12 February 2026, 23:41:19
Spoorwegmuseum in zwaar weer door WesleyMunnik
12 February 2026, 23:20:49
12 February 2026, 22:30:31
12 February 2026, 22:25:10
Spotten in Sloehaven en Zeeuws Vlaanderen door Huibert
12 February 2026, 22:11:03
Lok adres programmeren lukt niet met multimaus door Cegielski
12 February 2026, 22:02:11
12 February 2026, 21:55:06
Stub switches door Klaas Zondervan
12 February 2026, 21:28:45
12 February 2026, 21:15:21
RailBOX Accessoire Decoder RB4400 door Steven Loosman
12 February 2026, 21:15:20
Traincontroller software gaat stoppen. door reinderlf
12 February 2026, 21:12:47
12 February 2026, 21:09:20
Bediening OOC terminal Oss door timtrein
12 February 2026, 19:50:02
12 February 2026, 19:42:24
12 February 2026, 18:50:46
Toon hier je nieuwe (model-) spooraanwinst(en)... door Robkop
12 February 2026, 18:42:35
Roco 70788 2400 met Zimo MX645 acceleratie settings door Steven Loosman
12 February 2026, 18:12:17
Station Weesp door virmfan
12 February 2026, 18:05:15
12 February 2026, 18:01:04
Voordelige treinkaartjes door Quinzeedied
12 February 2026, 18:00:49
12 February 2026, 17:46:46
12 February 2026, 17:29:22
12 February 2026, 17:18:29
12 February 2026, 17:03:17
4 april Het Stoomgenootschap naar Köln door Seinhuis
12 February 2026, 16:55:32
Minstens 5 jaar geen treinverkeer Groningen-Leer [D] door Noordster
12 February 2026, 16:51:57
12 February 2026, 16:42:09
Spoor vernieuwing Oisterwijk door Charles_
12 February 2026, 16:42:05
Nederlands-materieel in Spoor-1 door FritsT
12 February 2026, 16:41:07
Spoor vernieuwing Oisterwijk door Daan Knoben
12 February 2026, 16:25:59
Auteur Topic: Roco h0, NS 1200  (gelezen 746763 keer)
De eerste Ivo
Re: Roco h0, NS 1200
« Reactie #1110 Gepost op: 23 December 2014, 20:09:32 »
Hallo allemaal,
Heb sinds zaterdag een 1204. Interieurlicht aan kabine2 kant blijft permanent op 1/2 kracht branden. Iemand enig idee hoe dit kan?
Ivo
« Laatst bewerkt op: 23 December 2014, 20:25:03 door De eerste Ivo »
cor_b
  • at ,t moar exact 1:87 is
  • Doornvliet CS 1975 t/m 1995
« Reactie #1111 Gepost op: 23 December 2014, 20:15:05 »
Rob
Ik gebruik ,t liefst ESU omdat deze fijner zijn om in te regelen,en ik hou van eenheid onder de dec ,anders krijg je zoveel soorten of wel een oerwoud van decoders
Dus ook voor de 1219 een ESU
Ik heb  op het ogenblik van schrijven de kap er af voor de cabine,s te pimpen en het plaatsen van de dec,
Cor
« Reactie #1112 Gepost op: 23 December 2014, 20:19:56 »
Cor, geen geluid??
    • Het Groterdam Project
« Reactie #1113 Gepost op: 23 December 2014, 20:28:40 »
Beide decoders (Zimo en ESU) laten de lok mooi kruipen en fraai en rustig rijden.
Echter bij de Zimo jengelt de motor iets, en bij ESU is deze helemaal stil.
(puur decoder inprikken en rijden, geen instellingen aangepast bij beide decoders)
Het gaat dan om loks zonder geluid. of bij de Zimo het geluid uit.
Dat is mijn ervaring.
cor_b
« Reactie #1114 Gepost op: 23 December 2014, 22:14:32 »
Ik heb wel enkele cv,s  aangepast hij loopt echt fluister stil
Goede trekkracht
F1 en F2 zijn voor het schakelen van de sluitlichten,dus met getrokken trein geen sluitlicht
Ik gebruik een IB en heb beperkte funktie in de toekomst een Z21
Dus ik kan nog geen cabine licht en rangeer licht schakelen
Cor
Corné81
  • DCC 1:87 NS (1996)
« Reactie #1115 Gepost op: 24 December 2014, 09:06:55 »
erg fraai die pimpbeurt van de 1204 en 1219 ga ik na de verhuizing ook eens doen (y)
Gelijkstroom 1:87 NS(1996)
« Reactie #1116 Gepost op: 24 December 2014, 09:11:01 »
Een algemene vraag omtrent de decoder:
Je kan er ook een PLUX16 decoder in steken, maar daarmee verlies je aannemelijk wel enige functionaliteiten? weet iemand wat het verschil in resultaat is met een PLUX22?
Michiel 80
« Reactie #1117 Gepost op: 24 December 2014, 09:11:17 »
Lust een analoge 1200 een sounddecoder en een speaker ?
Ja, getest.
Analoge 1219 gepakt, decoder erin geprikt en een speaker ingeprikt en je hebt keurig een soundlok.
Dus de ACTS 1254 kan zo een soundlok worden, decoder en speaker bestellen en inprikken.
Mooi verslag weer!
Wellicht een domme vraag, maar als je de 1254 van Sound wil voorzien: hoe kom je dan aan de goede geluidsfile voor op de sounddecoder?
Moet je dan de decoder van de 1204/1219 bestellen bij Roco of....
Groeten!
« Reactie #1118 Gepost op: 24 December 2014, 09:19:45 »
@Floris: waarom zou je er een 16 in proppen? Die kosten toch evenveel als de plux22?
« Reactie #1119 Gepost op: 24 December 2014, 09:24:54 »
geen idee, ik ben niet zo thuis in de PLUX decoders, was gewoon nieuwsgierig wat dit voor verschil maakt bij de functionaliteit van een 1200
« Reactie #1120 Gepost op: 24 December 2014, 09:44:15 »
Ok, dan kun je er ook een plux12 indrukken en testen wat het nog meer niet doet ;D (y) ;).
« Reactie #1121 Gepost op: 24 December 2014, 09:50:09 »
Een plux12 en 16 hebben max 4 functies en de 1200 vraagt er ongetwijfeld meer.
Gr, Ben.
« Reactie #1122 Gepost op: 24 December 2014, 09:54:34 »
Volgens mij zijn er zes fysieke functies in gebruik. De kopverlichting zit op de aux0 uitgangen en de sluitseinen op aux1 en aux2. Dus ik denk dat de cabineverlichting dan niet werkt.
« Reactie #1123 Gepost op: 24 December 2014, 10:16:07 »
dank!
  • Schwarzburg-Neuffen-Bahn
« Reactie #1124 Gepost op: 24 December 2014, 10:45:11 »
Ik zie dat de Acts-versie vandaag in de winkel ligt. Even rennen voordat het Kerst is ;D. Als je een heeeeele grote foto wil, dan even deze link aanklikken en onder het normale plaatje 'zoom' kiezen.
« Laatst bewerkt op: 24 December 2014, 10:50:18 door Ruud K »
