software kun je downloaden op een andere PC/Laptop en via een USB stick oid op je XP PC installeren.
Citaat van: saskia
Dat kan een goede optie zijn. De DR4088 ( s88) en de DR4088LN (LocoNet) hebben identiek hetzelfde ontwerp en zullen dus daarmee compatibel zijn.
Of de DR4018 ook compatibel is met de WDD van Wim, weet ik niet. Maar ik vermoed van niet.
Dat gezegd hebbende, zijn de YD6016ES zonder verdere "verfijningen" direct als vervanging van de s88 Melders van Wim inzetbaar. De YD6016LN, eveneens zonder verdere verfijning, als vervanging van Wim's LocoNet melders. Wat je bij de YaMoRC melders wel gratis erbij krijgt is de storingsonderdrukking aan de ingangen: zowel het hardwarematige filter als de stoorpiekonderdrukking in de firmware.
Pas als je de "special" features ( vrij adres per ingang, actie per ingang ) van de YD6016LN modules wilt gebruiken heb je een PC nodig.
De YD8008 als wisselspoelen-decoder heeft geen andere instelling nodig als het startadres. Deze stel je eenvoudig met het knopje in. Dat gaat geloof ik met de WDD net zo. De DR4018 heeft een dergelijke manier om een adres toe te kennen.
De YD8116 is in die zin een iets ander verhaal. Daar deze module zoooo veeeel meer kan dan de eenvoudigere WDD en 4018, zul je als je iets anders wilt dan 8 rood-groen seinen wel met de configuratie aan de slag moeten. Is 8 rood-groen voldoende voor je, is er ook hier weer het bekende knopje om de module een startadres te geven.
Grtzz en suc6 met je keuze,
Karst
saskia
« Reactie #153 Gepost op: 04 October 2022, 10:38:44 »
Karst,
bedankt voor de heldere uitleg.
Nu is alles véél duidelijker.
Mvgr,
Saskia
« Reactie #154 Gepost op: 04 October 2022, 10:47:50 »
Dus even voor mij concreet,
Ik heb Wim z’n s88 terugmelders
DCC ( dus met stroomdetectie) en de internetkabel ipv de platte s88
( wat is dat zo’n rj45 of zoiets)
En de keerlusmodules?
Met hartelijke groet.
Dave
Rheinburg tijdperk V/VI
Martin Domburg
« Reactie #155 Gepost op: 04 October 2022, 11:02:05 »
Dan heb je inderdaad S88n, wat momenteel de standaard is. S88 is met flatcable en dat is een achterhaalde methode. De n achter S88 staat voor netwerkaansluiting en dat is in de vorm van RJ45 connectoren.
Je kunt nu gewoon doorbouwen met elke willekeurige s88n module. Dus de YD6016ES, of de DTS88n modules.
Qua keerlusoplossing is die van Karst nog niet beschikbaar. Onze eigen keerlusmodule KeerPlus3 is vergelijkbaar met die van Wim en Karst en zal in de loop van de komende weken weer leverbaar worden.
« Reactie #156 Gepost op: 04 October 2022, 11:22:10 »
Mooi!
Bij Wim’s zat er een dingetje in om het signaal te versterken ofzoiets.
Dat hebben beide ook?
Dave
Karst Drenth
« Reactie #157 Gepost op: 04 October 2022, 15:53:08 »
Welk "Dingetje" bedoel je Dave ?
« Reactie #158 Gepost op: 04 October 2022, 16:16:02 »
Je weet wel  ;D
Er stond me iets bij dat er wat electronica inzit die het s88 signaal wat oppoets of versterkt.
Dave
Karst Drenth
« Reactie #159 Gepost op: 04 October 2022, 16:20:02 »
Hmm...
Ik weet alleen van de z.g. LocoNet-Voeding. Op s88 gebied weet ik het zo niet.
Wel weet ik, dat elke YD6016ES het s88 signaal opnieuw "genereert" ;) Zeg maar een "actieve" s88 bus ( ES-Link )
Grtzz,
Karst
« Reactie #160 Gepost op: 04 October 2022, 16:22:11 »
Het was een "signaal oppoetser", om verminkingen die onderweg ontstaan op te poetsen en kostte 2 eurokwartjes.
https://forum.beneluxspoor.net/index.php?topic=87334.msg3222000849#msg3222000849
Denk iets wat uitgelubberde flanken weer recht maakt?
Gr, Ben.
« Reactie #161 Gepost op: 04 October 2022, 16:25:27 »
Ok dat zal wel hetzelfde doen denk ik dan haha
Dave
Karst Drenth
« Reactie #162 Gepost op: 04 October 2022, 16:29:01 »
Citaat van: Ben
Ik denk dat ik weet wat dat is. En geen slecht idee. Misschien iets voor de YD6016ES REV.C ;)
De s88 signalen die in aanmerking komen zijn "Clock", "Load" en "Reset". :)
Dus antwoord op Dave... ==> nope, dat hebben de YD6016ES niet.
Grtzz,
Karst
  • DB Tijdperk III
« Reactie #163 Gepost op: 04 October 2022, 16:30:13 »
Dat klopt inderdaad.
Die Sauerlandbahn
Mijn YouTube-kanaal
« Reactie #164 Gepost op: 04 October 2022, 16:37:40 »
Karst,
Hoe zit dat eigenlijk met die ES-link (mits dit geen 'company secrets' zijn). Ik begreep dat je zo apparaten laat communiceren met elkaar dmv I2C. Doe je dat echt als bus zijnde, dus de eerste in de keten wordt master en de andere slaves. Of is het meer point to point tussen 2 modules? Ik dacht dat je met I2C en meerdere mogelijke masters niet kan uitvogelen wie de master taak op zich gaat nemen  ???
Ik zag ook een kastje waar je op de ES-link een RJ45 connector had gezet en die aan een S88 aansluiting had bekabeld van een ander kastje. Gebruik je in die opstelling dan ook I2C of S88 'protocol'. Doen je kastjes via I2C zelf uitvogelen of ze aan een ander zijn verbonden of niet?
Ik vind het hoe dan ook wel een.... eh een creatieve oplossing  (y)
Train-Science.com
Train-Science github
It ain't rocket science ;-)
