H0e pizza layout door Sven
18 February 2026, 23:50:13
Minibaan Visserskaai H0 door Ronzol
18 February 2026, 23:48:26
Spoorwegmuseum in zwaar weer door Eelco Storm
18 February 2026, 23:23:17
Multimaus Zwart door Lars Smelter
18 February 2026, 23:21:35
MERG CBUS/VLCB gebruikers? door reinderlf
18 February 2026, 23:20:37
18 February 2026, 23:16:26
18 February 2026, 22:35:13
18 February 2026, 22:01:04
Fabrieksplaten NS E-lok 1600 en 1700 door Jos B.
18 February 2026, 21:57:36
18 February 2026, 21:47:52
18 February 2026, 21:46:44
Show je realistische treinsamenstelling door Benelux795
18 February 2026, 21:29:58
carnaval door Remunj
18 February 2026, 21:28:39
Fleischmann 1898 set analoog>digitaal door henk
18 February 2026, 21:18:26
18 February 2026, 21:03:17
Houten Plus zaterdag 21 februari 2026 door Ronald A.
18 February 2026, 20:59:36
HS 4de klasse Staatsspoorstation door jdk
18 February 2026, 20:58:41
Jeugdbaan - VvMrZ door Jelmer
18 February 2026, 20:22:41
18 February 2026, 19:29:43
De bouw van mijn modelbaan in Thailand door Eric B
18 February 2026, 19:23:18
18 February 2026, 18:58:55
Cv instellingen Fleischmann Sprinter door Luud H
18 February 2026, 18:19:54
The Summer of 69 door Robkop
18 February 2026, 17:56:21
18 February 2026, 17:48:27
18 February 2026, 17:24:52
18 February 2026, 17:17:00
Lima IRM gaat niet lekker door de bocht door ceuleer
18 February 2026, 17:16:00
DJH E127 NS 3300 door orientexpress
18 February 2026, 17:04:58
Bauarbeiten im gange door Ronald Halma
18 February 2026, 15:57:03
18 February 2026, 15:23:46
Auteur Topic: 5V voeding S88 interface  (gelezen 2906 keer)
Marcel-v-R
« Gepost op: 17 October 2007, 10:56:19 »
Ik rijdt met MRdirect. Maar nu wil ik een S88 inteface maken. Hiervoor heb ik een 5V voeding nodig welke is goed(koop). Conrad bestelnummer?
Alvast bedankt voor jullie reactie's.
Marcel
Robert E
    • Robert’s Modelspoor Pagina
Re: 5V voeding S88 interface
« Reactie #1 Gepost op: 17 October 2007, 13:09:51 »
Onder andere
190809 - 89
300mA lijkt me wat weinig
Zie ook
http://www.circuitsonline.net/circuits/view/30
als je zelf beetje hendign bent met soldeerbout, moet wel met MrDirect  ;D
Robert
MDRRC-II (Lite) goedkope DIY centrale voor DCC en MM.
Heb je een vraag, stuur me dan een mail via mijn site ipv persoonlijk bericht...
Delftinhetklein
    • bouweninhetklein
« Reactie #2 Gepost op: 17 October 2007, 14:30:06 »
Ga naar een gemeente afvaldump. Vraag of je mag zoeken in de bak met afgedankte electronica. Zoek voor een afgedankt pc want een beetje pentium III is al afval tegenwoordig. De voeding van de gemiddelde pc heeft +5V en 12V uitgangen en zijn nog gestabiliseerd ook.  Gratis ;D
Marcel-v-R
« Reactie #3 Gepost op: 17 October 2007, 15:19:50 »
Erwin dat is een goed idee. Kan er nog wel ergens eentje vinden. Zou ik trouwens gewoon de voeding van de mrdirect pc kunnen gebruiken.
Marcel
« Laatst bewerkt op: 17 October 2007, 15:33:35 door Marcel »
Robert E
« Reactie #4 Gepost op: 17 October 2007, 15:44:55 »
Je kunt de 5Volt inderdaad aftappen van de 5Volt uit je MrDirect Pc.
Zet er echter een glaszekering in, bij sluiting op S88 bus pin 2 en 6
om welke reden dan ook krijg je tot 10A door je draden e.d. van de
PC voeding en dan is het einde oefening denk ik van de printplaten /
S88 bedrading,  die kunnen echt geen 10A hebben die spoortjes.
Trouwens, een losse PC voeding moet een of andere schakeling hebben
voor het powergood signaal..
