Betrouwbare Stroomafname met Trix C-Rail door Blausee-Mitholz
Vandaag om 00:54:25
PB Models, ICR-rijtuigen door MikeMike
Vandaag om 00:49:59
NS Stempelautomaat 1:87 door Jos B.
Vandaag om 00:17:50
28 January 2026, 23:59:57
28 January 2026, 23:57:01
28 January 2026, 23:48:41
Minibaan Visserskaai H0 door HenkN
28 January 2026, 23:34:02
NS rongenwagen type S-HTS 89301-89330 door prutser
28 January 2026, 23:31:57
PIKO 2240 71096 uit de doos! door Ronald Halma
28 January 2026, 23:20:43
28 January 2026, 23:05:06
De Projecten van RetroJack door Wim Vink
28 January 2026, 22:46:44
28 January 2026, 22:30:12
28 January 2026, 22:30:11
Interesse stamtafel/club Amersfoort? door Rob Ellerman
28 January 2026, 22:25:55
Roco NS plan V door Sicco Dierdorp
28 January 2026, 22:12:17
Baanplan De Oosthoek (h0, 360 bij 140) door Eric B
28 January 2026, 22:02:31
3weg wissel rocoline in iTrain door Henk Veenstra
28 January 2026, 22:00:12
28 January 2026, 21:56:38
28 January 2026, 21:54:43
Blokken , secties en terugmelding ( Marklin Crail ) door R.C.Grootveld
28 January 2026, 21:38:29
Mte korting door weslyr
28 January 2026, 21:33:44
LEDs aansturen met oude Conrad stadsverlichting module (191906) door Klaas Zondervan
28 January 2026, 21:27:19
US diorama in H0 door RetroJack
28 January 2026, 21:10:12
Gare de Tannay, Frans N-spoor door Hatsune Miku
28 January 2026, 21:08:11
19 Toen door Ferdinand Bogman
28 January 2026, 20:54:11
Faller 2026 door Sven
28 January 2026, 20:46:59
Länderbahn en Reichsbahn locomotieven. door Ferdinand Bogman
28 January 2026, 20:36:37
Piko NS 5/600 Hippel 2025 door Mischa
28 January 2026, 20:33:06
camera roco db 180 z21.......... door ruudns
28 January 2026, 20:23:19
28 January 2026, 19:57:09
Auteur Topic: Sound verplicht?  (gelezen 10204 keer)
ingenium
  • TM
    • Modeltrein projecten
Re: Sound verplicht?
« Reactie #60 Gepost op: 04 February 2017, 13:30:39 »
Ja, de LokSound V4 kan 4-8 Ohm speakertjes aan. Die telefoonspeakers zijn bijna altijd 8 Ohm. Je kan er dan zelfs twee parallel zetten, dan zijn ze samen 4 Ohm.
« Reactie #61 Gepost op: 04 February 2017, 13:57:36 »
Dat heb je zelf niet in de gaten. Je denkt dat je nog leuk mee draait, maar ondertussen. ;D
Dat weet ik, maar daarom is nog niet alles wat ik wel of niet doe een generatieding. Dit niet. Uittgesloten dat 'jongeren' het soundgebeuren financieel in de lucht houden. Overigens ben ik voor een modelspoorder meer de tusseningeneratie.
Rondje_HO
« Reactie #62 Gepost op: 04 February 2017, 14:14:45 »
@Ingenium: bedankt, dan kan ik dat ook nog eens proberen als schuim niet voldoende werkt  :)
iarnrod
« Reactie #63 Gepost op: 04 February 2017, 14:31:04 »
Ik maak liever zelf de keuze LP/sound. Anders wordt de kakofonie te groot...
Modellen met 'verplichte ESU sound decoders' probeer ik te recycleren. De andere 'verplichte sound' modellen laat ik dan maar in de schappen liggen... .
De kleine, maar stilletjes aan alsmaar groeiende producent uit het Vlaamse Ingelmunster heeft het volgens mij goed begrepen...
Bij hun modellen maak je zelf de keuze tussen: met analoog brugstekker / basis digitaal / digitaal met geluid.
(Al heeft m'n geldbeugel het begrepen voor hun Budget-Line en niet voor hun peperdure B-Models) .
Kan je nadien, indien gewenst, alsnog gemakkelijk 'upgraden' (bij hun HLD T59 lijkt het wel wat moeilijker te liggen).
Enkele jaren terug kocht ik een Murphy Models "CIE Irish Rail GM 071 Class loc" (enkel geleverd met 'een 21p blanco plug'). Murphy Models ging wel in zee met ESU voor de een lopi en sound decoder, die je als Murphy Models decoders afzonderlijk kan aanschaffen. De sound versie kan je gewoon ook via de ESU webstek downloaden en in een 'blanco ESU sound decoder V4.0' overzetten
Maar The Belfast Modelshop bracht een eigen decoder met en een betere kwaliteit en met meer sounds op de markt.
