Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: Welke (spuitbus)primer voor messing en styreen?  (gelezen 13544 keer)
  • Bestuur
lokloods
Re: Welke (spuitbus)primer voor messing en styreen?
« Reactie #16 Gepost op: 20 November 2019, 19:55:47 »
Helemaal eens met Frits T.
Een meer dan prima lak.
mvg
Wiebe
Joran
  • NS tijdperk IV (1981)
« Reactie #17 Gepost op: 21 December 2019, 17:43:02 »
Het is uiteindelijk Motip primer geworden. Wel veel spuitnevel. Vanwege het weer binnen gedaan in een grote kartonnendoos, maar dat is verre van ideaal. Hoe doen jullie dat met dit weer? Aangezien ik geen verwarmde schuur o.i.d.
« Reactie #18 Gepost op: 21 December 2019, 17:58:48 »
Ik gebruik altijd Motip autoprimer. De grijze. Dat Actionspul is op acryl basis en daar heb ik slechte ervaringen mee. Ik spuit tegen een stuk karton en heb in de andere hand een föhn. Zo blaas ik de lucht van me af en ik blaas elk dun laagje meteen droog voor het volgende laagje er op komt.
Albert
https://denapp.blogspot.com/
bellejt
« Reactie #19 Gepost op: 21 December 2019, 18:02:51 »
waarom geen goedkope airbrush aanschaffen ? Ding kost amper 10 euro bij onze ali en je kan een drukbus gebruiken om het goedkoop te houden in afwachting van een compressortje (50 euro).
« Laatst bewerkt op: 21 December 2019, 18:04:58 door bellejt »
  • Nervensäge.
    • belse roestkraam
« Reactie #20 Gepost op: 21 December 2019, 18:28:41 »
omdat zo'n goedkope airbrush met drukbus een draak is om mee te spuiten. Koop dan meteen een fatsoenlijke met compressor. kost je 1 loc.
Wil uit ZO drenthe
« Reactie #21 Gepost op: 21 December 2019, 18:29:28 »
Spuiten doe ik altijd buiten. Eh, alleen verf en water bedoel ik.
Bij spuitbussen na het spuiten de bus onderste boven houden en spuiten. Staat in de gebruiksaanwijzing. Doet iemand dat? Ik wel om de spuitdop schoon te blazen.
Bij een airbrush altijd gelijk na het spuiten de airbrush schoonmaken. Niet wachten, de verf droogt en je krijgt hem veeel moeilijker schoon, als je wacht.
Dit zijn dan ook gelijk de voor en nadelen van beiden.
Wil
Joran
« Reactie #22 Gepost op: 21 December 2019, 18:41:41 »
Die airbrush en compressor heb ik. Maar zo’n spuitbus leek me wel makkelijk. En op zich het resultaat is er wel naar.
Oh en dat ondersteboven doe ik nooit. Ik heb bakken vol caps liggen die ik eens in de zoveel tijd ff schoonmaak.
Carl
« Reactie #23 Gepost op: 21 December 2019, 21:33:48 »
Zelf spuit ik regelmatig wat onderdelen van brommers in de grondverf cq primer.
Daarbij kijk ik altijd eerst welk weer het is, bij veel wind begin ik er zo wie zo niet aan.
Motip spuitbussen primer werken perfect en is er in verschillende kleuren ( grijs en geelachtig )
Wat ik altijd doe is hele kleine laagjes aanbrengen en laten drogen en dan herhalen tot dat het gewenste resultaat er is.
De spuitbus werkt het beste als die op kamer temperatuur is, ook zorg ik dat de onderdelen dan op dezelfde temperatuur zijn.
Binnenkort ga ik het ook eens een kap van een locomotief ( die echt in erbarmelijke staat is ) in de primer spuiten en als ik die niet voor handen heb een wagon.
Na het spuiten met spuitbus altijd de bus op zijn kop en even het spuitkopje leeg spuiten  ;)
Maunsell
    • New Ponca Yard
« Reactie #24 Gepost op: 21 December 2019, 23:07:13 »
het is goed om de spuitbus eventjes 10' in heet water van de kraan te leggen (geen kokend water) De druk wordt iets hoger in de bus en die gaat dan ook fijner vernevelen.
Paul
  • Team Mitropa
« Reactie #25 Gepost op: 22 December 2019, 01:57:31 »
Laat de prijs geen maatstaf zijn voor het gewenste resultaat.
Ik ga niet zeggen dat de goedkoopste rommel is, maar kwaliteit kost over het algemeen iets meer en over dat laatste lees of zie ik niks.
In mijn bouwproject 8100 in schaal 1 heb ik een (niet goedkope) spuitbus op kleur laten maken. Dat zou Motip kwaliteit moeten zijn volgens de leverancier... nou, na even testen belande die (nog volle bus) in de ecocontainer. Model moest ook weer in een thinnerbad om alles ongedaan te maken.
Let op, het gaat dus niet om de verf zelf , maar om de nozzle van de spuitbus en dat zie je pas als je er mee werkt. Voor mij geen ander merk meer als Motip. Kwaliteitsspul.
Beste Frits,
Nou heb jij zulk mooi gereedschap waarvan bij de meeste van ons het kwijl over de schoenen loopt, ga je nou beweren dat je geen airbrush hebt?
Ook verf uit de spuitbuis spuit ik in een potje en gaat met de airbrush op het materieel. (y)
Groetjes Jan
Pjotr500
« Reactie #26 Gepost op: 22 December 2019, 10:35:59 »
Ik heb ook van alles geprobeerd.  Buiten werken, ramen open en kartonnen dozen. Als je met cellulose verf van Phildie werkt, kun je eigenlijk niet binnen aan de slag.
Uiteindelijk heb ik bij HBM een kleine opvouwbare spuitcabine aangeschaft met afzuiging.  De dampen worden nu naar buiten geblazen. De slang is aan het einde voorzien van een speciaal mondstuk, waardoor je het raam slechts op een kier hoeft te zetten.
https://www.hbm-machines.com/producten/airbrush/airbrush-spuitcabines/hbm-bd-512-airbrush-spuitcabine-met-led-verlichting-afzuiging-draaiplateau-en-filter
Mij bevalt dit prima.
Pieter
Maunsell
    • New Ponca Yard
« Reactie #27 Gepost op: 22 December 2019, 10:52:14 »
ik gebruik de spuitbussen van Citykingz (meestal bedoeld voor grafitti) maar van zeer goede kwaliteit. Ze hebben een enorme variatie en kunnen besteld worden online.
http://www.citykingz.com/
Paul
lrrw
« Reactie #28 Gepost op: 22 December 2019, 11:18:33 »
Joran
« Reactie #29 Gepost op: 22 December 2019, 12:06:13 »
Pieter
Ziet er interessant uit. Werkt dat ook goed met spuitbussen of alleen met airbrush. Heb het gevoel dat een spuitbus meer nevel produceert dan m’n airbrush.
