om 00:24:44
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?"
Michiel VL
26 January 2026, 22:59:31
EifelBurgenBahn
26 January 2026, 22:45:26
HeVe01
26 January 2026, 22:44:28
Heiko
26 January 2026, 21:45:15
Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
Carl
26 January 2026, 21:27:09
Faller 2026
26 January 2026, 21:09:37
Kippenlijn of Valleilijn
Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan
26 January 2026, 20:57:31
Christoph
26 January 2026, 20:50:23
Da's Daz 2
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel)
sdz1976
26 January 2026, 20:04:08
26 January 2026, 19:53:54
26 January 2026, 19:36:57
Rsd1000
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005
ns.1200
26 January 2026, 18:42:35
René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6)
Maikel van Velzen
26 January 2026, 18:24:45
william_2
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris.
26 January 2026, 17:15:20
Jouef BB9201 anno 1968
saskia
26 January 2026, 16:51:03
Havenbaantje, Duitse havenstad, periode 2e wereldoorlog.
Topic: Havenbaantje, Duitse havenstad, periode 2e wereldoorlog. (gelezen 406720 keer)
AndréDev
Een trein is nooit genoeg
Always on track!
Re: Havenbaantje, Duitse havenstad, periode 2e wereldoorlog.
Reactie #1665 Gepost op:
16 March 2021, 21:38:07 »
Weet ik toch Ronald
We kennen elkaar al wat langer
Laatst bewerkt op: 16 March 2021, 21:41:41 door AndréDev
Groetjes,Dames en Heren
André
Some trains never roll.
AndréDev
Always on track!
Reactie #1666 Gepost op:
17 March 2021, 16:08:57 »
Help!
Heeft of weet iemand scharfenberg koppeling[en voor de roco VT601??
Valt dat ding eerst om tijdens de rit kom er tijdens het oppakken achter dat een van de wagens de koppeling mist.
En aangezien ik duwende reed[motorwagen achter] viel dat niet meteen op.....
Roco weet van niets en Huider heeft het ook niet maar misschien hier iemand??
André
Team forummoderators
Reactie #1667 Gepost op:
17 March 2021, 16:14:59 »
Volgens
deze
pagina bij Roco is zo'n koppeling nog leverbaar:
89226 Scharfenberg Kupplung 1,95 € [Lieferbar] [In den Warenkorb]
Reactie #1668 Gepost op:
17 March 2021, 16:22:21 »
Die dingen ken ik nog, op mijn 3-rail variant had ik metalen stroomdoorvoerende functionele scharfenberg koppelingen. Ik heb ze tijden geleden al weggegooid. Die koppelingen volstaan niet in hun basisfunctie. Ze werken niet. Je kan er niet mee duwen en bij trekken lieten ze zo los.
Roco heeft steeksleutel vormige plastic koppelstangen uitgebracht die over de daaipunten van die wielstellen heen klikken. Ik kwam er achter dat roco ze ook hadden uitgevoerd met een stuk koper voor de stroomgeleiding. Die had ik eigenlijk willen hebben. Ik had ze destijds ook bij Huider besteld
De eerste beste google search
https://www.ebay.nl/itm/Roco-89212-Kupplungssatz-Kontakte-Vt11-5/402708285266?hash=item5dc348c752:g:D34AAOSwczxflF-d
https://www.roco.cc/de/service/spareparts/index.html?p=y&ssp=89212
De roco site zegt: 'lieferbar'
Train-Science.com
Train-Science github
It ain't rocket science ;-)
AndréDev
Always on track!
Reactie #1669 Gepost op:
17 March 2021, 16:46:00 »
Bas!!vriend
In de doos zelf zit een zakje met steeksleutel achtige dingen waarvan ik geen idee had waarvoor die zijn....
Daarvoor dus!toppie!!dankjewel voor het wijzer maken vandaag
BTW,mijn wagens zijn onafhankelijk verlicht dus niet met doorvoerkoppelijg.
André
AndréDev
Always on track!
