24 en 25 Januari 2026 modelspoorweekend Ewijk door neudalhausenstadbahn
Vandaag om 00:29:38
Vandaag om 00:00:32
Brawa 2026 door grossraumwagen
24 January 2026, 23:40:44
Doornvliet door Ronzol
24 January 2026, 23:34:13
Condensator - Binnenverlichting en Decoder. door bask185
24 January 2026, 23:13:01
Japanse 2C2, 4-6-4, Hudson locomotieven in vele schalen. door minilocomaster
24 January 2026, 23:06:10
Baan weer opgebouwd na vervangen dakraam door minilocomaster
24 January 2026, 23:05:13
Bahnstrecke 5867 door 741230
24 January 2026, 22:50:51
Spur 0 1 Tage 2026 in Giessen (D) door Marty
24 January 2026, 22:34:05
"Southern Pacific's Coos Bay Branchline in H0", een nieuwe thuisbaan. door Hans1963
24 January 2026, 22:32:00
24 January 2026, 21:35:17
PB Models, ICR-rijtuigen door cor_b
24 January 2026, 21:12:14
Welke central is betrouwbaar? door Ronald Halma
24 January 2026, 20:13:51
Ontraxs 2026 door Ronald Halma
24 January 2026, 20:08:37
24 January 2026, 20:04:43
Baanplan De Oosthoek (h0, 360 bij 140) door Frans Peeters
24 January 2026, 19:28:07
Bruine NS 1200s - Treinsamenstellingen. door Ferdinand Bogman
24 January 2026, 18:54:47
Ervaringen met bezorgdiensten (PostNL, DHL, etc) door Charles_
24 January 2026, 18:51:22
Yamorc YD8116 & MP1 vraag door Bert_Apd
24 January 2026, 18:44:28
19 Toen door Keska
24 January 2026, 18:42:15
US diorama in H0 door gdh
24 January 2026, 17:19:28
24 January 2026, 17:11:28
Die Sauerlandbahn - Tijdperk III door Frank 123
24 January 2026, 17:00:50
heeft iemand ideeën voor een baan van 120CM bij 240CM? door Ronald69
24 January 2026, 16:47:55
24 January 2026, 15:50:12
Oudere Marklin S3/6 opleuken door Robkop
24 January 2026, 15:19:07
24 January 2026, 15:05:32
Handleiding Trix Express 2232 BLS 255 door stoombr38
24 January 2026, 13:36:46
ICR-rijtuigen, voor welk merk ga je? LSmodels, PBmodels, Exact Train of Piko? door Hammondman
24 January 2026, 13:28:12
Big Scale Trains - NS SLT in H0 door hmmglaser
24 January 2026, 13:11:19
Auteur Topic: Flexibele lijm  (gelezen 2070 keer)
  • Take It Or Leave It
Flexibele lijm
« Gepost op: 19 October 2017, 00:11:27 »
Er schijnt een flexibele lijm te bestaan van het soort zoals dat op stickers/plakband zit.
Handig om bv schroefjes meteen op een moeilijk begaanbare plaats te krijgen,
of andere kleine onderdelen flexibel op z'n plaats te houden.
Wie weet hoe die lijm heet en welk merk?
Re: Flexibele lijm
« Reactie #1 Gepost op: 19 October 2017, 09:18:20 »
Foto's worden nog wel eens met een soort rubberlijm geplakt. Kunnen ze later worden verwijderd.
Mijn dochter heeft zo eens een deur-poster opgehangen. Was na een paar jaar nog eenvoudig te verwijderen.
Ik dacht dat ze bij Action ook een magneet op een lange uitschuifbare houder hebben. Hiermee kan je vanuit je stoel een gevallen "speld" oprapen (niet zoeken in de hooiberg dus). Kan je ook zelf maken denk ik.
Je schroef oid moet dan wel van ijzer zijn.
Ronald Visser
Ferre
Re: Flexibele lijm
« Reactie #2 Gepost op: 19 October 2017, 13:04:42 »
Tacky Wax     https://www.hbmonique.nl/ad29-tacky-wax.html
Wax adhesive is ideal for holding figures and other tiny parts you may wish to reposition. Allows repositioning. Remove with warm water & soap.
Bullfrog Snot:
werd vroeger gebruikt als flexibele lijm, maar iemand is op het idee gekomen dat je er ook de tractie van je modellokomotieven mee kan verbeteren. Nu wordt dit verkocht als vloeibare anti-slipbandjes.
http://www.dcctrainautomation.co.uk/bullfrogsnot.html
Wat is je bedoeling?   Voor het opnemen van kleine onderdelen heb je ook nog:
Sticky Pick Up Pencil     https://www.yorkmodelrail.com/useful-bits/sticky-pick-up-pencil
Not a writing pencil but a pencil with a sticky wax lead - they hardly feel sticky to the touch but the sticky surface easily picks up small parts.
Use to pick up or move around small bits of models, etchings, transfers ect. making them easy to position properly - unlike tweezers there's no danger of squeezing too hard.
Can be sharpened with a pencil sharpener or craft knife.
mvg
Ferre
Re: Flexibele lijm
« Reactie #3 Gepost op: 19 October 2017, 14:54:58 »
De bedoeling is om de onderkant van een verende buisbalg van LS Models -flexibel- aan de bak te plakken.
Tacky Wax een idee?
Ferre
Re: Flexibele lijm
« Reactie #4 Gepost op: 19 October 2017, 19:18:06 »
Arnold,
Ik vermoed dat Tachy Wax niet "stevig" genoeg gaat zijn. Ik gebruik het om figuurtjes te plaatsen. Je kan ze makkelijk positioneren en eventueel later terug verplaatsen zonder beschadiging. Aangezien er bij normaal gebruik weinig kracht op een figuurtje komt, blijven ze netjes op hun plaats staan.
Als er teveel kracht op de buisbalg komt, zal deze ongetwijfeld vroeg of laat los komen.
Wanneer de buisbalgen elkaar niet raken, en er dus geen krachten op inwerken van de tegenoverliggende balg, zal het resultaat wel goed zijn.
Enige oplossing is uitproberen.
met vriendelijke groet,
Ferre
Re: Flexibele lijm
« Reactie #5 Gepost op: 21 October 2017, 17:43:07 »
Net Tacky Wax geprobeerd en momenteel voldoet het uitstekend (y).
Afwachten wat de eigenschappen naar een jaar zal zijn, maar dat merken we dan wel weer.
