Vandaag om 00:16:59
Welke centrale is betrouwbaar? door Michiel VL
Vandaag om 00:08:33
Vandaag om 00:05:01
Ondergrond modelspoorbaan door HenkN
25 January 2026, 23:34:12
Faller 2026 door Floris Dilz
25 January 2026, 23:33:48
24 en 25 Januari 2026 modelspoorweekend Ewijk door neudalhausenstadbahn
25 January 2026, 23:25:04
25 January 2026, 23:21:42
Au bord de la Cèze door WimNa
25 January 2026, 23:18:06
"Southern Pacific's Coos Bay Branchline in H0", een nieuwe thuisbaan. door NTeering
25 January 2026, 23:04:06
25 January 2026, 22:23:42
Länderbahn en Reichsbahn locomotieven. door wob
25 January 2026, 22:17:45
Toon hier je nieuwe (model-) spooraanwinst(en)... door 1200blauw
25 January 2026, 22:01:06
Toon hier je (model)TRAM foto's. door Charles_
25 January 2026, 22:00:08
Interesse stamtafel/club Amersfoort? door Sikko
25 January 2026, 21:56:58
25 January 2026, 21:46:52
Bruine NS 1200s - Treinsamenstellingen. door Vislijn
25 January 2026, 21:27:45
Zaterdag, 31 januari 2026 | 8e Ruilbeurs MSV Post B door Carl
25 January 2026, 21:27:21
25 January 2026, 21:11:21
25 January 2026, 21:03:30
Molenbaan (werktitel) door Marty
25 January 2026, 20:56:36
Modelbaan in schaal N - 520x80cm - schaduwstation door 1op160
25 January 2026, 20:56:17
Wissels omzetten met luchtdruk door Hans van de Burgt
25 January 2026, 20:55:54
25 January 2026, 20:42:00
Altbau e-loc BR163 zelfbouwen in H0 door Quinzeedied
25 January 2026, 20:31:37
Kortsluiting. Maar waarom dan toch? door puntenglijder
25 January 2026, 20:30:51
Oudere Marklin S3/6 opleuken door puntenglijder
25 January 2026, 20:27:23
25 January 2026, 20:22:14
Retrobahn goes to the States: Bergamot Creek door Frits C
25 January 2026, 20:15:02
Modelspoorfans in Amersfoort gezocht! door Martijnstein
25 January 2026, 20:03:36
De Oosthoek (lokaalspoorlijn periode III, diesel) door Ronald Halma
25 January 2026, 19:50:32
Auteur Topic: Welke besturingssoftware kies ik?  (gelezen 13713 keer)
NTeering
    • ARduino Controlled MOdel RAilway
Re: Welke besturingssoftware kies ik?
« Reactie #15 Gepost op: 21 October 2019, 19:37:11 »
Railroad is in het Duits
Traincontroller(Railroad) is ook in het Engels. Die keus maak je bij de installatie.
Mvg
Nico
AlbertG
    • Modelbaan Den Akker / Rocrail / DCC-EX
« Reactie #16 Gepost op: 22 October 2019, 07:55:06 »
Kijk maar eens hier: https://wiki.rocrail.net/doku.php?id=video-tutorials-nl
Ik ben in 2012 zonder enige voorkennis begonnen aan een modelbaan (ik dacht dat er alleen Märklin bestond  :P).
Mijn eerste baantje lag op een stuk tafelzeil op zolder. Ik las een artikel over Rocrail en ben daar mee gestart. Ik heb nooit wat anders geprobeerd dus kan geen vergelijkend warenonderzoek advies geven.
Wat ik wel weet is dat Rocrail gratis is en er dagelijks een update uitkomt. De ondersteuning via het forum is goed en als je een goed idee hebt en op het forum zet kan het maar zo gebeuren dat het een paar dagen later in Rocrail zit.
Enige nadeel is dat de Nederlandstalige wiki niet goed bijgewerkt is, maar daarom heb ik de video's gemaakt. Als je de video's in volgorde bekijkt en eventueel toepast op een testbaantje kom je erachter hoe het werkt.
Succes met kiezen,
Albert.
Hartelijke groeten,
Albert.
Mijn Youtube kanaal: https://www.youtube.com/@Albert-DenAkker
« Reactie #17 Gepost op: 22 October 2019, 08:27:22 »
..... De eerste vanwege de mogelijkheden die het lijkt te bieden op het gebied van volautomatisch rijden. Ik wil uiteindelijk op een stoel voor de baan gaan zitten en tevreden kijken naar hetgeen ik gemaakt heb. .......
