Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: Schellenbach mini project: Bruggen verweren  (gelezen 2130 keer)
Martin Domburg
  • Discussie is gezond
    • Domburg Train Support
« Gepost op: 13 January 2020, 23:37:08 »
Vrienden,
Vandaag heb ik mijn eerste stapjes gezet om mijn scenerybouw een flinke kick omhoog te geven. Ik ben gezegend met een vriendengroep met fanatieke proffesionele (BNLS) modelbouwers die me hebben gemotiveerd om niet langer genoegen te nemen met plastic look en feel. Dus om maar eens rustig te beginnen bij deze mijn eerste project: Het verkleuren en verweren van twee bruggen voor Project Schellenbach.
Ik doe dit buiten het draadje van Schellenbach zelf omdat daar momenteel een enorme klus gaande is met de sporen en techniek van het station en depot. Dat werkt alleen maar verwarrend.
Magoe, ik ben langzaam aan begonnen met het inslaan van Humbroll producten, waarom Humbroll? Ik kan er via DTS makkelijk aankomen voor weinig en das zeer prettig. Ook heb ik gekozen voor Acrylic verf vanwege het prettige schoonmaken.
Ik wil op Schellenbach waarin ik echt enorm veel tijd en energie heb gestoken in de complexe technieken en mogelijkheden natuurlijk niet opscheppen met de plastic looks. Maar mensen die me kennen weten dat ik maar techniek verzin om dit voor me uit te schuiven. Plankenkoorts? ja misschien, het is meer de nagst dat ik het verpruts. Maar een wijs man zei ooit....... als je niet start met de reis kom je nooit op je bestemming.
Dus vandaar dit draadje en dan komen we bij de Bridge (sorry kon geen bruggetje verzinnen)
20190911_232757 by Martin Domburg, on Flickr
Dit is de situatie, en dat lijkt natuurlijk nergens op.
Ik heb veel hulp gekregen en best veel goede adviezen en wilde alle technieken wel eens zelf ervaren. Nu was de eerste vraag voordat ik de bruggen in de juiste kleur ga spuiten: Wel of geen primer?
Ik heb "voorlopig" gekozen om de brug in Humbroll 87 matt Staal te spuiten met de airbrush. Omdat je Acryl verf makkelijk ervanaf spoelt met warm water heb ik eerst eens getest of het werkt zonder primer. Dus de bruggen in een sopje dreft ontvet en de airbrush aan de gang gezet:
Nou dat was geen succes:
IMG-20200113-WA0019 by Martin Domburg, on Flickr
Ook had ik de verf verdund met koelvloeistof (was ook een tip) maar dat leek helemaal nergens meer op. Dus snel de bruggen onder een warme kraan schoon gemaakt en opnieuw ontvet. De verf spoelde gewoon van de bruggen af, dus totaal geen hechting. Terwijl de bruggen lagen te drogen heb ik direct Humbroll Acrylic Thinner besteld, dat lijkt me een veilige keuze.
20200113_213234 by Martin Domburg, on Flickr
De brug weer schoon en plastic fantastic
Toch maar de Primer?
Nou daar heb ik geen spijt van gekregen, een nobrainer. Ik heb Humbroll acrylic Spray Primer 1 gebruikt. Met een paar drukjes op de knop waren de beide bruggen heel mooi gedekt in een laagje licht grijze primer
20200113_225904 by Martin Domburg, on Flickr
Mooi dekkend en egaal een kleine euforie, want nu kan ik dus niet meer terug. De volgende stap is het spuiten van de brugdelen in de staal kleur en dan iets wat ik echt nog nooit gedaan heb: Met poeders, airbrush, dry- en wetwash verweren.......
Nog even niet aan denken want dan heb ik nog de tijd om goede inspiratie op te doen voor lekker verweerde Duitste staalbruggen. Als ik op google ga zoeken zie je zoveel kleuren en maten van roest en vuil en UV-verkleuring.... Ben daar nog niet helemaal over uit.
Maar ik ben al met het eerste been op reis!
Groetjes Martin
Ik heb een mening, helaas uit ik die wel eens.  Ach ja beter een ster op je ring, dan een ring in je ster. Dan vallen je treinen om.
Hé een vogeltje! sorry waar ging het over?
Marco EB
  • spelen met Dinamo iTrain Digikeijs en treintjes
    • Het ontstaan van Trammenlandt. Hoe een test baantje uit de hand loopt.
Re: Schellenbach mini project: Bruggen verweren
« Reactie #1 Gepost op: 14 January 2020, 08:05:48 »
Gewoon beginnen.
Heel goed dat je ook aandacht geeft aan de scenery, want je hebt al zo veel tijd en geld in de techniek gestopt, het zou dan echt zonde zijn als je scenery dan tekort zou schieten.
Nadeel van scenery werk, er gaat heel veel tijd in zitten.
En hoe verder je komt des te beter je wordt.
mvg
Marco
Martin Domburg
« Reactie #2 Gepost op: 14 January 2020, 15:28:36 »
Nog bedankt voor je hulp kerel  (y)
ja inderdaad, als je maar reist kom je op een bestemming !