Robert
RoSoft
« Reactie #5 Gepost op: 17 October 2007, 15:52:03 »
Of gewoon zo
Mvg
Wim.
wim helsen
« Reactie #6 Gepost op: 24 January 2008, 15:45:50 »
hoi Wim,
Ik ben ook al een tijdje bezig met MR-Direct en zou  nu ook die s88 interface willen maken.  Ik ken zelf niets van elektronika, maar wil het wel leren. En via jouw schema's lijkt het allemaal wel simpel.
Maar zoals je hier op de print de aanpassingen hebt gedaan, is dat ook zoals je foto op je site. Of is dat nog een andere voeding.
En welke onderdelen komen er dan nog bij?
Mvg
Wim Ros
  • BHV
    • Perrongeluk
« Reactie #7 Gepost op: 24 January 2008, 16:04:26 »
Zoals al in het bovenstaande plaatje aangegeven.
4 x 1N4001 (diodes)
1 x 7805 ( spanningsregelaar)
1 220uF 25V (elko)
Mvg
Wim.
Rieks
  • Helemaal opnieuw begonnen
  • Fiat Voluntas HrMs Poolster A835
« Reactie #8 Gepost op: 24 January 2008, 19:48:59 »
Kijk maar even hier voor dat powergoodsignal.
Ian heeft nog wel meer leuke dingetjes.
Listen very carefully, I shall say this only once.
Cetero censeo birrum  bibendum esse
Dave van der Locht
« Reactie #9 Gepost op: 24 January 2008, 22:07:44 »
4 x 1N4001 (diodes)
1 220uF 25V (elko)
Mvg
Wim.
Dit is volgens mij toch de meest eenvoudige oplossing... Gewoon een standaard spanningsregelaar met een afvlak-elco (en de gelijkricht-diodes uiteraard).
Echter (ook afhankelijk van de belasting), is het bij een voedingsspanning van 16V AC (gelijkgericht hou je +/- 21V DC over) niet geheel onverstandig om de 7805 van een koelribje te voorzien.
De 7805 kan met een dergelijk verschil tussen de in- en uitgangsspanning behoorlijk heet worden en de max. stroom drastisch verlagen door de temperatuurbeveiliging.
Groetjes,
Dave
Beter een gat in een trein, dan een trein in je gat.
wim helsen
« Reactie #10 Gepost op: 25 January 2008, 09:17:37 »
vrienden van de elektronika,
mijn boodschappenlijstje is bijna volledig, nu nog een domme vraag om te laten zien dat ik echt niets van elektronika ken.
Ik zie op die strokenprint (foto op website Wim Ros), dat die doorverbindingen maakt met kabel. Wat voor soort kabel is dit? (ik bedoel dikte of doorsnede, soepele of stijve kabel).
En op die lpt connector worden de pinnen 18 tot 25 doorverbonden voor de GND. Hoe doe ik dit?
dank bij voorbaat
Wim Ros
  • BHV
    • Perrongeluk
« Reactie #11 Gepost op: 25 January 2008, 09:50:21 »
Je bedoeld die wit groene draadjes?
Dat is een vaste kern
Dikte maakt niet uit zolang het maar in het gaatje past.
Die verbinding maak je door er een draadje overheen te solderen met een vaste kern.
Mvg
Wim.
wim helsen
« Reactie #12 Gepost op: 25 January 2008, 10:01:25 »
dank u Wim,
maandag ga ik alles aankopen en zal ik tevens beginnen aan mijn proefstuk.
Ik hou jullie op de hoogte.
groeten
RobE
« Reactie #13 Gepost op: 25 January 2008, 13:35:28 »
Hallo Wim,
Heb je al eens overwogen om een HSI-88 te kopen.
Deze werkt erg goed en omdat je zelf al aangaf niets van electronica te weten zou dit misschien een optie zijn.
Zelf heb ik de S88 interface gebouwd en deze later vervangen door de HSI-88 interface.
Het is maar een idee.
Rob
Rob is op 4 februari overleden.
Edits Booster, MRdirect, Koploper, HSI-88, Zimo, HO, 2 rail
wim helsen
« Reactie #14 Gepost op: 27 January 2008, 17:22:16 »
hoi Rob,
heb ik over nagedacht, maar de prijs(90 euro) houdt mij tegen. Voor die prijs koop ik liever rollend materiaal.
Ik heb er op deze forum al enkele artikels over na gelezen, en het lijkt simpel. Dus ga ik het zo proberen.
in ieder geval, bedankt voor de tip, maar waarom heb je dan toch een HSI 88 gekocht?
groeten
wim
