Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: Voeding SPROG II V3  (gelezen 1805 keer)
Ronaldp
Voeding SPROG II V3
« Gepost op: 18 May 2018, 20:21:49 »
Wat voor voeding voor een sprogII v3?
Op de site van Sprog staat: SPROG II requires a regulated DC power supply of 12 - 15V.
Maar welke mile amper / ampere moet de voeding kunnen leveren.
Ga hem gebruiken voor uit lezen van de decoders. Rij n-spoor.
Zou deze bv kunnen?
https://www.gamma.nl/assortiment/q-link-ac-dc-adapter-300ma-6-pluggen/p/B547211
Deze geeft 12V / DC   en 300ma.
mvg ronald
Multimaus
Bezetmelders Rosoft
Servo decoders Rosoft
xTreme Keerlus Rosoft
Rails en wissel peco 55
Koploper
  • Spoor 0, dat wordt wel wat!
Re: Voeding SPROG II V3
« Reactie #1 Gepost op: 18 May 2018, 21:01:18 »
300 mA is voldoende voor uitlezen/programmeren. Voor inzet als Booster minimaal 1A.
http://www.sprog-dcc.co.uk/downloads/SprogIIv3UserGuide2-14.pdf
blz 5
vr. groet,  Hans
Menno
    • Mijn van-alles website
« Reactie #2 Gepost op: 19 May 2018, 00:52:23 »
Zou deze bv kunnen?
Doe die maar niet! Grote kans dat die voeding NIET gereguleerd is. Lees: bij 300 mA stroom trekken zal de uitgangsspanning de ingestelde spanning zijn, maar bij minder stroom loop je risico dat de uitgangsspanning stijgt.
Over het algemeen: als er niet bijstaat dat een adapter/voeding gereguleerd is, dan zal 'ie dat ook wel niet zijn. Ik vind de beschrijving dat je met de adapter verschillende apparaten kunt 'opladen' ook buitengewoon slecht gekozen. De adapter is absoluut geen oplader.
Ik zou gewoon iets beters kopen bij de Handyman of iets dergelijks.
Ronaldp
« Reactie #3 Gepost op: 19 May 2018, 08:41:44 »
Menno.
Heb jij een voorbeeld van welke voeding.Die wel geschikt is?
mvg ronald
Multimaus
Bezetmelders Rosoft
Koploper
Remco_Nzo
« Reactie #4 Gepost op: 19 May 2018, 13:55:38 »
ik zou iets pakken wat "gestabiliseerde voeding 12v" is.
een van de eerste google resultaten: https://www.kabeldirect.nl/gestabiliseerde-12v-voeding.html (geen ervaring mee)
Remco
N-spoor in de koelkast gezet - nu heerlijk bezig met LGB op zolder (dcc, multimaus, massoth, mardec, arloco)
Fritsprt
« Reactie #5 Gepost op: 19 May 2018, 17:43:30 »
Of deze.
Ik heb aan de Sprog een chassisdeel 5,5/2,1 gezet zodat ik de stekker van de adapter er af niet hoef te knippen. Ik gebruik de adapter ook voor andere dingen.
gr. Frits
« Laatst bewerkt op: 19 May 2018, 18:07:50 door Fritsprt »
Groet Frits
Ronaldp
« Reactie #6 Gepost op: 19 May 2018, 19:10:29 »
Is dat een gereguleerd voeding?
mvg ronald
Multimaus
Bezetmelders Rosoft
Koploper
Calimero
« Reactie #7 Gepost op: 19 May 2018, 19:46:21 »
Gezien de ruime U-in ..... Ja.
Het moet om die reden een geschakelde voeding zijn.
Groet, Ronald.
Fritsprt
« Reactie #8 Gepost op: 19 May 2018, 19:46:45 »
Ronaldp, je moet een gestabiliseerde voeding hebben. Alle moderne voedingen (zoals de hier getoonde voorbeelden van Conrad en Kabeldirect) zijn gestabiliseerde voedingen. Het kan zijn dat "gereguleerd"hetzelfde betekent maar dat weet ik niet.
Succes Frits
Groet Frits
Ronaldp
« Reactie #9 Gepost op: 19 May 2018, 20:00:14 »
Ops...bedoelde ook gestabiliseerde voeding.
De voeding van de gamma is dus ook een gestabiliseerde voeding?
mvg ronald
« Laatst bewerkt op: 19 May 2018, 20:02:01 door Ronaldp »
Multimaus
Bezetmelders Rosoft
Koploper
Calimero
« Reactie #10 Gepost op: 19 May 2018, 20:51:40 »
Zie de reactie van Menno. Het valt uit de info niet op te maken.
Groot kans dat er simpel een kleine trafo in zit met enkel een gelijkrichter.
Met wat geluk nog net een elco voor de afvlakking en dat is niet wat je
wil en/of nodig hebt.
Groet, Ronald.
Ronaldp
Multimaus
Bezetmelders Rosoft
Koploper
Calimero
« Reactie #12 Gepost op: 19 May 2018, 21:34:02 »
Dat zijn in ieder geval geschakelde voedingen en dus gestabiliseerd.
Groet, Ronald.