Dat kan elk programma denk ik wel, dat is het doel van deze programma's het volautomatisch laten rijden van de treinen.
...... en er dagelijks een update uitkomt. .....
Weet niet of dat een voordeel of een nadeel is? Komt er elke dag een update met nieuwe functionaliteit, of met een fix?
In het laatste geval is het programma blijkbaar rijk voorzien van bugs dat ze elke dag 1 of meerdere fixes kunnen uitleveren.
Ook elke dag nieuwe functionaliteit toevoegen lijkt me niet echt een sterk punt. Je krijgt dan puist op puist waardoor de kans op nieuwe problemen alleen maar groter wordt.
Roelco
Martin Hornis
« Reactie #18 Gepost op: 22 October 2019, 11:18:35 »
Bij I-train ervaar ik dat het zeer eenvoudig werkt. Enige wat ik niet onder de knie heb zijn de "acties" maar daar is een andere clubgenoot inmiddels behendig in.
Bij mij verdwijnen er in versie 5 (eind 2019/begin 2020) 36 acties doordat o.a. de aansturing van lichtseinen met cijferbak sterk verbeterd wordt.
Märklin K-rails met boogstralen > 500 mm; NS-lichtseinen met cijferbak: 4, 6 en 8 in één bak; iTrain; Intellibox I; OC32;
eigen treindetectiesysteem aangesloten op OC32;
controleprogramma voor OC32.
AlbertG
« Reactie #19 Gepost op: 22 October 2019, 12:07:22 »
Roelco
Hoi Roelco,
De update bevat zowel bugfixes als nieuwe functionaliteit en verbeteringen op bestaande functionaliteit op aangeven van gebruikers. Ik gebruik het programma sinds 2012 en installeer zo 1 keer per maand een update. Ik kan alleen maar constateren dat het programma zeer stabiel is.
Albert.
Hartelijke groeten,
Albert.
« Reactie #20 Gepost op: 22 October 2019, 13:27:51 »
Dan heb ik toch een ander idee van zeer stabiel.
Als klant zou ik iets niet stabiel vinden als er elke dag updates beschikbaar komen, en ik elke maand een nieuwe versie moet installeren.
Gebruik zelf koploper, weet niet meer helemaal hoe lang al, maar moet toch wel meer dan 15 jaar zijn.
En in die jaren misschien 10 verschillende keren een nieuwe versie moeten installeren. En de meeste keren daarvan was omdat ik nieuwe functionaliteit wilde gebruiken die toegevoegd was. en misschien 2 of 3 keer omdat ik een bug tegen gekomen was die opgelost was.
Als je het dan over zeer stabiel hebt.
Maar dat komt misschien ook door een generatie kloof waar bij de huidige generatie mobiele devices het de normaalste zaak van de wereld is dat die continue met internet verbonden zijn en elk gewenst moment een update kunnen binnen halen.
Moraal blijft denk ik dat er meerdere oplossingen zijn om een baan volledig te automatiseren, en dat verschillende mensen tot verschillende conclusies zijn gekomen. En als je voor jezelf ook z'n conclusie wilt trekken moet je gewoon een test baan maken, daar verschillende software programma's bij gaan gebruiken en dan voor jezelf kijken waar jij het beste gevoel bij hebt. En als het eerste de beste programma wat je probeert je geeft wat je nodig hebt, ach, dan hoef je misschien niet verder te testen, maar ook dat is dan een eigen conclusie.
Roelco
« Reactie #21 Gepost op: 22 October 2019, 14:20:25 »
Windows gebruiker?  8)
gruspoor
« Reactie #22 Gepost op: 22 October 2019, 14:42:07 »
« Reactie #23 Gepost op: 22 October 2019, 14:48:45 »
Ja.
AlbertG
« Reactie #24 Gepost op: 22 October 2019, 15:37:26 »
Volgens mij ging de vraag van de topic starter over welke software hij zou willen kiezen, niet over de stabiliteit van Rocrail.
Ik geef alleen 1 van de mogelijke opties aan maar blijkbaar heb ik bij een paar mensen op het verkeerde knopje geklikt  ;)
Albert.
Hartelijke groeten,
Albert.