Martin Domburg
« Reactie #3 Gepost op: 14 February 2020, 16:16:32 »
Het is weer tijd voor een kleine update, door drukte en wachten op spullen heb ik eventjes niks kunnen doen. Maar vandaag toch eindelijk wat kunnen doen.
De afgelopen tijd heb ik met de resin printer een nieuwe loopplank en brugsteun geprint. Waren leuke oefeningen en het resultaat is wel bevredigend te nomen. Wel spannend was het of ik een geleiderail kon printen voor tussen de sporen. Helaas is N te klein of een railprofiel te printen, althans zover ben ik nog niet. Maar ik moet eerlijk zeggen dat ik dat ook wel iets onzinnig vind.
Wat ik nu heb weten te maken vind ik ook perfect:
20200214_115025 by Martin Domburg, on Flickr
Hij zit inmiddels in de primer, binnenkort even roestkleurig schilderen en dan de sporen in de brug verweren zodat de brug erin kan.
In de PLA printer worden momenteel twee brughoofden geprint die ik met albastine wil bekleden om een betonlook te creëren.
Maar terug naar de brug zelf:
Vandaag heb ik de staalkleur aangebracht. Ik ben hier echt onwijs tevreden mee hoe het is geworden!!!
20200214_151019 by Martin Domburg, on Flickr
20200214_151016 by Martin Domburg, on Flickr
ALs het droog is gaat deze in de matte blanke lak zodat ik ze kan gaan verweren. En daar kijk ik aan de ene kant enorm tegenop, aan de andere kant kan ik niet wachten om aan dat avontuur te beginnen.
Ik wil dit met acrylverf en poeders gaan doen. Maar ik heb nog wat moeite met het vinden van inspiratie. De meesten bruggen zijn of heel schoon of compleet verroest:
mjgdEnC by Martin Domburg, on Flickr
depositphotos_32528923-stock-photo-steel-truss-railway-bridge by Martin Domburg, on Flickr
78.571.780 by Martin Domburg, on Flickr
Ik moet nog even de juiste tactiek en plan van aanpak verzinnen om een mooi resultaat te krijgen.
Tot die tijd wil ik eerst gaan oefenen. Hiervoor heb ik besloten om dit rijtuig eerst aan te pakken:
20200214_153930 by Martin Domburg, on Flickr
Het voorbeeld:
img36 by Martin Domburg, on Flickr
Kortom spannend, heb er al zin in!
Martin Domburg
« Reactie #4 Gepost op: 15 February 2020, 23:47:36 »
Hier een big update :)
De proef met het rijtuig is helaas mislukt, het ging heel goed, maar als je te snel werkt en vergeet dat je de spuitbus Vernis eerst moet schudden..... Kortom het rijtuig is nu geheel wit........ Snel afscheid van genomen en rap met de brug verder :)
Eerst ben ik wat stijlen gaan proberen op de plekken die je niet zult zien. Voornamelijk met poeders van Anita Decor wat geëxperimenteerd. Kleuren als roest, aardegeel en aardebruin, groen, wit en zwart een kwastje hier en een kwastje daar. Met een wattenstaaf wat verdunnen en uitsmeren met thinner en zo een beetje rond gaan breien.
Letterlijk zonder enige inspiratie en met wat gezond verstand. Ik wilde hem zeker wat smerig hebben, maar een enorm gebrek aan consistentie in voorbeelden gewoon aan de slag gegaan en met dit als resultaat:
20200215_230755 by Martin Domburg, on Flickr
20200215_230800 by Martin Domburg, on Flickr
20200215_230810 by Martin Domburg, on Flickr
20200215_230815 by Martin Domburg, on Flickr
20200215_230820 by Martin Domburg, on Flickr
20200215_230830 by Martin Domburg, on Flickr
20200215_230838 by Martin Domburg, on Flickr
20200215_230845 by Martin Domburg, on Flickr
20200215_230945 by Martin Domburg, on Flickr
20200215_230949 by Martin Domburg, on Flickr
20200215_231558 by Martin Domburg, on Flickr
20200215_231601 by Martin Domburg, on Flickr
Ik vind de bruggen voor nu best wel heel erg mooi. Ik wilde nog wat expirimenteren met vochtstrepen maar die techniek beheers ik nog te weinig. Dus voor nu laat ik het nog even zo. Ik denk dat N zich daar ook niet echt toe leent, deze fijne detailering. Al ga ik daar nog wel eens mee aan de slag.
Waar ik wel blij mee ben is de groenaanslag, aan de koppen van de bruggen wil ik straks bossage en bomen plaatsen langs de rotswanden.
Voordat ik de bruggen ga plaatsen moet ik nog wat aan met de brughoofden. Ik heb gekozen voor betonnen brughoofden welke ik alvast met de 3D printer heb geprint. Ik wil dit in de primer zetten en bekleden met albastine en dit in betonkleur spuiten, wat verweren en begroenen.
Man wat is dit enorm verslavend zeg !
Groetjes Martin
Tulpendaal
  • Westlandbaan-Delft
    • DELFT
« Reactie #5 Gepost op: 16 February 2020, 06:47:07 »
 (y) Ja zon brug gaat echt leven met een beetje verweren. Ziet er zeer goed uit.  (y)
En tussen ons eigenlijk kan het niet verkeerd gaan als je natuurkleuren en poeders neemt. ;)
gr Joke
