Vandaag om 00:16:59
Welke centrale is betrouwbaar? door Michiel VL
Vandaag om 00:08:33
Vandaag om 00:05:01
Ondergrond modelspoorbaan door HenkN
25 January 2026, 23:34:12
Faller 2026 door Floris Dilz
25 January 2026, 23:33:48
24 en 25 Januari 2026 modelspoorweekend Ewijk door neudalhausenstadbahn
25 January 2026, 23:25:04
25 January 2026, 23:21:42
Au bord de la Cèze door WimNa
25 January 2026, 23:18:06
"Southern Pacific's Coos Bay Branchline in H0", een nieuwe thuisbaan. door NTeering
25 January 2026, 23:04:06
25 January 2026, 22:23:42
Länderbahn en Reichsbahn locomotieven. door wob
25 January 2026, 22:17:45
Toon hier je nieuwe (model-) spooraanwinst(en)... door 1200blauw
25 January 2026, 22:01:06
Toon hier je (model)TRAM foto's. door Charles_
25 January 2026, 22:00:08
Interesse stamtafel/club Amersfoort? door Sikko
25 January 2026, 21:56:58
25 January 2026, 21:46:52
Bruine NS 1200s - Treinsamenstellingen. door Vislijn
25 January 2026, 21:27:45
Zaterdag, 31 januari 2026 | 8e Ruilbeurs MSV Post B door Carl
25 January 2026, 21:27:21
25 January 2026, 21:11:21
25 January 2026, 21:03:30
Molenbaan (werktitel) door Marty
25 January 2026, 20:56:36
Modelbaan in schaal N - 520x80cm - schaduwstation door 1op160
25 January 2026, 20:56:17
Wissels omzetten met luchtdruk door Hans van de Burgt
25 January 2026, 20:55:54
25 January 2026, 20:42:00
Altbau e-loc BR163 zelfbouwen in H0 door Quinzeedied
25 January 2026, 20:31:37
Kortsluiting. Maar waarom dan toch? door puntenglijder
25 January 2026, 20:30:51
Oudere Marklin S3/6 opleuken door puntenglijder
25 January 2026, 20:27:23
25 January 2026, 20:22:14
Retrobahn goes to the States: Bergamot Creek door Frits C
25 January 2026, 20:15:02
Modelspoorfans in Amersfoort gezocht! door Martijnstein
25 January 2026, 20:03:36
De Oosthoek (lokaalspoorlijn periode III, diesel) door Ronald Halma
25 January 2026, 19:50:32
Auteur Topic: NS-200 Sik. Bouwproject in Spoor- 0 en Spoor-1.  (gelezen 83982 keer)
    • nulpunt
Re: NS-200 Sik. Bouwproject in Spoor- 0 en Spoor-1.
« Reactie #615 Gepost op: 09 September 2024, 22:39:03 »
Voor de deur bij de SGB.
Daar wilden ze ooit een replica maken. Mee begonnen en daarna.......
    • nulpunt
« Reactie #616 Gepost op: 11 September 2024, 13:07:41 »
Ik kwam er recent achter dat Valejo veel meer groen in de serie Model Air maakt, dan dat ik op de kleurenwaaiers zag. Wat een beetje groen in de richting had, heb ik besteld en vanmorgen wat testen gedaan. Mijn eerste keus valt dan op 71.265, 3e van rechts op de zwart gespoten messing plaat.
Ik ga deze kleur (met de airbrush) tzt. op de kap van de Sik spuiten...Spannend. Helaas werkt het weer vandaag niet mee. Regen en 13 graden.
55099
    • nulpunt
« Reactie #617 Gepost op: 12 September 2024, 16:55:36 »
Ik ben te nieuwsgierig om te wachten tot volgende week en het weer warmer wordt. Het kon misschien net, zo niet....overdoen. In ieder geval zit er nu een eerste dunne laag groen op en het lijkt me qua kleur niet verkeerd. Volgende laag zal zeker helderder worden. Zwart is de kap in ieder geval niet meer.
Buiten spuiten (14 graden) en daarna direct in de warmte binnen onder de afzuiging.
Voor mijn eigen boekhouding:
-nozzle 0,5
-1:1 verdund Valleo verdunner
-0,8 druk.
-spuitafstand 20 cm.
De HIAB-kraan is met XF-58 van Tamiya gekwast.
55246
« Laatst bewerkt op: 12 September 2024, 17:09:21 door FritsT »
    • nulpunt
« Reactie #618 Gepost op: 12 September 2024, 21:45:09 »
Het afwerken van al dat kleine grut kost veel tijd. Zandstralen en 2x spuiten.
Die klemscharen (Kocher), ik blijf ze ideaal vinden voor dit werk.
Ivo tB
« Reactie #619 Gepost op: 13 September 2024, 11:56:19 »
Mooie dingen. Ik gebruik meestal omgekeerde houten wasknijpers  :)
En dit keer geen spuitbus, maar gewoon met de airbrush. Oppervlakken zijn niet groot genoeg voor een spuitbus?