De deur ging daar helaas op slot. En nu had ik graag een 2è gehad. (Blijkt een ZIMO te zijn)
Echter, die mannen zijn met de noorderzon verdwenen (zelfs niet meer op de Ierse fora te vinden).
Ikzelf heb niet veel kaas gegeten om CV's aan te passen. En ik zoek een methode om de ZIMO sounds over te zetten op een 2è geluidsdecoder...
Gr,
Jan
ingenium
  • TM
« Reactie #64 Gepost op: 04 February 2017, 14:34:25 »
Dan kan je lang blijven zoeken, want dat is nu juist de essentie. Je moet de file hebben om erop te kunnen zetten, anders zou je wel heel gemakkelijk alle fabrieksdecoders leeg kunnen trekken en zelf gaan programmeren. Daar hebben ze natuurlijk niet al die moeite voor gedaan. In jouw geval heb je gewoon pech, of je moet op ebay zo'n decoder nog eens tegen komen.
Martin Welberg
  • FYA !!!
  • OO. Organisatie OntraXS!
« Reactie #65 Gepost op: 04 February 2017, 14:48:00 »
Kijk, daar kan het dus al 3 keer fout gaan in de productie, zou dan ook voor alleen maar sound kiezen als fabrikant
  • Schwarzburg-Neuffen-Bahn
« Reactie #66 Gepost op: 04 February 2017, 15:48:07 »
Dat doet Brawa tegenwoordig ook met al hun nieuwe modellen. Of dat fout gaat in de productie ... ik heb er nog niet van gehoord.
« Reactie #67 Gepost op: 04 February 2017, 16:07:24 »
Bij Brawa kan je zelfs kiezen voor analoog zonder stekker. Voor de oprechte digitaalhater.  ;D
ZwolsBas
  • NL/NS vanaf 1945
« Reactie #68 Gepost op: 04 February 2017, 16:59:56 »
Esu loksound is ook bar duur in Plan U of DE-2 stellen, Roco sound modellen is het enkele tientjes... Plan V zonder geluid en met geluid, zonder geluid 2 decoders nodig gauw 60,- praat je nog over 2 tientjes verschil.
Menno
    • Mijn van-alles website
« Reactie #69 Gepost op: 04 February 2017, 17:42:37 »
Het is even een paar pagina's terug, maar:
Zeker bij elektrisch materieel dat op een wat hogere, constante snelheid rijdt, gaat het 'lokomotiefgeluid' volledig ten onder in windgeruis en contactgeluiden.
Dit geldt (wat mij betreft) toch echt niet voor de gemiddelde SGM en 1700 die voorbij komt sjezen.
Bij de SGM zijn de motorloze draaistellen duidelijk te onderscheiden van de motordraaistellen, die met een luid 'woem' geluid voorbij komen.
Ook de 1700 is niet te missen in een dubbeldeks-stam: de rijtuigen gieren alleen maar op de rails, de 1700 komt luid 'brullend' voorbij.
Voor mij hoeft het niet. Het gebrek aan bandbreedte van de luidspreker is voor mij de reden dat ik het een weldadige rust vind als het spul uitstaat.
Ik vraag me ook nog steeds af hoe het zou zijn als je een luidspreker zou maken die de volle lengte van een rijtuig in beslag zou nemen voor de lage tonen en 1 kleine voor de hoge tonen. Er zal vast een formule zijn om te berekenen hoe groot de spreekspoel moet zijn voor een goede lage-tonenweergave, maar het zou me niets verbazen als het met een grotere luidspreker al stukken beter wordt, maar ja, die ruimte is er vaak niet.
Hendrik Jan
« Reactie #70 Gepost op: 04 February 2017, 19:06:03 »
Analoge stoomloc met sound.
Het kan al jaaaren:
https://www.youtube.com/watch?v=nuwjUZCSB2Y
(soort van)
groeten
Hendrik Jan
-Billy Connolly
Martin Welberg
  • FYA !!!
« Reactie #71 Gepost op: 04 February 2017, 19:57:42 »
Zo man, een leuke voor de sound haters http://www.soundtraxx.com/dsd/soundcar/soundcar.php
  • Aachenau West
« Reactie #72 Gepost op: 06 February 2017, 09:16:54 »
Je kunt je ook afvragen in hoeverre het geluid van locs uit lang vervlogen tijden (min of meer) realistisch weergegeven kan worden. Het moet een gok zijn hoe dat echt geklonken heeft.
Mijns inziens is dat zijdelings ook een argument om sound niet standaard aan te bieden.
  • Nervensäge.
    • belse roestkraam
« Reactie #73 Gepost op: 06 February 2017, 10:01:33 »
Net als de kleur soms ook een gok is. Dan maar niet meer standaard in de verf zetten?
  • Modelspoor is emotie...
« Reactie #74 Gepost op: 06 February 2017, 11:02:05 »
 ;D ;D ;D
Tbinnebarretije…
