Stefan88
om 04:27:59
Frank103
om 00:45:29
om 00:39:04
Roco 2025
om 00:31:15
om 00:11:52
Wohnzimmer AW werkrapporten
om 00:06:32
Frans Peeters
31 January 2026, 23:49:58
Gare de Tannay, Frans N-spoor
31 January 2026, 23:49:20
Rsd1000
31 January 2026, 23:25:07
DCCNext probleem
gerrit1966
31 January 2026, 23:06:46
31 January 2026, 23:05:15
Rsd1000
31 January 2026, 22:32:18
31 January 2026, 22:28:35
31 January 2026, 22:23:53
31 January 2026, 22:10:48
31 January 2026, 21:05:28
Rivarossi 2026
Robert vh Prutsert
31 January 2026, 20:43:09
31 January 2026, 20:08:38
Bouw graafmachine Artitec.
Robert39
31 January 2026, 19:35:46
31 January 2026, 19:01:08
NL-modelspoor
31 January 2026, 18:49:59
31 January 2026, 18:32:39
31 January 2026, 18:19:47
31 January 2026, 18:02:32
31 January 2026, 17:59:01
WesleyMunnik
31 January 2026, 17:42:57
31 January 2026, 16:51:19
De Projecten van RetroJack
31 January 2026, 16:42:57
Nijmegen in h0
31 January 2026, 15:38:38
31 January 2026, 15:25:17
Roco H0 42200 Flexgleise 970 mm koppelen aan Fleischmann 6006 (Flex)
Topic: Roco H0 42200 Flexgleise 970 mm koppelen aan Fleischmann 6006 (Flex) (gelezen 2027 keer)
FTrains
14 September 2020, 16:07:52 »
Ik heb Roco H0 42200 Flexgleise 970 mm en Fleischmann Modelgleis Flexgleise 6006
Welke railverbinders heb ik nodig om deze soorten rails aan elkaar te koppelen?
gr. Fred
Laatst bewerkt op: 14 September 2020, 16:58:37 door FTrains
Lolke Bijlsma
Noorwegen jaren tachtig en negentig in HO (DCC)
Re: Roco H0 42200 Flexgleise 970 mm koppelen aan Fleischmann 6006 (Flex)
14 September 2020, 17:17:10 »
Fred,
De Roco flex is code 83 en de Fleischmann is code 100+. Roco heeft een speciale railverbinding voor dit soort gevallen:
https://www.roco.cc/en/product/22695-0-0-0-0-0-0-005003-0/products.html
Lolke
FTrains
14 September 2020, 17:27:59 »
Dank je!
Reinier Z.
14 September 2020, 17:42:12 »
Nee hoor, Roco 42200 is flex uit het oude 2,5 mm programma. Die Fleischmannrail is iets grover, 2,7 mm hoog dacht ik. Gebruik je Roco-verbinders uit het oude 2,5 mm programma, dan zal het even moeite kosten om die Fleischmannrail erin te krijgen, maar het gaat wel. Gebruik je Fleischmann-verbinders die bij dat Modellgleis horen, dan zal de Roco-staaf te los zitten. Ik zou de boel dan gewoon doorsolderen, dan zit het alsnog vast.
Reinier
Lolke Bijlsma
14 September 2020, 17:54:00 »
Bedankt voor de correctie. Ik had het Roco artikel nummer moeten opzoeken/controleren. Het is inderdaad de oude Roco 2,5 mm flex.
En dan is jouw advies om te solderen wel het beste.
Lolke
FTrains
14 September 2020, 19:43:20 »
Bedankt iedereen. Ik zal Roco railverbinders gaan kopen en daarna solderen, lijkt me idd de meest betrouwbare optie.
gr Fred
Die Bahn
14 September 2020, 20:44:27 »
ROCO Railverbinders voor de 2,5mm rails zijn niet of nauwelijks nog te verkrijgen.
Haal dus
niet
de 42610 of 42611, want die zijn voor de huidige ROCO code 83 rail met een railhoogte van 2.1mm
Je kunt dan beter de PECO SL-10 metalen raillassen en eventueel de PECO SL-11 kunststof raillassen aanschaffen.
Deze van PECO SL-10 is code 100 en zijn soldeerbaar.
Vriendelijke groet,
Erwin Prummel
FTrains
14 September 2020, 21:02:34 »
Erwin, bedankt voor de tip. Ga ik doen
Gr. Fred
14 September 2020, 21:12:36 »
Ik heb lang geleden Fleischmann Modellgleis en Roco 2,5 mm gecombineerd. Als je die zonder meer met een railverbinder aan elkaar zet, dan merk je het verschil van 0,2 mm toch wel bij het rijden. Je kan ze tegenover elkaar leggen, het hoogteverschil corrigeren en het daarbij laten. Met draadjes elektrisch verbinden.