Ivo
    • nulpunt
« Reactie #620 Gepost op: 13 September 2024, 12:39:05 »
Nee, geen spuitbus deze keer. Gewoon eens wat anders dan gebruikelijk tegen de saaiheid. Maar na al dat instellen en schoonmaken weet ik het weer...spuitbus. Maar deze Sik probeer ik dus wel af te maken met de airbrush.
    • nulpunt
« Reactie #621 Gepost op: 14 September 2024, 16:44:00 »
Het groen zit er op.
Ongeduldig om de Sik af te gaan werken, maar de lak moet wel eerst goed uitharden. Wat dat betreft blijf ik aanhanger van de autolakken uit de spuitbus en niet van deze watergedragen lak voor modelbouw. Mooi maar kwetsbaar, dus achteraf nog een vernislaag nodig.
55607
« Laatst bewerkt op: 14 September 2024, 16:49:42 door FritsT »
lrrw
« Reactie #622 Gepost op: 14 September 2024, 17:08:52 »
Tevreden met de kleur?
    • nulpunt
« Reactie #623 Gepost op: 14 September 2024, 17:33:20 »
Nee, maar ik laat het wel zo want soms (zoals nu dus) moet je experimenteren. Een betere Valejo groen bestaat (nog) niet. Is deze kleur fout?..ook weer niet maar net niet wat ik in gedachten had al wist ik dat vooral eigenlijk ook al.
Een thinnerbad kan altijd nog.
Het iets grijze zwart komt door de belichting tijdens het fotograferen.
« Laatst bewerkt op: 14 September 2024, 18:59:55 door FritsT »
« Reactie #624 Gepost op: 15 September 2024, 09:55:24 »
Ik vind de groene kleur heel geslaagd. Het lijkt sterk op de tint die Philotrain heeft gebruikt. Het complete aangezicht verandert ook nog wanneer de bufferbalken rood zijn en de gele accenten zijn aangebracht natuurlijk. Ik zou het inderdaad lekker zo laten
    • nulpunt
« Reactie #625 Gepost op: 15 September 2024, 10:18:38 »
De kleur groen is zowat identiek aan de Philo, maar het is niet de kleur groen die ik voor ogen had. Ik wil ook geen fabrieksnieuw uiterlijk maar een Sik waarbij je ouderdom en gebruikssporen duidelijk ziet. Wheateren dus. Dan blijft het zaak om de ondergrond zo goed mogelijk te maken dus het groen is niet fout, maar.........te netjes.
Hetzelfde geldt voor die gele handrails...Op de Philo prima, maar niet op mijn model. Die worden wit met een gele waas en als ik dan nog niet tevreden ben...zwart.
En ik wil roest.
Modelbouw blijft illusie. ;D
Inmiddels al begonnen (tussendoor om 1 uur wel even F1 kijken) om het strakke uiterlijk wat minder strak te gaan laten lijken met behoud van deze kleur groen.
Een thinnerbad sluit ik nooit uit.
55809
« Laatst bewerkt op: 15 September 2024, 10:26:12 door FritsT »
Deetrein
« Reactie #626 Gepost op: 15 September 2024, 13:19:22 »
Op de groene Sikken die ik ooit gezien heb is het hele onderstel zwart Frits.
Dus naast de deur stopt het groen, jij hebt een groene baan doorgetrokken.
Maar misschien heeft jouw 'grote' voorbeeld dit juist wel.
Mvg, Erich
    • nulpunt
« Reactie #627 Gepost op: 15 September 2024, 15:18:23 »
Klopt, dat is zwart. Heb ik me nog niet mee bezig gehouden. Spuit- en afplaktechniek ging even voor.
Komt bij de definitieve afwerking, net zoals de kleur van de schoorsteen (nooit zwart) en de belijning.  Alles is bij dit "handmonster" nog mogelijk en zoals ik eerder zei, het thinnerbad kan ook nog.
    • nulpunt
« Reactie #628 Gepost op: 15 September 2024, 20:55:21 »
Afwerken kost tijd en geduld.
56010
« Laatst bewerkt op: 15 September 2024, 21:00:25 door FritsT »
    • nulpunt
« Reactie #629 Gepost op: 15 September 2024, 22:47:11 »
Ik heb er helemaal geen haast mee, maar het is gewoon leuk om de Sik te zien ontstaan. Morgen wat minder doen.  ;D
-Dat stuk groen van het machinistenhuis onder de voetplaat...moet echt zwart.
-Kleur lichtschakelaar nog uitzoeken.
-Kleur rangeer-drukknop idem.
-Trekstangen naar de zandstrooiers aflakken en monteren
-Handrails op de huif......kleur bepalen en monteren.
-Verticale handgrepen. Kleur...... (zoals de horizontale)
-Trekstang  naar de lamellen aan de voorkant aflakken en monteren
-Veertjes achter de deuren plaatsen
-Ramen er in zetten
-Treeplanken: zwart of aluminium kleurig.
-enz. enz.
Nog genoeg te doen.
« Laatst bewerkt op: 16 September 2024, 22:49:38 door FritsT »
