Molenbaan (werktitel)
sdz1976
om 00:19:12
01 February 2026, 23:44:43
Hout realistisch nabootsen
01 February 2026, 23:41:08
01 February 2026, 23:36:40
01 February 2026, 23:14:29
NMJ 2026
Dion
01 February 2026, 23:09:08
01 February 2026, 23:00:46
01 February 2026, 22:43:44
01 February 2026, 22:34:40
reinderlf
01 February 2026, 22:18:42
BR01 van Roco verfraaien.
01 February 2026, 22:09:34
01 February 2026, 21:57:01
Z21
Caspar25
01 February 2026, 21:42:39
Eindstation Daarhuizen
HenkN
01 February 2026, 21:41:32
T.Spat
01 February 2026, 21:38:17
Armita Wagons Amsterdam bv Tds
T.Spat
01 February 2026, 21:34:49
The Summer of 69
01 February 2026, 20:50:28
Inrijbaan 240x120cm
BramFokke
01 February 2026, 20:46:20
01 February 2026, 20:25:59
01 February 2026, 20:18:11
01 February 2026, 20:03:16
De donkere blauwe blokkendozen
01 February 2026, 19:15:05
01 February 2026, 18:49:40
ik kom er niet uit met de esu in de bigboy solderen
01 February 2026, 18:45:59
jack is back
01 February 2026, 18:19:43
Ronald A.
01 February 2026, 17:53:38
01 February 2026, 17:53:34
01 February 2026, 17:45:29
Traintastic - modelbaan besturingssoftware (gratis en open source)
reinderlf
01 February 2026, 17:20:06
reinderlf
01 February 2026, 16:27:08
Ronald gaat Duits met Johanneshausen!
Topic: Ronald gaat Duits met Johanneshausen! (gelezen 71136 keer)
Lucien
narrow minded and proud of it
Re: Ronald gaat vreemd! En bouwt een keertje Duits :)
Reactie #285 Gepost op:
16 June 2023, 18:09:32 »
Als je nog meer wil lezen over de Limburger ETA 176 heb ik nog een Lahntalbahn Special die je mag lenen.
Lucien
Modelrailroading is fun!
Reactie #286 Gepost op:
16 June 2023, 18:26:32 »
Ok man, dank voor het aanbod! Zeker interesse
Gerard van de Weijer
Reactie #287 Gepost op:
16 June 2023, 19:18:50 »
Jij gaat je echt duurzamer gedragen, van full dieselpower naar batterijstroom
Reactie #288 Gepost op:
16 June 2023, 19:27:31 »
Eric v C
Reactie #289 Gepost op:
17 June 2023, 10:55:56 »
Citaat van: Ronald Halma op 16 June 2023, 17:08:19
Vanmiddag nog even pootset 5 en 6 ingekort en daarmee dus 6 stuks voor 3 modules:
Tempo zit er goed in ;
Kijk waar we staan op
Reactie #290 Gepost op:
17 June 2023, 11:18:24 »
Dat is iig klaar
Wilde vandaag nog wat doen maar heb een andere verplichting. Komende week moet het iig op de poten staan en een keer gekoppeld zijn geweest.
Reactie #291 Gepost op:
18 June 2023, 22:33:38 »
Oke, was ik weer. Iig gelukt om het vandaag gekoppeld te krijgen en op de poten
Was even nodig om te kijken hoe de verschillende bouwwijzen van de bakken aan elkaar passen en of de hoogtes ook kloppen. En dat doen ze.
Eerst de middelste bak voorzien van een verstevigingkruis aan de achterkant:
20230618_151907
by
, on Flickr
Aan de voorkant van een "oude" schoor een versteviging gemaakt die je er zo in kunt drukken en die de poten aan de voorkant netjes op afstand houdt. Afgetekend:
20230618_150252
by
, on Flickr
Gezaagd (buiten!):
20230618_151020
by
, on Flickr
Geklemd:
20230618_151037
by
, on Flickr
En blokjes om hem op de plek te houden:
20230618_151836
by
, on Flickr
Rechtse bakkie er aan mbv lijmtangen:
20230618_152726
by
, on Flickr
Het geheel stond daarmee eigenlijk al heel stevig. Ik maak alleen nog onder de beide buitenste bakken een soort houder om de buitenste poten netjes rechtop te houden. Dit ook ivm het later afspannen met de afrokking op een tentoonstelling, dan blijft het geheel mooi strak in aanzien.
Dit strookje zit aan de middelste bak en moet nog aangepast worden. De rechtse is 36cm diep, de andere 2 zijn 40cm. Dat laat ik zo:
20230618_152917
by
, on Flickr
En bakkie 3 er aan:
20230618_155228
by
, on Flickr
Lijnt naar tevredenheid. Ik moet toch wel een hele lieve vrouw hebben toch?