Reactie #1670 Gepost op:
17 March 2021, 17:15:49 »
Dankjewel Jan
Altijd handig om te weten en te bestellen natuurlijk
André
Reactie #1671 Gepost op:
17 March 2021, 17:20:20 »
Citaat van: AndréDev
Tja... je vraagt om een Scharfenbergkoppeling dus krijg je een Scharfenbergkoppeling
AndréDev
Always on track!
Reactie #1672 Gepost op:
17 March 2021, 19:47:31 »
En daar ben ik ook heel blij mee...
Want wat blijkt...die steeksleuteldingetjes passen er niet onder...
Dus morgen Huider bellen en 10 van die scharfenbergdingen bestellen.
Je weet maar nooit wanneer je er meer nodig hebt
André
Reactie #1673 Gepost op:
17 March 2021, 20:39:31 »
Ehm... wacht even. Kijk voor je bestelt even op het
onderdelenblad
of dat wat je wil bestellen wel datgene is wat je wil hebben.
De Scharfenberg waar ik het over had staat onder pos.nr. 5, en dat is volgens mij een niet-functionele imitatie-koppeling. Voor het koppelen van de wagens (en ook de motor- resp. "stuurstandwagen" onderling dan wel aan de wagens) moet je wel degelijk die 'steeksleutels' hebben.
Ik weet het niet zeker, maar de oudere treinstellen hadden die 'steeksleutels' nog niet, maar iets van metaal, en hoe dat er uit ziet weet ik niet.
Ik heb een poos geleden, nog voor m'n verhuizing, mijn VT 11.5 voorzien van stroomvoerende koppelingen (die ook te ontkoppelen zijn). Dat moet ergens in september of oktober vorig jaar geweest zijn. Is vast nog wel in het draadje "Projekt hoop & onzin" te vinden.
AndréDev
Always on track!
Reactie #1674 Gepost op:
17 March 2021, 21:25:21 »
Klopt,Jan
de koppelingen zijn van metaal en koppelen best goed..denk magnetisch of zo.
De plastic stekertjes zijn recht zonder gat voor het draaistel..dus daarom kan ik ze niet gebruiken.
Of ik doe het gewoon fout...niet ondenkbaar
En het klopt.....ik ben gewoon dom ::)net ff snel nog eens gekeken.
Ik dacht dat de stekertjes een koppeling moeten voorstellen..dom dus...het is een dubbele koppeling zoals lima ook doet bij de Henschel Wegmann
draaistelllen eraf...stekertjes om de asgaten..draaistellen erop...en klaar is K...André
Dank voor het meedenken en zoeken,Bas en Jan
André
AndréDev
Always on track!
Reactie #1675 Gepost op:
18 March 2021, 20:52:26 »
Nu weet ik hoe die koppelingen werken...
Dus wil ik alles vervangen inclusief de kleine voor de motorwagens..
Krijg ik de magneetjes niet meer los
Nou zit er bij het model ook een soort mini kachelpook met halve maan..
Ik denk dat dit de ontkoppelaar is voor het stel..en heb al voorzichtig gefrommelt..zonder resultaat
Met geweld lukt het wel blijkt
Laatst bewerkt op: 19 March 2021, 00:12:16 door AndréDev. Reden: vraag verwijderd
André
Reactie #1676 Gepost op:
19 March 2021, 17:23:38 »
met geweld lukt alles
hrp
Reactie #1677 Gepost op:
19 March 2021, 18:43:52 »
Zeker in WO2..
Hoewel...
R
Ronald
Forummoderator
Reactie #1678 Gepost op:
19 March 2021, 18:55:53 »
Ach, toen ik in Delft studeerde waren er twee Delftse Hoofdwetten:
- Alles kan kapot.
- Zo niet, dan toch.
Reinout
Bouw v/d EifelBurgenBahn
(h0, zijlijn in de Eifel)
Eifelgeschiedenis
hrp
Reactie #1679 Gepost op:
19 March 2021, 19:48:06 »
En de Wet tot behoud van ellende.
R.
Ronald
