om 13:12:59
om 13:06:48
om 12:55:13
Lucien
om 12:34:57
om 12:31:33
om 12:30:59
Wissel polijsten
om 12:09:16
om 11:47:55
Roco E94 Motor uithalen
om 11:39:58
om 11:30:43
om 11:02:53
om 11:01:02
om 10:50:28
om 10:40:56
om 09:56:08
om 09:44:29
om 09:39:32
om 09:33:41
om 09:21:46
om 07:15:30
21 April 2026, 23:19:15
21 April 2026, 23:14:57
21 April 2026, 22:24:30
Paulus
21 April 2026, 21:54:59
RikM
21 April 2026, 21:43:29
Robert uut Salland
21 April 2026, 19:41:26
Marcel112
21 April 2026, 18:55:17
tychoo
21 April 2026, 17:56:01
KoosDeJong
21 April 2026, 17:11:08
21 April 2026, 16:50:27
1/32 schaal, 'Papier Berken", andere bomen , grassen en meer.
Topic: 1/32 schaal, 'Papier Berken", andere bomen , grassen en meer. (gelezen 63240 keer)
Daniel Caso
Re: 1/32 schaal, 'Papier Berken", andere bomen , grassen en meer.
Reactie #75 Gepost op:
09 December 2019, 11:49:57 »
P1120087 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120088 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120089 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120091 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120092 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120094 (2)
by
Daniel Osvaldo Caso
, on Flickr
De volgende foto lijkt een 'bailaora é flamenco'
P1120095 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120097 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120098 (2)
by
Daniel Osvaldo Caso
, on Flickr
Daniel
Daniel Caso
Reactie #76 Gepost op:
09 December 2019, 13:06:41 »
Hier, René, de foto's van het gebladerte en zijn verhaal:
P1120100 (3)
by
Daniel Osvaldo Caso
, on Flickr
P1120101 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120102 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120103 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120104 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120105 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120106 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120110 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120112 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120113 (2)
by
Daniel Osvaldo Caso
, on Flickr
Het verhaal:
640/5000
Deze planten (die niemand heeft geplant) groeien overal op de trottoirs, in de spleet tussen het trottoir en de muur.
Ze zijn klein maar ongelooflijk sterk, zodat je ze hard moet trekken.
Zodra je met ze thuis bent, geef je ze twee of drie goede baden in water. (De hond van je buurman kan uitleggen waarom.)
Vervolgens laat je ze drogen van het bad (een of twee dagen, afhankelijk van het weer of als je schoonmoeder, vrouw, moeder, dochter en de kat je toestaan om ze op de vensterbank te laten drogen.)
Vervolgens stop je ze in de magnetron (ik gebruik een enorme magnetron die ik via Marktplaats voor 10 euro heb gekocht alleen voor de modelbouw) zodat ze diep binnen drogen.
Het is belangrijk dat u hierop let
1) temperatuur
2) het aantal minuten
Ik herinner me geen enkele van de twee, maar in elk geval elk type plant dat ik verwerk (veel!) Vereist een andere behandeling zodat ik begin met het plaatsen van slechts een kleine in de magnetron en ik zie wat er gebeurt.
(Ik schrijf dat op maar dan weet ik niet meer waar ...!)
Het hangt er ook van af of je ze met kleur (airbrush) gaat retoucheren of niet.
Zowel de Magnetron als het glycerinebad (we zien dat later) laten de kleur van de plant kracht verliezen, dus het is goed om de temperatuur en de tijd te reguleren.
Bij sommige planten is veel temperatuur en korte tijd beter, maar bij andere is het andersom, dus het is beter om kleine tests te doen voordat je de oogst riskeert.
Vervolgens doe je een 70% glycerine en 30% warm water (niet kokend!) in een kom en zet je de oogst in. Je laat het minstens twee of drie dagen op een plaats waar niet veel licht of koud ontvangt.
