Vandaag om 00:24:44
Aachenau West door Peter J K
26 January 2026, 23:20:59
26 January 2026, 23:02:20
Van "Welke-Centrale-Is-Betrouwbaar?" tot "Is-Die-Servo-Defect?" door Michiel VL
26 January 2026, 22:59:31
26 January 2026, 22:45:26
bufferbalken BR 141 Fleischmann H0 door HeVe01
26 January 2026, 22:44:28
Dubbele keerlussen in schaduwstation door Heiko
26 January 2026, 21:45:15
Kortsluiting. Maar waarom dan toch? door Blausee-Mitholz
26 January 2026, 21:39:36
26 January 2026, 21:32:35
NS rongenwagen type S-HTS 89301-89330 door Carl
26 January 2026, 21:27:09
Faller 2026 door Floris Dilz
26 January 2026, 21:09:37
Kippenlijn of Valleilijn door Albert de Heer
26 January 2026, 21:00:50
Ondergrond modelspoorbaan door bask185
26 January 2026, 20:57:31
Raadplaatje door Christoph
26 January 2026, 20:50:23
Da's Daz 2 door Huibert
26 January 2026, 20:45:37
26 January 2026, 20:26:22
Molenbaan (werktitel) door sdz1976
26 January 2026, 20:04:08
19 Toen door Eric B
26 January 2026, 19:53:54
Bahnstrecke 5867 door Dave.......
26 January 2026, 19:36:57
26 January 2026, 18:53:24
Discussie over EETC samenstellingen vanaf 2005 door ns.1200
26 January 2026, 18:42:35
Interesse stamtafel/club Amersfoort? door René 4312
26 January 2026, 18:42:07
Reysburg H0 (NL TP 5/6) door Maikel van Velzen
26 January 2026, 18:24:45
26 January 2026, 18:16:07
26 January 2026, 18:07:44
Länderbahn en Reichsbahn locomotieven. door Modellbahnwagen
26 January 2026, 17:53:47
26 January 2026, 17:47:27
26 January 2026, 17:38:09
Plan N van Heris. door Rob Ellerman
26 January 2026, 17:15:20
Jouef BB9201 anno 1968 door saskia
26 January 2026, 16:51:03
Auteur Topic: Intellibox basic en Decoderpro  (gelezen 9661 keer)
ReneH0
Re: Intellibox basic en Decoderpro
« Reactie #30 Gepost op: 04 October 2015, 16:02:17 »
Investeer in Sprog, en alles werkt gewoon.
Heb ook van alles geprobeerd, het werkt niet of betrouwbaar genoeg.
Jammer helaas, zonde van je tijd.
Met Sprog werk het perfect, investering van ongeveer € 60,00 maar is het waard na bergen ergenis.
« Laatst bewerkt op: 04 October 2015, 17:31:45 door René H »
derrick23
« Reactie #31 Gepost op: 04 October 2015, 20:51:22 »
Ik heb en test gemaakt.
De Loof LocoBuffer, COMPort @ 19200 Baud, Digitrax Centrale, Locobuffer II, werkt!  (y)
Wim Ros
  • BHV
    • Perrongeluk
« Reactie #32 Gepost op: 04 October 2015, 22:18:59 »
Goed, wat ik me dan afvraag of het dan wel goed gaat als je via de IB zelf de decoder leest en of schrijft, gaat dat dan wel zonder problemen? En laat dan eens decoderpro mee luisteren.
Want overal werkt het behalve bij jouw, zal zomaar eens aan de Intellibox zelf kunnen liggen.
Mvg
Wim.
eichddraig
« Reactie #33 Gepost op: 05 October 2015, 06:26:46 »
Het uitlezen gaat prima, dat heb ik gisteren gedaan bij die derde lok die het dus wel deed.
Schrijven op de decoder niet aangezien ik in principe (nog) geen wijzigingen had te doen.
Eerst het programma beter leren kennen en de mogelijkheden bekijken.
