Piko 2026
Sicco Dierdorp
om 09:19:38
om 09:12:27
om 09:10:32
om 09:03:16
om 08:49:14
V200-G2000
om 08:33:33
VulcanRaven
om 08:04:39
om 04:56:16
om 01:15:06
Multimaus Zwart
om 01:10:26
Marty
om 00:50:22
borotof
om 00:29:24
19 February 2026, 22:45:52
Dirk
19 February 2026, 22:26:14
19 February 2026, 22:15:30
19 February 2026, 21:58:27
Stub switches
19 February 2026, 21:54:31
Menno de Vries
19 February 2026, 21:24:50
Trein Eindhoven Brussel?
Hlv53
19 February 2026, 21:09:45
Ertstreinen in HO
19 February 2026, 21:00:55
19 February 2026, 20:52:45
De eerste Ivo
19 February 2026, 20:49:36
weslyr
19 February 2026, 20:30:26
Daan Knoben
19 February 2026, 19:15:50
19 February 2026, 18:34:04
Joost O
19 February 2026, 17:19:49
Robert uut Salland
19 February 2026, 17:15:26
19 February 2026, 17:08:22
19 February 2026, 17:01:54
19 February 2026, 16:47:17
Overige spoorzaken
Grootspoor
Bulk Carrier takes out railroad bridge in Panama Canal
Topic: Bulk Carrier takes out railroad bridge in Panama Canal (gelezen 2321 keer)
28 June 2020, 09:47:42 »
A bulk carrier transiting the Panama Canal took out the railroad bridge in Gamboa
on Tuesday, causing major damage. The Panama Canal Authority said it is
investigating the accident and that ship transits are not impacted by the incident.
The railway bridge crosses the Chagres River in Gamboa, Panama. It is part
of the Panama Canal Railway which parallels the Panama Canal providing freight and passenger
service linking the Atlantic with the Pacific Ocean. Video showing the aftermath of the incident
shows a portion of the bridge collapsed into the water. The ship involved is the Cyprus-flagged MV
Bluebill, a 37,000 dwt bulk carrier built in 2004. AIS data shows the ship was transiting the Canal in
a northbound direction, from the Pacific to the Atlantic, after sailing from Korea. The AIS track
below shows the track of the Bluebill as it struck the bridge. In 2012, a video was posted online
showing a bulk carrier nearly hitting the Gamboa bridge, coming to a stop just meters away.
(Source:gCaptain/Tugs Towing & Offshore Newsletter
Laatst bewerkt op: 28 June 2020, 12:36:58 door Bert van Gelder. Reden: Hoofdletters vervangen
Modelrailroading is fun!
Re: BULK CARRIER TAKES OUT RAILROAD BRIDGE IN PANAMA CANAL
28 June 2020, 10:16:55 »
Leuke tekst Hans, maarre..... heb je ook foto's?
NL-modelspoor
28 June 2020, 10:53:38 »
Linkje:
https://gcaptain.com/bulk-carrier-takes-out-railroad-bridge-in-panama-canal/
Johan
Re: Bulk Carrier takes out railroad bridge in Panama Canal
28 June 2020, 13:38:30 »
Op verzoek van Ronald een en ander ter verduidelijking
28 June 2020, 14:12:34 »
Wim Hesselink
28 June 2020, 14:50:05 »
Die boten ook steeds! Eerst Leer, nu Panamakanaal... Het zou verboden moeten worden, die boten!
Groet, Wim
Nieuwe baan:
Kurtscheid
Strassenhaus im Westerwald, Duitse zijlijn, Ep IV, schaal N
https://forum.beneluxspoor.net/index.php?topic=102763.0
Oude baan: Altwied im Westerwald
http://www.n-spoorforum.nl/viewtopic.php?f=14&t=9256
Noordster
Online
28 June 2020, 17:11:42 »
De boten zijn niet zozeer het probleem, alswel de schepen!
Je vaart trouwens op aanwijzing van de loods. De ouwe is natuurlijk eindverantwoordelijk.
Aanvaringen met bruggen komen ook in Nederland vaker voor dan je denkt, denk ik.
MVG,
—-Peter.
28 June 2020, 17:19:24 »
Dit was een duidelijk geval van jammer waar zowel de loods als het gezag niets aan kon doen.
technisch probleem! het schip liep uit zijn roer en dan sta je als mens gewoon machteloos.
Zelfs een ankertje presenteren hielp in zo'n geval niets!
Noordster
Online
28 June 2020, 18:45:27 »
Aha, dank je. Dan heb je idd niet veel meer te koop.
Syb030
Ik ben ook: Sybs_modellen op insta!
28 June 2020, 20:29:35 »
Dat wordt repareren.... Hoe lang zou die spoorlijn dan nu buiten gebruik zijn?
Pauze
28 June 2020, 20:42:29 »
Kan die titel niet gewoon even in het Nederlands? Kleine moeite. Nu ziet het er uit als de titel van een spambericht...
28 June 2020, 21:35:23 »
Met die brug eruit zal het nog wel wat logistieke gevolgen hebben. Er zijncontainer schepen die om de diepgang te verminderen containers lossen aan de ene kant en weer een partij oppikken aan de andere kant. Of containers lossen die dan per trein naar de ander kant gaan waar een ander schip ze weer oppikt. Die schepen vervolgen dan heen reis aan de oost of west kust.
Voor het toeristen Vervoer maakt het niet uit……..die zijn nu toch niet.
26 jaaar geleden toen ik nog stagiaire was ook eens met een schip in dezelfde bocht uit het roer gelopen maar iets verder en aan de anderkant aande grond gelopen.
Toen zag die brug er zo uit, niet zo heel veel veranderd lijkt het
NL baan in Canada
https://forum.beneluxspoor.net/index.php?topic=71130.msg3221692419#msg3221692419
Overige spoorzaken
Grootspoor