Mijn tekening in 3'en geknipt en aangepast aan de bakjes. Bak 1:
20230618_160425
by
, on Flickr
Bak 2 geen foto gemaakt, bak 3:
20230618_160422
by
, on Flickr
En allemaal (los) op hun plek:
20230618_160743~2
by
, on Flickr
Zo is goed te zien wat kan en wat niet. Er zal her en der wel wat ingeschikt moeten worden maar veel is dat niet.
Frieslijstje van 17 cm hoog, deze wordt het:
20230618_161223
by
, on Flickr
Lijning van de achterkant, hier zie je goed de "sprong" van die 4 cm diepe door de verschillende bouwwijze:
20230618_181649
by
, on Flickr
Tot zover tevreden, alles is weer weg
Blijft wel een huiskamer. Maar wel fijn dat het kan en mag. Komende dagen aan de bakken wat aanpassingen make en de tussenschotten (wat het nu zijn) aanpassen cq weghalen zodat het 1 geheel gaat worden. Als dat klaar is gaan ze in de schuur op de poten om er verder aan te bouwen.
Later weer meer!
Duitsland TP III/IV
Reactie #292 Gepost op:
18 June 2023, 22:38:29 »
Goed bezig.
Grt, Ronald.
Reactie #293 Gepost op:
18 June 2023, 22:43:56 »
Dank je, ik hoop het
Tis nog een heel ding zo maar netto gezien 3,2 x 0,4 = 1,3 vierkante meter oppervlak. Relatief weinig modelspoorbaan dus dat zou redelijk vlot moeten kunnen
Duitsland TP III/IV
Reactie #294 Gepost op:
19 June 2023, 00:49:02 »
Ik denk er net zo over maar wel 2 x meer oppervlakte(2, 64 mtr). Mijn voordeel is wel dat de rails bijna compleet ligt. Nu alleen nog bedraden en dan komt het grote werk, de scenery.
Grt, Ronald.
Reactie #295 Gepost op:
19 June 2023, 06:28:50 »
Het hoeft morgen toch niet af? Of heb je al een datum ini de agenda staan om hem te showen?
Am Ende der Strecke
Den gamla sågverket (gepland)
Reactie #296 Gepost op:
19 June 2023, 08:52:17 »
Nee hoor, het hoeft morgen niet af
Maar hoe sneller op de poten, hoe makkelijker de bouw. En kan ik er doorlopend aan blijven werken
@Ronald; ja, als het staat eerst de rails en dergelijke en dan inderdaad naar het leuke deel; scenery!
Reactie #297 Gepost op:
19 June 2023, 15:15:47 »
Middelste bakje aangepast vanmiddag. Eerst de rechterkant die in de bak kwam (zie laatste bericht gisteren) afgetekend en de zaag er in:
20230619_140331
by
, on Flickr
Kiek!:
20230619_140519
by
, on Flickr
Dan de andere dichte kant. Die gaat open, een strook van 4 cm breed met een steuntje tegen de achterwand van 3 cm extra. Samen 17 cm en dat is.... de fries:
20230619_141157
by
, on Flickr
Gezaagd:
20230619_141410
by
, on Flickr
Onderkant aftekenen:
20230619_141538
by
, on Flickr
En zagen:
20230619_141653
by
, on Flickr
Plaatje voorzichtig loswrikken, zitten toch nog 3 grote spijkers in:
20230619_141703
by
, on Flickr
En los. E.e.a. nadien nog bijgewerkt:
20230619_141834
by
, on Flickr
Zoals misschien al gezien op wat foto's is dat deze bak nog 2 bouten had voor het dak vast te houden zeg maar. Het zat aan de open kant echter al gelijmd dus moest de rest ook zodat de bouten eruit kunnen. Dus even ruimte gemaakt:
20230619_142555
by
, on Flickr
Dat gelijmd en gespijkerd. Daarna de open kant voorzien van een versteviging en dat gelijmd en met lijmtangen vastgezet:
20230619_144358
by
, on Flickr
Binnenkant. Ja, ik had dat door kunnen laten lopen maar zo is het prima en het doet wat het doen moet; verstevigen
20230619_144406
by
, on Flickr
Staat lekker te drogen, deze bak is zover klaar nu. Later!
Reactie #298 Gepost op:
19 June 2023, 20:53:40 »
Klaar
20230619_204230
by
, on Flickr
Deze week even schuren en dan op de poten!
Duitsland TP III/IV
Reactie #299 Gepost op:
19 June 2023, 21:04:10 »
Mooi werk!
Grt, Ronald.