Verder nog eens wat meer loks testen of het dus alleen die 2 waren die niet wilden terug praten of dat dat euvel structureel is.
gr. Ed
Timo
  • Team encyclopedie
« Reactie #34 Gepost op: 05 October 2015, 12:40:48 »
Wim bedoelt of het lezen/schrijven naar die twee probleem loc's op de IB zelf wel goed gaat.
Timo
eichddraig
« Reactie #35 Gepost op: 05 October 2015, 21:15:26 »
Dat betwijfel ik, Timo.
Het probleem met die twee loks is juist dat ze niet 'terug praten' (dat zegt die foutmelding juist) en dus uitlezen al niet mogelijk is. Of schrijven dan wel mogelijk is weet ik niet, maar lijkt mij niet handig als het ding niet terug kan communiceren.
gr. Ed
« Reactie #36 Gepost op: 05 October 2015, 21:41:25 »
Denk wel dat Timo gelijk heeft  ;D
Maar heb je wel geprobeerd of de IB ze kan uitlezen?
Als je de locs even ziet bewegen weet je of de IB ze kan uitlezen.
Kapot kan je ze er niet mee maken.
Lijkt me vreemd.
Je geeft ze tenminste allemaal een uniek adres.
Anders reageren ze allemaal tegelijk op een commando.
Gr.
Eric
Timo
  • Team encyclopedie
« Reactie #37 Gepost op: 05 October 2015, 21:58:50 »
Inderdaad, als het probleem al tussen decoder en IB zit is het logisch dat eventuele software ook de mist in gaat. Dus zou zeggen, probeer het eens.
Ik sprak ook over lezen/schrijven als in beide. Veel centrales (ook al zou ik niet durven zeggen welke) proberen overigens ook de waarde die ze net weggeschreven hebben ook weer terug te lezen.
Timo
eichddraig
« Reactie #38 Gepost op: 05 October 2015, 22:21:28 »
Even een stukje geciteerd van de vorige pagina
Tijdens het uitlezen van CV 8 en daarna CV7 zie je de lok een stukje vooruit bewegen en een klikje, maar dan komt links onderaan in het 'Create new Loco'-venster: 'Set PI for read product ID' en daarna error 308
Bij die 2 loks waar het 'vastloopt' leest hij de CV's 8 en 7 wel uit. Als je het log aanzet, zie je ook antwoord terugkomen. Zo uit mijn hoofd 151 (esu) en 107 meen ik.
Daarna komt die error 308 die betekent geen communicatie terug van decoder.
Het niet-schrijven wat ik noem (en jij citeert) slaat op decoderPro. Natuurlijk heb ik al mijn treinen (via de IB) een uniek adres gegeven en diverse andere wijzigingen gegeven.
Nu, bij de lok die ik gisteren onder handen had en het dus wel deed met DecoderPro, had ik geen wijzigingen te doen en dus derhalve niets op weggeschreven.
gr. Ed
Wim Ros
  • BHV
    • Perrongeluk
« Reactie #39 Gepost op: 05 October 2015, 23:45:41 »
301 No locomotive detected. 302 Programmer busy. 303 Requested operation not implemented in command station. 304 Aborted by user. 305 Confirm failed. 306 Timeout talking to command station. 307 Unknown error. 308 No acknowledge from locomotive. 309 Short circuit on programming track.
Foutmeldingen in DecoderPro.
308 zegt gewoon wat het probleem is, de decoder zend geen bevestiging, of te wel geeft geen antwoord. Heeft niets met de IB of de PC of wat dan ook te maken, het probleem is en zit in de decoder.
Zo klaar als een klontje.
Mvg
Wim.
eichddraig
« Reactie #40 Gepost op: 06 October 2015, 06:31:38 »
Duidelijk Wim, zo begreep ik het ook.
gr. Ed
JohnT
« Reactie #41 Gepost op: 13 January 2016, 15:23:39 »
Ik rol bij toeval in deze discussie en kan nog aanvullen dat sommige decoders beveiligd zijn tegen uitlezen en/of het programmeren van bepaalde cv-waardes.
JohnT