Daarna verwijder je de planten uit de bad en (als je wilt) was je ze met alleen water. (niet echt nodig als je ze niet ga airbrushen).
Als alles goed is gegaan, hebben de planten geen elasticiteit verloren, wel een beetje kleur, maar ze zijn net zo sterk als in het leven.
Nou: dat is wat ik doe.
Experts doen het anders :
(Sorry, geen idee van waar heb ik de tekst van hieronder gevonden. Wel op internet.)
Daniel
GLYCERINE BAD
Dit is niet echt een manier van drogen maar eerder een manier om bloemen lang te bewaren. Door deze techniek vervang je het vocht uit je bloemen en bladeren door glycerine. Hierdoor kunnen bloemen jarenlang worden bewaard. Er zal echter wel een lichte verkleuring optreden.
Glycerine kan je ook kopen in de hobbywinkel. Meng voor gebruik één deel glycerine met twee delen kokend water, roer goed en giet het mengsel in een vaas die groot genoeg is zodat je de bloemen rechtop kan zetten. Laat dit goed afkoelen. Laat je bloemen en planten vervolgens goed volzuigen met water.
Snijd de uiteinden van de stelen scherp af en zet ze in de vaas zodat ze ongeveer een 10 à 15 cm in de glycerine staan. Zet de vaas op een donkere koele plaats. Controleer nu en dan als het mengsel niet moet worden aangevuld.
De bloemen zijn klaar na 1 à 8 weken. Als de bloemen droog zijn haal je ze uit de vaas en spoel je ze af met water. Leg ze vervolgens te drogen op vloeipapier of een ander absorberend materiaal.
Daniel Caso
Reactie #77 Gepost op:
09 December 2019, 13:18:38 »
Hier een link naar mijn album over modelbouw foliage van SNHS (Surrounding Nature's Hobby Shop) waar alles is gratis:
https://www.flickr.com/photos/158027525@N08/albums/72157680274954328
Daniel
daempfer
Reactie #78 Gepost op:
09 December 2019, 15:42:57 »
Dank, Daniel voor uitleg en foto's! Daar is geen (on)kruid tegen gewassen
Dat spul heeft een mooie zwierige wilde vorm die je in werkelijkheid ook ziet en die ook wind suggereert.
En goed dat je linkt naar de foto's van de levende plantjes, anders had ik ze echt niet herkent.
Ik ga er buiten ook eens op letten of ik ze zie en dan kan jouw beschrijving van de verwerking mooi als naslagwerk dienen
Veel plezier met de verdere bouw!
René
Daniel Caso
Reactie #79 Gepost op:
09 December 2019, 16:16:42 »
Mijn plezier, René.
Als je nog vragen heeft bent je altijd welkom.
Daniel
Daniel Caso
Reactie #80 Gepost op:
10 December 2019, 14:35:25 »
De skeletten voor de groep bomen die de mangrove vzullen ormen, zijn klaar om hun foliages te ontvangen.
De details met droge pastel ontbreken nog steeds, maar om geen tijd te verspillen aan het detailleren van wat zal niet kunnen gezienb worden, zal ik dat pas doen als het gebladerte me laat zien wat blijft en wat niet.
In iedere geval ik ben echt blij met wat de crackelverf-heteluchtpistool team doet.
Volgende keer zal ik wel voor zorgen dat ik ook genoeg zwarte pigmentpoeder thuis heb om in de verf can mengen.
P1120129 (3)
by
Daniel Osvaldo Caso
, on Flickr
P1120132 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120133 (3)
by
Daniel Osvaldo Caso
, on Flickr
P1120134 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120135 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120136 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120137 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120138 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120139 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120140 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120141 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120142 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120143 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120144 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120145 (2)
by
Daniel Osvaldo Caso
, on Flickr
Meer in volgende post.
