om 03:25:42
Inbouw Märklin decoder 60906
borotof
om 01:05:46
R v/d Hoven
26 February 2026, 22:57:04
26 February 2026, 22:44:46
26 February 2026, 22:32:52
Anton Maris
26 February 2026, 21:57:27
Roco 10764 overload
26 February 2026, 21:54:58
Nummerplaat stoomlocomotief NS 4700 vragen...
26 February 2026, 21:44:41
Viessmann straalantaan 6922
26 February 2026, 21:44:33
"Spoor op Vleugels" in H0
Pinkelpa
26 February 2026, 21:43:07
Daan in Las Vegas
26 February 2026, 21:33:20
26 February 2026, 20:45:12
Klarentrein
26 February 2026, 19:58:08
timtrein
26 February 2026, 19:58:04
Botsing bij SGB 29-12-2025
timtrein
26 February 2026, 19:52:19
26 February 2026, 19:36:07
26 February 2026, 19:12:39
Laatste baan in aanbouw
Debvd
26 February 2026, 19:02:10
De Hondsrugbaan
Jint Nijman
26 February 2026, 18:53:33
Mehano ACTS 7102
ceuleer
26 February 2026, 17:28:39
26 February 2026, 17:25:36
Wandplanken, advies.
26 February 2026, 17:23:25
Beekdaelen in H0
26 February 2026, 17:17:30
R v/d Hoven
26 February 2026, 16:13:36
Bor de Wolf
26 February 2026, 16:09:59
NME stuurstandrijtuig (was: Nieuw in de winkel)
26 February 2026, 15:36:26
H0e pizza layout
26 February 2026, 15:14:45
Te 2/2
26 February 2026, 13:07:05
Hatsune Miku
26 February 2026, 12:45:33
26 February 2026, 12:34:56
Elektronica en analoog
Conrad wisselmotoren aansturen met Digirails 4018 mogelijk?
Topic: Conrad wisselmotoren aansturen met Digirails 4018 mogelijk? (gelezen 7240 keer)
santerdam
Re: Conrad wisselmotoren aansturen met Digirails 4018 mogelijk?
Reactie #15 Gepost op:
12 December 2013, 10:34:11 »
Hoewel ik niet Henk ben, herken ik de strips.
Volgens mij zijn het kabelhouders van Conrad, artikelnummer 211035-89 :
Zie
http://www.conrad.nl/ce/nl/product/211035/
Sander
jerrytrein
Reactie #16 Gepost op:
12 December 2013, 12:51:35 »
de spullen zijn besteld
zullen vandaag of morgen wel binnenkomen
@ de stoker
die zag ik toevallig met zoeken bij conrad
Home > Hobby > Modelspoor > Modelspoor toebehoren > Modelspoor reserve-onderdelen > Reserve onderdelen, overige
211035 Kabelhouders
Fred Eikelboom
Wees jezelf, er zijn al anderen genoeg.
Team encyclopedie
Zonderling en fobie-deskundige.
Reactie #17 Gepost op:
12 December 2013, 15:43:27 »
Citaat van: Thurbo op 11 December 2013, 22:21:58
Kan iemand deze info toevoegen aan de encyclopedie?
Heren, bedankt voor de tip. Is toegevoegd.
mvg, Fred
Als de oorzaak bekend is, is de oplossing een stuk dichterbij.
De Stoker
H0 - TC - Digirails - KL 8.2 1920-1950
Reactie #18 Gepost op:
17 December 2013, 13:02:39 »
Dank voor de tip
deze zocht ik, zal ze op de wensenlijst zetten zodra er een bestelling is zal ik ze bestellen.
Gtrz
Gerwin
Station Eibergen
Station Eibergen - Digitaliseren
jerrytrein
Reactie #19 Gepost op:
18 December 2013, 13:46:31 »
even een vraag
de laatste print
als ik het zo maak dan is er geen onderbreking in de printbanen te zien
is hier een duidelijke print van zoals de roco versie(die overigens maar 1 kant opwerkt)
Reactie #20 Gepost op:
18 December 2013, 14:54:44 »
Als je de componenten plaatst zoals aangegeven hoef je ook geen banen te onderbreken.
Gr.
Eric
jerrytrein
Reactie #21 Gepost op:
18 December 2013, 22:25:20 »
OK
ze werken perfect
Nu even een paar maken stuk of 6 die ik direct nodig heb
bedankt voor alle tips en hulp
Nu nog eens kijken hoe je de B-C-E kan herkennen
Zou een pijltje staan
Maar nie op de conrad transistors
Reactie #22 Gepost op:
18 December 2013, 23:40:52 »
Citaat van: jerrytrein op 18 December 2013, 22:25:20
Bij google vul je in b.v.: BD678 datasheet.
Dan vind je b.v. dit:
http://pdf.datasheetcatalog.com/datasheet/motorola/BD682.pdf
Ergens in dat verhaal staat hoe de pinnen zijn ingedeeld. Bij dit soort transistors zit de collector vrijwel altijd in het midden, en is elektrisch verbonden met het metalen plaatje op de achterkant.
jerrytrein
Reactie #23 Gepost op:
19 December 2013, 00:20:59 »
Klaas