« Reactie #25 Gepost op: 22 October 2019, 16:32:37 »
Nou ja, de Koplopergebruiker is/was gewend dat de gewone gebruiker nauwelijks als testmateriaal diende. Dat kan ermee te maken hebben dat Paul Haagsma een uitgebreid testpanel had dat een betaversies langdurig op echte banen probeerde. Hierdoor waren de meeste bugs er al uitgevist voordat een nieuwe versie op het publiek werd losgelaten. Maar dat kan een erg ouderwetse aanpak zijn.  ;)
Het is in ieder geval verleden tijd. Dat gezegd hebbende kan de huidige versie van Koploper meer dan ik ooit zal gebruiken. De stabiliteit van het OS boeit al helemaal niet, omdat de programma’s zo weinig vergen. Ik heb Koploper jaren op Windows 95 laten draaien. Dat veranderde pas nadat de oude Pentium1 dan toch de geest gaf. Voor een paar tientjes heb ik toen een laptop met Windows XP gekocht. Daar draait de laatste versie van Koploper nog steeds op. Stand alone, dus geen gezeik met virussen.
Overet
« Reactie #26 Gepost op: 22 October 2019, 21:07:37 »
Ik denk dat die vergelijking op meerdere fronten mank gaat. Frequente updates wil niet automatisch zeggen dat de software instabiel is. Het staat een gebruiker vrij om updates te installeren.
Verder heeft Paul Koploper in zijn uppie ontwikkeld, waarvoor hulde. Door het open source karakter van Rocrail wordt hier parallel door meerdere ontwikkelaars aan gewerkt. Als laatste is het in de huidige wijze van softwareontwikkeling gebruikelijk om frequent kleinere incrementen door te voeren. Zoek maar eens op termen als agile en scrum.
Tom
Plannen voor baan tijdperk III naar DB-voorbeeld. Roco Multi-maus/Maus2/MausR3, Z21, Mardec, Koploper of Rocrail?
  • Twentelijn 1968-1980
« Reactie #27 Gepost op: 22 October 2019, 22:41:09 »
Laten we proberen er geen discussie van te maken zoals 3-rail versus 2-rail. Vertel gewoon je eigen bevindingen. Wat vind je goed, wat valt tegen, waarom heb je er ooit voor gekozen en zou je het nu anders doen?
Bijzonder sterk punt Henk, dankjewel. Dat is precies hoe mijn configuratie gaat worden. Immers de Win7 PC gaat van het net af en wordt dus stand alone. Als dat met Rocrail niet mogelijk is, ik hoor op een ander forum ook geruchten over regelmatige crashes, dan is dat wellicht in die configuratie niet de beste keuze. Of jouw alternatief, Koploper, voor mij de beste keuze zou zijn weet ik nog niet. Zou je het in de huidige situatie nog steeds kiezen, wetend dat Koploper niet verder wordt ontwikkeld? Het is kennelijk stabiel, maar hoe toekomstvast is het als de hard- en software zich wèl verder ontwikkelt (nieuwe centrales, locs, OS etc.)? OK, je zet iets neer en het werkt, maar stel dat er eens iets stuk gaat (en dat doet het gegarandeerd een keer)?
« Reactie #28 Gepost op: 23 October 2019, 08:05:55 »
Je hebt een Ecos dus je begint al met een achterstand als je Koploper gaat gebruiken: het aantal lok functies is beperkt tot 20 en er kleven nog wel wat meer nadelen aan jouw keuze. En die Ecos is te duur om nu al afscheid van te nemen. Slimmeriken rijden allang op het LocoNet protocol, althans: als je dit soort issues belangrijk vindt.
Bovenstaand geeft aan hoe onzinnig de discussie is over wat de toekomst gaat brengen. Aan Koploper wordt niet meer gesleuteld maar je hebt evenmin de zekerheid dat dat bij iTrain wel het geval zal zijn in de toekomst.
Gr, Ben.
« Reactie #29 Gepost op: 23 October 2019, 08:53:23 »
Het is voor mij lastig om te bedenken wat ik zou doen als ik nu moest kiezen, omdat ik mijn bestaande kennis moeilijk kan wegdenken.  :)
Het is dus zaak dat je die kennis op gaat doen en ik denk dat er uit een dergelijk draadje niet zoveel nieuws meer komt. Ik heb zeer goede herinneringen aan mijn testovaal met aan iedere kant een inhaalspoor. Je leert in korte tijd een heleboel en het is een project dat ook nog eens af komt.  :)
Als ik jou was, zou ik zo'n ovaal maken. Het ovaal zelf vier blokken (twee bogen en twee rechte einden) en verder ieder inhaalspoor een blok. Zo'n inhaalspoor kan natuurlijk ook als opstelspoor of kopspoor functioneren. Ieder blok twee bezetmeldpunten en je kan verschillende programma's proberen.
Ik ga door met Koploper totdat er nieuwe ontwikkelingen zijn die dat onhandig maken. Maar die zie ik nog niet,