Daniel
Daniel Caso
Reactie #81 Gepost op:
10 December 2019, 14:42:14 »
Here we go:
P1120147 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120148 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120149 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120150 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120151 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120154 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120155 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120157 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120158 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120159 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120161 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120163 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120164 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120165 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120165 (3)
by
Daniel Osvaldo Caso
, on Flickr
En dat was het zo ver.
Daniel
Daniel Caso
Reactie #82 Gepost op:
10 December 2019, 18:01:41 »
De laatste boom van vandaag:
P1120176 (3)
by
Daniel Osvaldo Caso
, on Flickr
P1120173 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120180 (2)
by
Daniel Osvaldo Caso
, on Flickr
Daniel
Daniel Caso
Reactie #83 Gepost op:
15 December 2019, 12:31:28 »
Nou, hier en daar wat vooruitgang - vooral wat bomen - en nog een voorlopige 3D-schets (dat is een eufemisme voor gezond spelen met mijn speelgoed zonder speciaal doel maar mogelijkheden ontdekken).
Zoals gewoonlijk heeft nog niets een vaste plaats gekregen en ik vraag me af of het ooit zal gebeuren, omdat de vreugde van het kunnen veranderen en veranderen en blijven veranderen voelt als en meer organische versie van mijn eerste Meccano 64 jaar geleden.
Eigenlijk gaat elk object dat ik nu maak constant door hetzelfde heerlijke verwarrende proces dat lijkt te werken als een etherische magneet op de vreugde van het zijn. Nou ja, tenminste voor mij.
P1120281 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120284 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120285 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120291 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120290 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120292 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120296 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120297 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120298 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120299 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120300 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120301 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120302 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120304 (2)
by
Daniel Osvaldo Caso
, on Flickr
Daniel
Daniel Caso
Reactie #84 Gepost op:
15 December 2019, 12:45:27 »
Ja, na vier verschillende banen, de poor trreurwilgens staan ongeduldig te wachten dat een nieuwe lente zal zhun de mooie gebladerte herstellen. Dat zal binnenkort gebeuren.
Nee, ik heb nog niet, zoals had gezegd, de oude wortels van de mangrove boomen vervangen. Misschien later vandaag.
P1120305 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120306 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120307 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120308 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120316 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120317 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120318 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120319 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120321 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120322 (3)
by
Daniel Osvaldo Caso
, on Flickr
P1120322 (3)
by
Daniel Osvaldo Caso
, on Flickr
P1120326 (2)
by
Daniel Osvaldo Caso
, on Flickr
P1120328 (2)
by
Daniel Osvaldo Caso
, on Flickr
Dat was het tot nu toe.
Daniel
Modelrailroading is fun!
Reactie #85 Gepost op:
15 December 2019, 12:49:43 »
Daniel Caso
Reactie #86 Gepost op:
15 December 2019, 12:55:55 »
Bedankt, Ronald.
Magoo.
daempfer
Reactie #87 Gepost op:
15 December 2019, 13:10:35 »
Waue, dat ziet er fantastisch uit Daniel
René
Daniel Caso
Reactie #88 Gepost op:
15 December 2019, 13:33:15 »
Bedankt, René.
Ik ben wel behoorlijk ongeduldig nu omdat elke stukje ruimte lijkt te wilklen diicteren wat moet straks er op komen en ik wil natuurlijk dat stroom volgen maar ik weet dat als ik nit eerst ietjes verstandig doet straks heb ik een hoop mooie scenes maar de achtergrond blijft onvoltooid...
Hmm...
Hmm...
(Nee, Daniel; eerst moet de achtergrond klaar zijn!)
Daniel
BartvD
Relax, it is only a hobby.
Reactie #89 Gepost op:
15 December 2019, 16:16:00 »
Is gewoon top! Realistisch zoals het kan zijn.
Bart
Groeten uit Zeeuws Vlaanderen
www.flickr.com/photos/bvdoorn
De Fabriek een avontuur in spoor 0;
https://forum.beneluxspoor.net/index.php?topic=90042.0
Bij voorkeur in Schaal 0.
