Vandaag om 03:15:40
Holland Scale huisjes bouwen en pimpen. door roadster36
Vandaag om 03:10:48
Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
Auteur Topic: Bovenleiding op modulebakken  (gelezen 2224 keer)
arnaud-ns/htm
  • Nederlands - 1:87 - digitaal - HTM trams - mcc car system - hulpverlening
  • soms lopen men katten over de baan heen,,
    • arnaud's trein baan
« Gepost op: 03 January 2019, 00:29:43 »
Hallo allen momenteel ben ik wat aan het stoeien met een module bak. Nu ik portalen en rijdraad wil plaatsen hoe kan ik dit spannen op een loze bak maar zodat het wel los kan ?
De bak rechts is een blackbox zeg maar
Arnaud
H0 2-rail DCC & MCC
trein - tram - hulpverlening
iTrain V5 ultimate
lid van:
MSV De Drijfstang - Nunspeet.
2 rail DCC + Car System MCC.
showdagen oktober 2025: https://ap.lc/MKOqk
Ronald1974
Re: Bovenleiding op modulebakken
« Reactie #1 Gepost op: 03 January 2019, 10:24:50 »
Misschien geeft dit je een idee.
Mijn modelspoorbaan is uitgevoerd als module baan, en op de overgangen zijn de rijdraden afneembaar.
Dit is de overgang naar het schaduwstation ( opstelsporen).
M.v.g. Ronald.
arnaud-ns/htm
« Reactie #2 Gepost op: 03 January 2019, 13:52:36 »
Dat is een hele mooie optie maar de  vorige en volgende modulle zijn "leeg"  is nu nog een simpel rondje
ik zat gisteren niet op de pc toen ik hetplaatste  bij deze nog een foto
Arnaud
H0 2-rail DCC & MCC
iTrain V5 ultimate
lid van:
arnaud-ns/htm
« Reactie #3 Gepost op: 03 January 2019, 13:59:52 »
Arnaud
H0 2-rail DCC & MCC
iTrain V5 ultimate
lid van:
Frans Peeters
  • Gelukkig voor mij zit de laatste gek nog niet vast
« Reactie #4 Gepost op: 04 January 2019, 11:28:11 »
Je zal dan toch een "tijdelijke" constructie moeten opzetten met een pantovanger, anders gaat het niet lukken.
Je gebruikt een redelijk eenvoudige bovenleiding en de draden zijn behoorlijk dik, dus de oplossing zoals ze aangedragen werd door Ronald is een zeer plausible.
Wil je meer ingewikkelde dingen zien, kijk dan even hoe het bij "La Bosse", een Franse baan werd opgelost. Daar is de rijdraad 0,3mm dik.
Ook op "Vaerwegh Dok" werd de bovenleiding gemaakt met veerbronsdraad van 0,3mm dik en dat is een Belgische compound draad.
Frans
MTD treinenclub vzw Edegem - www.mtdtreinenclub.be -
Tentoonstelling MODELSPOOR by MTD - Hangar 27, Edegem (B) op 24 & 25 Oktober 2026
